Question about Microsoft Xbox 360 Console
Xbox 360 Game console
Am unable to play xbox games on the xbox console, but i can play dvd movies.
    Problem Solver:
  • 9 Answers
What you are going to have to do is replace the disk drive, send it in to microsoft and they will fix it
Posted on Feb 22, 2009
Xbox 360 wont play games but will play dvds
A drive that will play DVD movies but not Xbox 360 game discs has been set up incorrectly at the factory. The only solution is to return the Xbox 360 and specifically note the problem so the drive can be repaired or replaced.
Apr 02, 2010 | Microsoft Xbox 360 Console
Play multi region dvds on my xbox 360
http://www.biline.ca/360_mod.htm
Flash your 360 drive with a custom firmware and then you can play any region of any game or dvd movie
Mar 07, 2010 | Microsoft Xbox 360 Console
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Feb 18, 2010 | Microsoft Xbox 360 Console
My xbox will play movies but when it comes to
You likely need a new laser. I would recommend getting your System diagnosed by a professional.
Feb 10, 2010 | Microsoft Xbox 360 Console
The console thinks the disk is a movie and displays play and pause and chinese looking letters appear on the screen. It won't allow me to do anything
The problem you are facing is of a copied Xbox 360 game you are probably trying to play on a Genuine Xbox 360, these discs are read as a movie disk and it shows as "Play DVD".
When you try to play such discs, it would give you dvd media control bar on the bottom and the message in chinese letters is actually a message asking you to insert this disc in a Xbox 360, which is actually a Modded Xbox 360 that is required
Dec 30, 2009 | Microsoft Xbox 360 Console
Xbox says play DvD when there is a game in the Disc drive....
Hi. You need flash the firmware from the old drive to the new drive.
Jun 11, 2009 | Microsoft Xbox 360 Console
Installed new Xbox DVD ROM, but cannot read games
The DVD drives must match the motherboard that it came with. Unless you go through a very complicated re-flashing process. If the motherboard and DVD drive do not match, it will not play 360 games
Dec 04, 2008 | Microsoft Xbox 360 Console
Xbox 360,michael
if you broken the seal then take it to a xbox repair person.
the drive is going bad or out of alignment
good luck
Jun 02, 2008 | Microsoft Xbox 360 Console
Will not read games
some one either bumped the 360 or moved system vertically while playing game there is not fix for game now never put vertical when playing any games its also on the 360 manual or bump it in any way
Apr 24, 2008 | Microsoft Xbox 360 Console
XBOX ( not a 360 )
What are you trying to play, DVD movie or a Xbox game?
Nov 10, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
42 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
