Computers & Internet Logo
Posted on Feb 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tower keeps running and monitor says no signal on my Dell t5274
Ben Wabnick
Level 3:
  • Dell Master 2,404 Answers
  • Posted on Feb 05, 2012
Ben Wabnick
Dell Master
Level 3:
Answers
2404
Questions
Helped
883258
Points
7655
Turn off the computer and then take out all the memory from the computer. Reseat the memory into one of the slots and then turn the computer back on and see if the video comes back. If it doesn't then repeat this step for each memory stick in each slot one at a time.
If after trying all the memory and all the slots you still can't get video then the motherboard is bad and would need to be replace
2 Related Answers
Anonymous
  • 63 Answers
  • Posted on Feb 26, 2010
SOURCE: eMachine T6522 monitor says
This could be an issue of a video card gone bad. I have experienced the same issue firsthand. This could also mean that no RAM is installed. If you have been using this computer previously, the second option is probably not even an option.
If you have another computer available, please try plugging the monitor in to that machine to test. If it works, your Video Card is more than likely toast.
But not to worry, you should be able to find a new card for that machine. I believe it will be a PCI Video Card, which may run you anywhere from $20-$100 depending on what you purchase. Please consult with eMachines before ordering a new card. Some will not work with your machine.
I hope this helps you out. Have a great day and please don't hesitate to ask any further questions regarding this issue.
Testimonial: "Will definitely ck this out...sounds possible."
Anonymous
  • 60 Answers
  • Posted on Oct 02, 2010
SOURCE: MY HP TOWER TURNS ON
If the keyboard and is USB, you can try another USB port. For the monitor not getting display, I would try either a different monitor or a video card. Otherwise, the motherboard could be the problem.
I have emachines w3653 and the no signal keeps popping up
Are you still using the monitor that came with or have you replaced that monitor? The monitor or the cable connecting it to the tower could be faulty. If possible try connecting another cable between the monitor and the tower and then if you still get the no signal message, try another monitor altogether.
MONITOR Dell older model says no signal
The first thing to check is the cable between the tower and the monitor. If you have done this, then hold the power button until the computer shuts off...wait 5 seconds and then turn it back on. If these two things do not work, then it is likely that the integrated video part of the mother board has failed.
Black screen and one beep
One beep usually indicated that all is ok
Check the connection form the PC to the monitor, unless you are getting a number of beeps, the issue is most likely with the VGA cable or a dead monitor.. try a different monitor, computer tower sounds like it is ok.
1helpful
2answers
My Desktop computer is dead
it means that the monitor is not receiving any signal from the cpu, check the cable that goes from the tower (cpu) to the monitor
1helpful
I have an older Dell Dimension 2400 series. I have tried running the monitor with it. I will get it up and running only after numerous restarts. Most of the time when I start up my system the monitor...
If it's an older 2400 series and you suspect it doesn't have a good signal going to it, I would try the monitor on a different tower to see if it's the monitor. If it isn't, I would recommend that you try to disable and change the VGA card in the Dell, if possible to a known good VGA card.
Also, try wiggling the connections at the monitor and graphics card, if this applies.
Or else, it might be a lost cause for that tower.
Good luck on getting the Princeton monitor working with your Dell Dimension 2400 series.
Monitor has no signal
make sure that your tower is on and running because alot of times when it is not on the monitor will give you an error message that says Monitor has no signal
also make sure that all of the cables are plugged in!
hope that this helps
1helpful
Monitor keeps saying no signal.Tried a new cord from monitor to tower but that did not help.The light is on the monitor to show that it is on.Help please.
connect another working Monitor to the tower, if this solve the problem send in the monitor to the monitor's authorised repair center. If the problem is not solved, replace the Vedio card on the tower
11helpful
3answers
My screen is showing Self test feature check and will not stop! Help!
The first thing to check is--is your computer actually running?
It sounds like your computer is either off or it is not sending a video signal to the monitor.
If there was a signal going to the monitor, you would be seeing something other than self test.
There is also probably a menu button on the monitor. Find it and push it to reset the monitor.
Now check your computer--preferably with another monitor to see for sure what is going on.
My screen sayin signal cable disconected
if you are using an lcd monitor, make sure you have connected the vga (screen cable) properly and tight both on the tower and your monitor. if its crt monitor then make sure the vga cable is tightly connected to the tower on the female connector
3helpful
4answers
My monitor says there is no signal from my new Dell Studio
Try reseating the video card in your new computer. Sounds like it may not be seating in the slot properly. Take it out and put it back in with the power off and then hook everything back up and then see if you get video,.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
