Question about LG 42LC2D 42 in. LCD HDTV
Stand Removal Hi there. I hava a LG 47" LCD & I want to hang it on the wall, only I cant remove the stand that came attached to it. The manual doesnt show the 47" model. Your help with this would be greatly appreciated. Regards Trevor
  • Trevally Oct 23, 2008
    Thanks a mill I found the screws there are 4 on the back. They look like they are part of the casing removal screws, I didnt want to go opening screws before getting some info.
    Cheers
    Champion:
  • 211 Answers
Hi Trevor,
I haven't looked at the 47LG6000 yet, but I'll think that there are 4 screws on the back that you have to unscrew to release the socket. It may be taht there's also a clip that you have to push.
Regards, Gerard
Posted on Oct 23, 2008
  • Gerard Oct 23, 2008
    Hi Trevor,
    Well done, it's my pleasure.
    Cheers, Gerard
Need to remove the bottom attached to tv to mount tv to wall
Firstly, before you unscrew anything, lay the screen face down on a mat on a table/desk with the stand hanging off the edge of the table. This will ensure nothing moves without you wanting it to.
There's four screws to remove, two from each leg. Two of them are above where the mains plug goes in, and two above the computer display input socket. Stand should slide out once these have been removed.
Jan 05, 2011 | LG 42LC2D 42 in. LCD HDTV
I have an LG 42lh40, I need to remove the stand so I can hang it on the wall. How do Itake the swivel stand off? Can some help?
It straight forward check for all around the base stand for screws,just make sure u check and take out all the screws out.Now,just push the base stand it foward or backward for loosen.Just take it out now.
Nov 24, 2010 | LG 42LC2D 42 in. LCD HDTV
I just purchased a JVC 47'' LCD just need to know how to remove the stand. I have it hanging on a Unti do not need the stand.
1. remove the 4 screws on the back of the TV (these are located in the deep holes above the stand)
2. after the screws are removed, the TV will lift from the stand.
The stands sits inside the TV. after the screws are removed the TV will still sit on the stand. you (and someone else) will need to lift it from the stand.
Nov 10, 2009 | JVC LT-47X788 47 in. LCD HDTV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
May 26, 2009 | LG 42LG30 42 in. LCD HDTV
Cant remove stand
thestand should have 2 screws under it
Mar 15, 2009 | Polaroid 3211TLXB 32 in. LCD Television
Stand base removal
how do you remove the stand of lg 50pg30fd so it can be wall mounted
Jun 15, 2008 | Toshiba 42HP66 42 in. LCD Television
Removal of stand to wall mount tv.
Slide clips are used on a lot of these sets, and they require a small, flat blade to release the catch on both sides to allow removal...accordianman
Mar 09, 2008 | Televison & Video
Stand
You should see at least 4 large phillips head or box headed screws tha hold the stand in place.
Mar 10, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
LG 42LC2D 42 in. LCD HDTV Logo
437 people viewed this question
Computer Repairing
Computer Repairing
