Question about Whirlpool GR465LXLS Electric Kitchen Range
How to take off the oven door? Do the silver u-shaped clips that are screwed on just above the hinges need to be taken off first. I have a whirlpool gold range.
  • cherylnorris Oct 22, 2008
    Thank you
    The u shaped clips that are screwed onto the open itself had to be removed before we could lift the door upwards until it disengaged. I took them off and behold the oven door lifted off and I cleaned in between the windows.
    I'll you an A+++ for response and a "thanks for trying"; perhaps my explanation of my request wasn't clear.
    Again
    Thank you
    Cheryl
  • machinehead6 Feb 28, 2009
    oven gets hot and keeps getting hotter and burns the food
    Scholar:
  • 112 Answers
The silver u clips are designed to flip all of the way foreward and hold the door spring tension while removing the door. Once the clips are in place on their notches, you should be able to lift the door upwards until it disengages and then out.
Posted on Oct 21, 2008
How to turn off the oven light when door is closed. My stove is 15 years old
  1. Check all the screws behind the oven door gasket - in place and tight.
  2. Check that the door gasket is installed correctly and with all clips locked into place.
  3. Check the center hinge receiver, all screws are in place for the front chassis support
  4. Check the underside of the range below the center hinge receiver and make sure all 4 screws are tight and in place.
  5. Check that the door hinges are installed correctly & both mounting screws are secure.
  6. Check that the hinge retainers are closed and not blocked by the hinge cover.
  7. Check the top of door liner with a straight edge - make sure the liner is not bowed more than the width of a dime.
  8. Loosen the door panel top screws to a "relaxed" state. Open and close the door and retighten screws.
  9. Check the light/latch switch assembly - if out of position or stuck in incorrect position.
  10. If everything checks out, and oven light still stays on, replace hinges.
Apr 02, 2018 | Ovens
Loose handle on H4900B oven door. How do I access it to tighten the screws/nuts?
Look at your booklet that came with the oven - the page that shows you how to clean the door. The inside glass panel folds upwards and outwards and you can then access the screw holding the handle in place. Unfortunately you need a rather strange star-shaped screw driver.... I had to go and buy one but that's a lot cheaper than a Miele engineer call-out.
If you can't find your instructions you will be able to look it up online.
Catherine.
Sep 10, 2011 | Miele H4900B Electric Single Oven
Hi, We have a Westinghouse electric wall oven with a door which appears to have a broken spring inside. We have previously been able to set it back in gap for hinge but now it has given up holding...
You should be able to buy new springs or the hinge complete from most appliance parts outlets. On some Westinghouse, the door will slide straight off the hinges but on others, you have to strip the door to get at them. Try opening the door and see if the door slides up and away from the oven. If it does, its pretty easy to change the hinge, if not, there will be a little clip on each hinge which locks the arm in place. Slide the clip on both hinges to the front and then you can lift the door up and out of the oven. remove the screws holding the door together and then you will see the 2 screws which hold the hinges in. Order a left (or right) hand side whatever one you need, but I would suggest that they are replaced as a pair, otherwise the door may not close evenly.
Jul 31, 2011 | Ovens
The oven door has disengaged at the hinge I cannot get back into the slot on the stove westinghouse
Hi You cant do this without taking the door off the oven this is a 2 person job when it has disengaged There is a wire clip on the bottom of the K type hinge that hooks on to the top of the hinge if you can get them to hook together you can then remove the door You need to do this to both hinges lay it flat get the 2 hinges hooked together put the door back in the oven and release the hook the hook also looks like a flat u shaped bracket it depends on which westinghouse stove you are talking about as to where it is located mostly it is very close to the oven itself Regards Geoff Stove Recyclers
May 28, 2011 | Ovens
Dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
My oven door does not close tight
These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
Then reassemble.
My door now feels like a new one even though it is 15 years old.
Sep 16, 2009 | Stoves 720EF Electric Double Oven
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Replace door hinges
I had exactly the same problem until tonight!
I had nothing to lose so solved it by sheer brute force!
The problem is with the hinges that the door clips into they seem to get very loose. If you can manage to crimp them against metal they won't move and your door will shut properly. This is how I did it.
1. There are a couple of locks (levers) on each hinge open them up and then lift off the door
2. Ensure that there is nothing wrong with the door brackets, tighten the screws on them to ensure they don't move.
3. Fit the door back on to the hinges and with the levers still open(towards the door) push the door against the hinges which bends them tight in position (don't push too hard otherwise you will completely bend the bracket out of shape you just need to do it enough to crimp it in to place and prevent it from moving)
4. Now open the door, push the levers back closed against the hinges and then shut the door. Hopefully it will be a much tighter fit.
Nov 26, 2007 | Electrolux EOG6330 Gas Single Oven
Removing the microwave door
In many cases, microwave door panels are held together by hidden hooks or catches that ave to be separated by a thin, strong tool such as a putty knife. I've attached a photo that should serve as a good example.
Apr 16, 2007 | Neff H7871A2GB 800 Watts Convection /...
GE JVM1650BB005
You can search under Repair Parts and enter your full model number JVM1650BB005 and get an exploded view diagram here: http://www.geappliances.com/shop/prts/ That diagram can be a great help. Also, I've attached below a door panel diagram from a Sharp model. Your GE disassembly may work the same way. If you haven't already taken the door off the microwave, I would recommend you don't unless you leave the hinge assembly attached to the door and remove the door from the hinges. It's critical to be sure you get (or keep) the door and hinged aligned exactly as they were to prevent leakage.
Dec 05, 2006 | GE JVM1650 1000 Watts Microwave Oven
Whirlpool GR465LXLS Electric Kitchen Range Logo
128 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
