I have a philips freeline 1100 and have so many problems with it within 3 moths of purchas it has had a new hard drive ,fan, graphics board,ect; I now have the biggest problem with it it kept shuting down then starting up until it had blue screen then black with files missing everything has been wiped of f of the hard drive windows reinstalled hard ware have been checked and the 250 hard drive taken out and a 80 gig hard drive installed It works but I have been told that if I have a 250 hard drive put back in the same problems will happen again as the tower casing is a bad design and there is not enough cool air circlating inside to keep it cool. and that this model has been discontinued ,,... is this true.. can you help me please.. sallyanne
Go to this link and read my blogs at bottom of page (my name is folkestoner) for information and help on Freeline LS1000s and LS1100s
http://news.digitaltrends.com/news-article/5985/philips-freeline-entertainment-pc-s
Posted on Nov 25, 2008
Please show me value for resistance location no are 3644 and 3626 in philips 107T , thanks for the help
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connections and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause you problems or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps you
Nov 14, 2011 | Philips SoHo 107T21 (White) 17" CRT...
Tip
Error Codes you need to know.
Standard Original IBM POST Error CodesCode Description
1 short beep System is OK 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Display adapter problem (EGA) 3 long beeps 3270 keyboard cardIBM POST Diagnostic Code DescriptionsCode Description 100 - 199 System Board 200 - 299 Memory 300 - 399 Keyboard 400 - 499 Monochrome Display 500 - 599 Colour/Graphics Display 600 - 699 Floppy-disk drive and/or Adapter 700 - 799 Math Coprocessor 900 - 999 Parallel Printer Port 1000 - 1099 Alternate Printer Adapter 1100 - 1299 Asynchronous Communication Device, Adapter, or Port 1300 - 1399 Game Port 1400 - 1499 Colour/Graphics Printer 1500 - 1599 Synchronous Communication Device, Adapter, or Port 1700 - 1799 Hard Drive and/or Adapter 1800 - 1899 Expansion Unit (XT) 2000 - 2199 Bisynchronous Communication Adapter 2400 - 2599 EGA system-board Video (MCA) 3000 - 3199 LAN Adapter 4800 - 4999 Internal Modem 7000 - 7099 Phoenix BIOS Chips 7300 - 7399 3.5" Disk Drive 8900 - 8999 MIDI Adapter 11200 - 11299 SCSI Adapter 21000 - 21099 SCSI Fixed Disk and Controller 21500 - 21599 SCSI CD-ROM System
on Mar 09, 2010 | Computers & Internet
I need to buy a internal hard drive for a Philips Freeline LS2200. Can you advise me if I need a 2.5 or 3.5 inches?
The Philips Freeline LS2200 uses a 320GB SATA Seagate, 3.5 inch width harddrive. (7200RPM)
The usual desktop sized harddrive.
Due to the low costs of SATA desktop harddrives, I would recommend at least a 500GB unit,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4499974&CatId=2459
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 24, 2011 | Computers & Internet
Computer will run for serveral minutes then shut down. I have new mother board, new power supply. i use cpu paste that is new. the cpu fans starts with a roar and then is very quite.
Hi
The initial fast running of the fan is normal, I'm assuming the fan has as 4 pin connector which is the one with thermal control ( fan speed increases as the cpu gets hotter).
Try booting into the bios, in hardware monitor tab, see what the cpu temp is doing and the motherboard temp. Look for any initial overheating. If the bios screen indicates a temperature rise to say 80 degrees within the 1st 3 minutes of booting, then recheck the security of the cpu, the thermal paste used and whether the base of the heatsink is free from pits.
Look also at the power output of the 12v and 5 v etc circuits, make sure they are within 0.5 volts (0.25 is better).
Check the motherboard and connections, in particular, look for blowing capacitors, or signs of arcing that would cause power to earth. You may have a hairline crack in the circuit that is expanding as the board warms up.
Check the ram is right for the board, remove one module at a time, test with it in and out.
Unplug all hard drives and optical drives, see if it boots to the bios and stays on and then replace each in turn.
Check the PSU.. new it may be but it could be faulty
remove the graphics card if fitted and any other slot in cards, test with these out of the computer, disconnect the usb cables from their headers
After that, the issue may be a fault with the switch, the switch wires or a faulty board or cpu.
Jul 22, 2011 | Gateway 505GR PC Desktop
Thanks Miro70, what 3in high graphics card for LS1100 desktop
Actually you may have to shop around for a form factor that would fit smaller cased pcs. Try Tigerdirect.com.
Mar 17, 2010 | Computers & Internet
My Philips LS1100 freeline desktop PC is too slow ???
u need to change graphic card first in something better !!!
what games u want to play, tell me and I'll tell u what u need exactly !
Your RAM ??? It can't be 2.6G, but that is place to start, ram must be same brand and value, compatible with Your motherboard !
Feb 24, 2010 | Computers & Internet
Hard drive
Some motherboards support both IDE and SATA so it is not unlikely for your MOBO to have both. There should be some mention of SATA in the motherboard BIOS screens so have a look see. Otherwise just plug in a SATA device to it and see if it works!!
Cheers,
Ripface.
Sep 26, 2009 | Asrock 775Dual-880 Pro Motherboard
I have a philips freeline x57 computer with a white screen
tray this unplug from power for 30 sec and plug to wall again
Apr 17, 2009 | Philips (142440) Computer Speakers
Philips Freeline MT1000 freezes during operation.
you need to reinstall windows mine youst to do that all the time so I got a new higher ram card a new hard drive and new graphics card for £20
goto this video for more help on how to make computer faster so it will stop freezing
http://www.youtube.com/watch?v=CTHTAaobXS4
http://www.youtube.com/watch?v=aMRId33OU-I
http://www.youtube.com/watch?v=Js2taikG7_Y
Jul 15, 2008 | Computers & Internet
VGA/MOTHERBOARD
Try hooking up to the onboard card and check the video settings in yor bios. Usually press f2 to get there on bootup. Select VGA graphics.
Jan 29, 2008 | IBM NetVista PC Desktop
Computers & Internet Logo
179 people viewed this question
David Payne
David Payne
