Question about Sony KV-27V22 TV
Need to know how to acess the service menu
Want to adjust color screens and vertical
    Scholar:
  • 117 Answers
First, I would do a factory reset. Press power on the TV to turn it on. Press SET UP on the front of the TV. Press CH- (channel down) Next, on the remote control, press MENU. Make sure the cursor is beside VIDEO and press RETURN. Press the UP and DOWN or + and ? buttons to scroll to the item you want, and press RETURN. Press the UP or DOWN (+ or -) buttons to adjust the item AND press RETURN to save the setting. Do this for each category you want to adjust. We hope this helps you, and please let us know if you need any additional troubleshooting. Best regards. nightdiver
Posted on Jul 25, 2006
Can't read writing left of screen needs adjusting
collect service menual book from market.adjust service menu.vertical tuning adjust.
May 30, 2012 | Televison & Video
I have a problem in my BPL TV(FHR-21) it showing a green color
How to Fix a TV When the Screen Is Green
A TV is calibrated by the factory to provide a "standard" picture that attempts to appeal to the vast number of buyers who take the set home. To adjust a TV picture that is too green, you must first enter the hidden "service menu" that technicians use. Adjusting the colors to remove the green cast will save you the cost that would otherwise be incurred from a TV technician coming to your home. No special tools are needed, nor any expertise in how the TV works.
Press the power button on the remote of a TV whose picture is too green in order to turn it on.
Press and hold down the "Menu" key until the manufacturer's logo appears on the screen. This could take up to a minute or more. Release the "Menu" key when the logo appears.
Immediately press the "9," "8," "7" and "6" keys in this order. Press the "Enter" button on the remote to enter the "Service Menu" screen.
Press the "Menu" button to go to the second of the two "Service Menu" screens. Press down on the "Down" arrow until you highlight "Color Calibration." Press the "Enter" button to enter the "Color Calibration" screen.
Select one of the color bars on the screen. Adjust the color by changing the values of the color bar by pressing left and right on the "left" and "right" arrows on the remote. Repeat this procedure with the other color bars as well. Stop adjusting the colors when the green cast is no longer present.
Press and hold the "Power" button on the remote to exit the "Service Menu" and save the adjustments you have made. Turn the TV off.
Sep 14, 2011 | Audio Players & Recorders
I am having trouble with the blue gun. It would
Be shure the guns are set properly follow below:
ADJUSTMENT PREPARATION:
  • Pre Heat Run should be finished.
  • Be sure Screen Color Temperature setting is in the COOL mode
  • Room Light should be minimal.
ADJUSTMENT PROCEDURE:
  1. Go to I2C ADJ. Mode. (With power Off, press the INPUT button on front panel and then press the POWER ON button then release. The Service Menu is displayed.)
  2. Set R DRV (COOL) to center data value (3F).
  3. Set G DRV (COOL) to center data value (3F).
  4. Set R, G, and B CUTOFF (COOL) data settings to [80].
  5. Adjust Screen VRs on Focus Pack fully counter clock wise.
  6. Choose SERVICE item [1] of I2C ADJ. Mode. Select CURSOR RIGHT and the Vertical will collapses.
  7. Adjust any Screen VR. Screen VR should be turned clockwise gradually until that particular color is barely visible.
  8. Repeat for the other two colors.
  9. Exit SERVICE MODE by pressing the CURSOR LEFT on remote.
  10. Exit SERVICE MENU by pressing the MENU key on remote.
Oct 12, 2009 | Hitachi 51F500 51" Rear Projection...
Covergence out of alignment on 1/4 Vertical left side of screen
You need to manually adjust the alignment:
On remote, press Menu to get to the main menu
Then arrow down to "ADVANCED FEATURES"
Then press "enter"
Then Arrow down to "CONVERGENCE" and press "enter"
"Red Convergence" should be highlighted
Press "enter"
You now have Green, Red, and Blue overlapping crosses.
If Red is out of whack, use arrows to align
To toggle to blue (and back to red), press "VIDEO"
Then align blue cross
Once the crosses look aligned, and nice and white, press "AUDIO"
This will bring up the Advanced Convergence screen
This is a grid of the same overlapping colors
You have control over the Red and Blue
If Green is very out of whack, you'll need a repairman…
While the "target" is flashing, you can move it around the screen with the arrows
Place it over an intersection to adjust, then press "enter"
Now the "target" is steady (not flashing), and you can use the arrows move your color
When it's aligned, press "enter" again
Now "target is flashing, and you can go to the next square.
You cannot adjust every intersection.
Some areas need to be adjusted via the adjacent intersection
When you're happy with color you're working on,
Press "video" while target is flashing to change to the other color
Repeat the above (blue is much harder to see and adjust for me…)
When you're happy with the entire grid, start hitting "Menu"
Each press brings you back out one menu level, until you are out of them
Once you're used to the process, it should take no more than a minute or two.
Mar 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Acess service mode rca ctc197cw
hold menu button in. push power button once. push vol up once.
Dec 02, 2008 | RCA F32450 32" TV
Screen position needs adjustment
try opening up the back and the chip with the thousands of mirrors can be adjusted and the should be 4 screws holding it in place but then you could also be pplaying with the focus as well i'd recommend it being a two person job
Oct 02, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Are there internal picture controls for the WS-55315?
Good Day; OPTION MENU "MENU 0370" SERVICE MENU. CAUTION document settings before any adjustments are made. V = vertical, H = Horizontal. Good Luck, big IRISH.
May 11, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Jvc av 27530
**WORKS**
In my case, the adjustment was available from outside the TV. Sortof. On the rear of the TVabout 2 inches to the right of the coax in, there are two vertical slits on a little protrusion. Inside the slits are the two adjustment screws. The lower screw adjusts brightness, the upper screw adjusts focus.
Dec 23, 2007 | JVC AV-27530 27" TV
Service mode
To enter service mode, push and hold the [Menu] button on the set. While holding, push and release the [Power] button, then the [Vol +] button.
You will now have some information on the screen: "P0 V0"
To actually be able to change these values, you must push [Vol +] on the remote so the information reads V76. Then pushing on the Channel +/- will change the "P" value.
P1 - 3 are error codes. If there is a problem with the set that can be self-diagnosed, the "V" will report the code. These codes are available in the RCA repair manual.
P4 - 7 control the horizontal size, shift, vertical size and shift.
You may also find a summary leaflet for the service tech clipped somewhere inside the chassis. The procedures for getting into the service mode, as well as the service items of interest will be there.
If you're attempting to adjust color or geometry errors, you'll need the Video Essentials DVD, Laser Disc or some other source of test material.
Dec 11, 2007 | RCA P46812BL 46" Rear Projection...
JVC Vertical Problem
You need to adjust the vertical height in the Service menu.Press the SLEEP TIMER key and set the SLEEP TIMER for 「0 MIN」. Then press the DISPLAY key and VIDEO STATUS key of the remote control unit at the same time to enter the Service menu.In SERVICE MENU, press the FUNCTION ▼/▲ key to select any of the SUB MENU items. (The letters of the selected items are displayed in yellow.)You want #2 DEF - go to sub-menu and look for the height adj. FUNCTION / key Setting (adjust) the SETTING VALUE of the SETTING ITEM. When the key is released the SETTING VALUE will be stored (memorized). EXIT key Returns to the previous screen.
Aug 22, 2007 | JVC AV-27320 27" TV
Televison & Video Logo
41 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
