Question about Honeywell Heating & Cooling
Honeywell 7512A. Working fine. Turned off power yesterday notice no display so once power was restored I changed to new batteries. There should of been a display due to the batteries. New batteries were checked fully charged. Breakers were all reset. Batteries are in properly. Now I have no display. Polarity is correct. Wiring configurations is White to white. Orange to Yellow terminal. Green to green. Black to red terminal. Red to RC terminal. I have airconditioning and heating.
  • 7 Answers
SOURCE: changing thermostat matching wires trouble
Brown my friend is for the 4 way valve solenoid, that is if you have a heat pump, ( it uses freon for heating instead of natural gas) perhaps you got the wrong thermostat, if you have a brown you need a thermostat for a heat pump, a regular thermostat is not going to have a brown connection.
Posted on May 08, 2008
  • 61 Answers
SOURCE: Thermostat wiring
your best bet and where i would start is to identify where the coulors are conected at the fernace. in the industry we use standard wireing coulors wher green is g for fan and red is rh=switched trans power for heating . rc=switched transformer power for cooling . now normaly there is only one transormer so you would put a jumper from rc to rh and conect the red wire from the furnace to eather of these.jumper installed. the y is your cooling witch is normaly the yellow wire. o on the stat is for a heat pump if you nead to energize reversing valve in cooling mode . w is first stage heating and this can be conected to eather brown or white youll have to check at the furnace to see witch it is . the final wire eather brown or white should be conected to c or 24v common witch you didnt say you see on the thermostat. once again
red to rc and rh
green to g
yellow to y
brown or white to w
brown or white to common or c
please post feadback hope i was of help
Posted on Oct 21, 2008
  • 306 Answers
SOURCE: I'm installing a Honeywell RTH7600B
Every thing the same except take your blue wire and replace the yellow for it. So when you hook it to t-stat goes like this
Red to R
White to W
Green to G
Blue to Y
Posted on Jan 16, 2009
  • 410 Answers
SOURCE: thermostat wiring goodman model aruf032-ooa-1b
is this a heat pump or straight cool with heat strips?
Posted on Mar 16, 2009
  • 415 Answers
SOURCE: recently changed thermostat on gas furnace w/ cent air
Unfortunately, a strick standard does not exist for wire terminals and colors. However, there are "norms" which I will be happy to share with you.
Red - Rh & Rc (Jumpered)
Blue - C
Yellow - Y
White - W
Green - F
Note: this is assuming you have only ONE transformer in your low voltage circuit for both heating and cooling. If there is a low voltage transformer at your outdoor unit you will need to seperate Rc & Rh. At this point, I have to recommend a trained, qualified service technician. A good service technician should be able to resolve the wiring issue in under 30 minutes.
I only wish I was able to look at exactly what you have to include tracing all the wire back to the furnace and condensing unit. Tracing the wire is the only sure-fire wire to do the job correctly.
I wish this could have been a black & white answer; however, I do hope you found this information helpful in your endeavor. Good Luck to you! :-)
Posted on Mar 10, 2010
Testimonial: "thanx,but i figured it thermostat required a battery for led display...elim. blue added jumper-good to go....thanx though!"
My Honeywell dt200 is displaying a flame when I turn it on but isn't actually heating.
The problem could be with the heating unit or furnace and not the thermostat.
Aug 10, 2015 | Honeywell Programmable Thermostat Heater
I have a honeywell programmable therm that worked fine last season - didn't turn on during the summer as didn't need A/C. It is currently displaying the correct day and time, but the temp is not...
Hello my name is Heath it will be my pleasure to assist you. Your thermostat may be on the blink and need to be replaced. But first lets try a couple things first take the batteries out of the thermostat and let the display go completely blank ( aprox. 5 mins.). While that is going blank go to the indoor air handler and turn the power off to it either from the switch or the inside panel box. Then once the display has gone blank turn the power back on and put the batteries back in. Then set the switch to cool and turn the temperature down and press hold and try it like that to see if it goes back to heat if it does then the thermostat is changing the temperature on its own and going into heat mode and will need to be replaced.
Sep 21, 2011 | Honeywell Programmable Thermostat Heater
I am having a compaq laptop 1 yr was working fine till when i restarted it the 1/4th portion of display has turned black.there is no hardware damage reported and lcd was working...
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Microsoft Computers & Internet
No display on Robertshaw 9600; unit seems dead/furnace works
you have to have a thermostat! The thermostat tell the unite what to do. Get a new one.
Jul 25, 2009 | Honeywell Programmable Thermostat Heater
Honeywell digital thermostat stopped working
Sounds to me like you have a low voltage short. If the stat had no display until you installed the battery means there was no voltage for the stat to work. Putting the battery in proves the stat works, no motors turning on probably leads to a blown low voltage fuse generally a blade fuse on circuit board in indoor unit. Good Luck
Jun 11, 2009 | Honeywell Programmable Thermostat Heater
My thermostat quit working
Does it have batteries that need replacig. I think so. good luck.
May 31, 2009 | Honeywell Programmable Thermostat Heater
New batteries ...display not working
remove the batteries and pull the metal tabs at each end stretching out a little the reinstall the batteries
Nov 26, 2008 | Honeywell Programmable Thermostat Heater
Honeywell Thermostat won't turn on
There is a small automotive type of fuse in your air handler (not thermostat), check that. Also check to see if the Emergency Switch somehow got turned off (Usually found in stairwell or closet).
Aug 05, 2008 | Honeywell Heating & Cooling
I have a Honeywell Programmable Thermostat T8600 and nothing displays. It was working fine, and the A/C was on on Saturday. I checked the display on Sunday and the thermostat was blank. All other lights...
check your transformer for power, should get 24V reading, if transformer is out make sure there are no short otherwise your new one will have the same fate.before checking the transformer however, make sure that your dedicated breaker for the air handler and your switch in the attic is turned on.
Apr 15, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
