Question about Canon PowerShot A85 Digital Camera
Sudden shutdown I have a Cannon A85. I was taking pictures and then it flashed E30 on the screen and went dead. The lens is still extended the lens protector is still open. I tried opening and closing the battery and CF doors, replaced the batteries and now it is just dead. The camera is about 2 years old and has been gently used. Thank you for any suggestions you may have. Sandi
    Problem Solver:
  • 57 Answers
Hello Sandi, I think there is a problem with lens and it will not be fixed otherthan Canon. It better to go Canon shop. thank you.
Posted on Jul 25, 2006
SOURCE:
Lens on my S7000 doesn't retract when switched off - now permanently extended - and camera dead
This is going to require service / repair at the shop, not something you will be able to correct.
Jan 26, 2013 | Fuji FinePix S7000 Digital Camera
PROBLEM WITH - Cannon PowerShot A85:- The
switch off the camera and take out the baterys for a muinnuit then put nthem back in then switch on the camera if you still have the same problem you may need to use the same type of batterys as wos with the camera
Mar 07, 2011 | Canon PowerShot A520 Digital Camera
E18 screen msg
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Don't want to get your hopes up too high, but here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 17, 2009 | Canon PowerShot A85 Digital Camera
My camera is showing E18.I can't take photos. What
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 30, 2009 | Canon PowerShot A85 Digital Camera
I have a cannon A85 digital and flash works but no picure will t
I think your Canon A85 is not giving you live view to take picture?
If this is the case then it is known problem of CCD Imager in A85 and that part will be replaced.
Canon offers free of cost repair for bad CCD Imager in A85.
Please click Canon CCD Imager Advisory for details.
Feb 08, 2009 | Canon PowerShot A85 Digital Camera
Cannon EOS Rebel XS shows busy display stopped working
Just got a brand new camera. Played around with it a few nights to learn all the parts and buttons. Went to a concert tonite. While waiting for the show I took many test shots to see how the camera would work under these contiditions. Used a 75 to 300 Cannon lens. I had just got the settings about right when the show started. All of a sudden the display went dark and "busy" flashed in the view finder. But it would not take any more pictures. Taking the battery out and removing the sd card did not help. The auto focus and flash still worked but nothing else.
This camera is going back to the store if I can't get some help. PLEASE............. vj
Dec 05, 2008 | Canon Digital Rebel / EOS-300D Digital...
A85 Dead
I read something about the fuse going out...
http://www.dcresource.com/forums/archive/index.php/t-18151.html
Apr 12, 2008 | Canon PowerShot A85 Digital Camera
Lumix TZ3 lens does not open
It is not clear if you are saying whole camera turns off or just screen turns off.
Notice before the camera went bad the lense does not extend in play mode, while it does in record mode. Many cameras have software that automatically turns camera off if lens cannot/fails to extend for some reason. Try to help it extend in record mode before camera turns off.
Feb 23, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Feb 18, 2008 | Canon PowerShot A85 Digital Camera
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Nov 16, 2007 | Kodak EasyShare Z612 Digital Camera
Canon PowerShot A85 Digital Camera Logo
75 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
