Question about Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB DVD RW DVD BRAND PC Desktop
Sony Viao PC RX404 Frozen
The PC sounds as if a fan is running but won't turn on or off. Blue power light is on and hard drive LED but nothing but the fan noise
  • wsnaith Oct 22, 2008
    No everything is connected right
    The two disc drives work
    The computer does not turn off by the power switch only the mains
    I have put in the 1st recovery disc (supplied as set of 3 with computer) the pc sounds as if it is reading the drive but then after a few moments there is nothing but the noise of the fans
    The monitor is flashing green/orange
  • Canaan Hoffman
    Canaan Hoffman May 11, 2010
    Are you sure everything is connceted right and your not shorting/
    Scholar:
  • 136 Answers
Try removing and reseating the vga card.
Posted on Oct 26, 2008
Blue power light off and fan running hard
The led may have become disconnected or failed. The power led can be replaced as it goes to a couple leads on your main board.
Sep 02, 2014 | HP Pavilion a6547c Refurbished AMD Desktop...
I have an acer aspire ax3960. The problem I have is that it will not boot up, here is a list of the current process that happens; 1. I press the power button, and for a millisecond the blue LED on the...
Try removing the battery, power supply, hard drive and RAM. Power up and see what happens, you Acer should complain. If it does, the mother board is probably OK. remove the power, fit the RAM and try again. If it now tells you it cannot boot, suspect the hard drive but power down, fit the drive and check it.
May 03, 2014 | Computers & Internet
Sony Vaio VGC-RC210G blue panel light LED burned out. Need to know how to change bulb?
Obviously the question was not answered correctly. I don't know how well you are versed into taking things apart, but here we go. First you need to unplug Sony. You need to remove the I/O panel on the bottom of the case after removing the front panel. Remove the on/off switch and remove the two lights adjacent to it. You gently pry apart the tabs on the back of the bulbs and pull the lights out from the back out of retainer. Do the same with the light that is burned out. Carefully cut or break the two cable ties and remove complete wiring harness. You need to remove the side Panel (right side looking from the front). Remove the air tunnel pieces (2 of them), The cable that needs to be unplugged from the motherboard. it is the very first along top edge from the left. It is yellow. Open the 2 tabs that hold all wiring down the front (you will see these just in front of CPU fan and behind front grill. Remove the harness. I do have the number in front of me but you can take the harness to Radio Shack and they can give you the correct one. Cut the old bulb off as close as possible. Solder the new one on and reverse the steps to reinstall. Once harness is plugged back onto motherboard, you can test by plugging power cord in and pushing power button. Make sure none of the wires are touching each other or any metal. Put it all back together and you will have blue light (light is not blue, plastic in front of it is). OR you can just use it without that light as it serves no purpose to be pretty and no one but you will know the difference. By the way I refurbish, repair, etc. nothing but Sony PCs. You also may be able to find a replacement harness but they are scarce. Hope this help. OH, the power supply or motherboard has nothing to do with this bulb working or not. If the other two (power on and hard drive activity) work, the bulb only, is bad.
Jan 07, 2013 | Sony VAIO VGC-RC210G 1GB DDR2 PC2-4200...
Acer aspire m3640 no power light hard drive light on
Check/reseat monitor cables. If the fan and HDD are running, perhaps the power led is out. Check the monitor cable connections. Is the monitor plug into AC? Turned on? Shut down Desktop , unplug, reseat Graphics Card, if applicable, reboot.
Dec 13, 2012 | Computers & Internet
My sony viao laptop was working yesterday but this morning when i turned it on i saw the lights along the front as well as the CAPS, NUM and SCROLL lock, i also hear hard drive activity, but there is...
The high pitch sound could be a faulty inverter.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Oct 23, 2012 | Sony VAIO Computers & Internet
Error why coming
Can you hear any fan or drive sounds? If you don't hear anything at all when you try to turn the laptop on, no little LED's light up, the problem almost certainly isn't related to the hard drive. So if you don't have a live screen, start with the LCD troubleshooting flowchart, and if you don't have any activity at all, start with the power troubleshooting flowchart. Even if the hard drive has failed at the electro/mechanical level and won't spin up, this wont prevent the LED's on the laptop from lighting up, or the LCD from displaying the BIOS information and complaining about the lack of a boot device.
Ford F150 Body Kits
Jun 07, 2012 | Computers & Internet
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
My Gateway Gt 5220 will not turn on. Technicaly it does turn on ex: hard drive spin processor click couple time power brick and processor fan spins hard drive light flickers couples time and cd drive will...
sounds like your system is booting up and running due to the hold power shutdown procedure. you might try replacing the video card or adding one if your video is integrated.
Dec 23, 2010 | Gateway GT5220 PC Desktop
Computer won`t start
Hello there my friend
There is a easy check, it sometimes MEMORY PROBLEMS, or VIDEO , check your RAMs, and take out one module, if has more than one, and restart the PC, I know you will write me back! :)
tell me!
Open Sky
Sep 19, 2008 | Everex GA3400 Refurbished AMD Desktop...
Drive Not Ready
typical of external drives overheating.
i sell external case with fan at my store.
Nov 03, 2007 | Fantom Titanium Hard Drive
Computers & Internet Logo
73 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
