Question about Kenmore 22422 Top Load Washer
Wont spin unless you use a tool to depress the contactor in the little slot on top of washer lid..seem like the piece is loose or has lost a screw..works and spins fine if you hold piece down with tool....stupid ? how do I raise the lid...dont want to break it my wife will kill me..ha
  • 62 Answers
You cant raise the lid. You have to take the sides off the top panel, and unscrew the two phillip head screws. Then remove the two brass clips(very strong). Then pull the whole cabinet off. Then repair lid sw. Be carefull when putting cabinet back on, you have to make sure the back of cabinet goes on the rail with the clip into it, if you dont put back on right it will vibrate.
Posted on Oct 22, 2008
Not spin water
do you mean the lid switch is loose? 02 Control and Rear Panel Parts for Roper RAX4232PQ0
if it is broken -- you could bypass it 01 Top and Cabinet Parts for Roper RAX4232PQ0
take out the two screws on the top control panel edged and remove the panel - just tip it back-- see that squiggly metal piece in the edge -- use a flat screw driver and stick the end in the slot of the tip of the brass looking squiggly piece and relieve the tension. The top will now be loose and there is the lid switch
Jan 12, 2014 | Roper RAX4233PQ Top Load Washer
Frigidaire top load washer does not spin until I depress the lid lock switch
Is the strike still in place on the lid? What is the model number?
Nov 20, 2013 | Frigidaire Washing Machines
Machine not spinning
where lids closes on top of washer is a little hole. on bottom of lid is a peg that goes into that hole. try first pushing lid down hard to see if makes contact, if not that switch if does not make a click sound when depressing, most likely is out, can easily be replaced, and can do yourself. swich is maybe 20 bucks, that swich is a safety switch, to not allow washer to spin unless lid is closed, to prevent injury to a child sticking hand in when spinning.
May 11, 2011 | Fisher and Paykel Washing Machines
Sony cfd-z110 cd seems to not spin/play when door/lid is closed but will play when lid is open and lid switch is depressed, is there any thing (maintence) that needs done on that round piece (that is...
your on the right track. the piece on top should spin really freely. there is a spring inside of that piece. if it lost its track it will lock it up from spinning. one other think it maybe is the tab is broken that presses the switch down. inspect both things if it ends up being the tab missing you can simple hot glue the switch down or dissemble and twists the two wires together (ones at the switch) that will bypass the switch. beware if you do this the laser will be active every time you have it in cd mode. (don't look at the laser it can harm your eyes) hope this helps please rate me.
Dec 31, 2010 | Sony ZS-S2IP Radio Boombox
Washer fills with water. agitates, does'nt finish cycle. still full of water.
The most common reason for this problem is the Lid Switch. If the lid is not closed, washer will not go into extract (drain) & then spin cycles. Check the lid to see if the plastic piece that pushes the switch down is broken off. You can simulate "Lid Down" condition by depressing switch with a screwdriver. It's located on the right side of the wash drum / tub. There is an oval slot there & you should hear & feel a click when pressed down. Look directly above that slot on the lid bottom for the plastic piece that is commonly broken off.
If it is, you can apply a temporary fix by wedging something in the slot to depress switch while you order a replacement part.
*****WARNING*****
Operating washer with this interlock defeated can cause severe injury!
Washer will continue to spin with the lid up!
You should use this technique for troubleshooting purposes ONLY!
Please reply if this is NOT your problem and I'll post other causes & solutions for you.
Sep 16, 2010 | Whirlpool Washing Machines
Washer fills up agitates then when it should drain ,nothing.motor dosent come on to pump water out.
In most cases all brands will fill and agitate with the lid open, but will not drain or spin with the lid up.
It sounds to me like your lid switch is either bad or misaligned.
The first thing to check is the actuator plunger on the lid. Make sure it hasn't fallen or been broken off. Look for a piece hanging down from the lid that looks like a little finger that when the lid is closed, would hit and depress the lid switch ,which is under the top of the washer.
If it looks like the actuator is good shape then the lid switch is either bad or misaligned. Take a pencil or a bic pen and depress the lid switch. Making sure your washer is plugged in and in the spin mode. If it begins to rotate to spin and drain then see if a screw has fallen out that holds it in place or became loose not letting the actuator hit it correctly.
If the switch does not seem loose and it will not start the machine when depressed with a pencil it is probably time to change it out.
Apr 09, 2010 | Kenmore 24032\24036 Top Load Washer
Washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Jul 21, 2008 | Whirlpool LTE6234D Top Load Stacked...
Won't agitate!
does your model have a drive coupling its between the motor and gearcase,when they brake the machine wont wash or spin and makes a wierd noise
Jan 12, 2008 | Whirlpool LSR6232J Top Load Washer
Washer will not spin
I'm having a little trouble understanding the question because of the spelling, but this sounds like a typical lid switch not making contact either by the depressor on the lit itself or the switch is broken. try depressing the switch with a screwdriver and see what happens. The lid switch will be in a little slot in the top inside where the lid closes.
Dec 17, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
