Question about Canon PIXMA MP460 All-In-One InkJet Printer
Canon HL 5040 printer grabs multiple papers to print
Canon HL 5040
The printer will grab 2-3 sheets to print one page...resulting a broken printout...meaning the top will print on the first...the second paper is blank...the third sheet has the rest of the print. Or when it grabs two...the top is on the first and the rest on the second sheet.
  • Anonymous Mar 17, 2014
    when printing the first sheet goes in then the second one jams
    Problem Solver:
  • 4 Answers
Try one sheet at a time that may work.
Posted on Oct 21, 2008
Canon MP470, Printer feed grabs two or three sheets of paper or grabs only one and jams. Result = no print capability because of paper feed. I have been told that it would be cheaper to replace than fix....
Your feeder wheels need to be cleaned, open it up yourself from diagrams online, locate the feeder wheels, remove them, clean them with rubbing alcohol and a lint free rag, that will take care of the problem, if however the wheels are worn or how chips in them, then you can order the replacement parts
Sep 26, 2017 | Canon PIXMA MP470 All-in-One Printer
Hi, my canon ip2600 printer is grabbing multiple sheets of paper when printing instead of a single sheet at a time. It prints but some lines of print in the final result are to compressed to be almost...
the printer is grabbing multiple paper because the paper is stuck together in cold times the paper sticks together when you insert paper into the paper try try to make the papper loose
Mar 01, 2011 | Canon Pixma iP2600 Photo InkJet Printer
My praftically brand new Canon Pixma MP620 printer grabs more than one sheet of photo paper and stops printing picture on first sheet then garbles several pictures on a portion of the next sheet. I just...
check the printer's printing preferences on properties option.should be set to normal then check the printer rollers if its dirty where the papers pass thru, if the problem persists load only 1 paper every time you print for the printer not to grab more papers.i think it is in the feeder and the sensor maybe its dirty need to be cleaned up.
Feb 22, 2010 | Office Equipment & Supplies
The printer costantly "grabs" multiple sheets when trying to print a single page. the printer driver settings are ok with page size and media settings but it does it anyways!
This is to do with your rollers and feeders that take the paper from the tray or paper holder.
I personally recommend you take it either to a specialist or if it is still under warranty send it back to the manufacturer to fix this issue.
Hope this helps.
Jack Isaacs
Jan 29, 2010 | Canon iP100 Portable Printer
When printing, the sheet of paper always gets jammed.
check the wheels that pull the paper through. sounds like only 1 is grabbing. see if it fell off track
Jul 11, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon R265 keeps grabbing 6 sheets for printing one sheet
Paper has different thicknesses called Mils. Make sure you are using the correct paper for your printer. Paper that is thinner than is intended for your printer may sometimes cause it to take multiplesheets.
Jun 15, 2009 | Epson Stylus R265 InkJet Photo Printer
Printer grabs multiple pages to print one. Prints in mostly green for color copies.
Go into the printer setup menu and change the paper type to default. If your using Microsoft Word, go to 'File" > "Printer">"Properties" , and change to "plain paper" or default.
The problem sounds like the printer is set to print photos which is a heavy paper type. The printer needs to be set for a standard weight paper.
Mar 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
The rollers grab the right side of the paper and then jams
the gears which r pulling the paper r slightly worn out or getting blocked by dust particles.
you look carefully where u install the paper for printing there is a black colour round rubber gear with white colour part like a tiny stick attached to it.just check if that part is broken.if yes you have to replace that part.
Oct 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
My MP510 grabs way to many sheets of paper.
hi i am a Canon certified repair tech for this printer. it seems that your problem is due to a broken sheet feeder unit. what i ahve seem with some new machines is that a plastic shaft that controls ther seperation of the pages breaks. most of these problems occurs with new machine because they are shipped from place to place. if the unit is under a year old it is still under warrenty and can be brought to or shipped to a repair center. even if its not under warrenty any longer you should still call Canon at 1-800-OK-CANON and complain that it has been doing it since you bought it and they will locate the nearest repair center to your location for you. hope this helps.
Jan 01, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
406 people viewed this question
old marine
old marine
