Question about Kenmore Dishwashers
Kenmore dishwasher mod. #665.16912001
Makes a howling noise when running. Took it apart and found two tooth picks. Put it back together, same noise. Took it apart again but I can't figure out how to get the protecter inlet off, I think there might be something else in there. I have the screw out but it won't move.
SOURCE: How do I put it back together?
buy a new one, look at it, put yours back together and return the new one.
Posted on Oct 13, 2007
  • 1314 Answers
SOURCE: dishwasher pump not working
if you go here http://www.searspartsdirect.com/partsdirect/index.action and enter your model number without any spaces you can get a parts list on that page you will see show diagram it will give you a blueprint of the pump moter assembly
Posted on Jan 30, 2008
Skill Will
  • 53 Answers
SOURCE: Dishwasher not pumping the water out?
hi
the larger motor housing underneath the unit is what moves the water around to wash, the smaller pump is the drain pump, if you don't hear that running it is likely in need of replacement. check your paper work for warranty, if it's out of warranty try to find a deal online and it's relatively easy to replace
Posted on Mar 21, 2008
SOURCE: kenmore dishwasher
Mine eventually "fixed itself". I think some debris got caught and eventually (5 cycles or so) got ground up and sent through the drain. The noise changed each time it got closer "flushing out"
Posted on Apr 24, 2008
SOURCE: kenmore elite dishwasher noise
I had the same problem where rubber gasket that seals the motor bearings leaked water into the bearing and rusted out the bearing.
I scrapped the motor into every little pieces and extracted the bearing and just replace it. Now it is quiet as a mouse.
You need a bearing puller to get the bearing out for about $20 and the bearing is $6.
During the repair i slightly bent the shaft and i didn't straightened it properly so it wobbles a bit. But it works and if really quiet.
Posted on Jan 21, 2009
I took a Lefod Mod LF10-1H Pressure Control switch apart and I'm now looking for a diagram on how to put it back together.
You silly person you should not have taken it apart if you are not capable of doing the job
Dec 18, 2015 | Washing Machines
The dishwasher still cleans OK but we suddently hear a loud sound. I decided to disassemble the thing so I took every plastics off, unscrewed every screws I found, until I found large wooden tooth picks...
Hello, welcome to FixYa.
I understand by reading your post (which indicates it is a Kenmore dishwasher) you appear to have a noise concern, however if you could verify the machine is indeed a kenmore and possibly provide the entire model number I would be much better equipped to help without generalizing.
Initialy based on your post, it could be more debris further down in the impeller or chopper, but it really depends on the style of the machine, model number is located around the door opening ...
Good luck, I find this link to be quiet helpful on the majority of Whirlpool/Kenmore/Kitchenaid style dishwashwers.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
I'll watch for your reply and try and help going forward. Thank you.
Regards,
Macmarkus :)
Jul 19, 2011 | Kenmore Dishwashers
F 02 Error code, took apart and found 2 small
WHAT DID YOU TAKE APART AND FIND THE NAILS? WAS IT THE PUMP? SOME MORE NAILS MIGHT HAVE GOTTEN BACK IN THE PUMP OR THE PUMP IS DAMAGED.
Feb 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dryer takes three cycles to dry took apart need help put back together
Model #?
If this is a standard dryer with the idler pulley, place the pulley into the slots to the left of the motor pulley. Bring the belt through the idler so it is running on the flat side of the belt and place the belt around the motor. The idler should be placing down pressure on the belt keeping it tight. make sure there are no twists all the way around the drum or it will pop off.
Eric
May 28, 2009 | Kenmore Dryers
Kenmore elite dishwasher making loud buzzing sound when washing
I had the same problem with by Kemore Ultrawash after two years. The motor bearing went bad because the seal went out and dish water got to the bearing. If you are handy, this motor comes out after taking the dishwasher out. I was surprised how easily the motor came apart from the dishwasher, a good design. The motor has three screws that holds it together, I took them out and took the motor apart.
I took the old beaing off the shaft with a grinder, careful not to groove the motor shaft. I did, but just put some high temp silicone caulk in the groove before I put the new bearing on the shaft. I bought a new bearing on the internet, it is a 22mm x 8mm x 7mm. I bought one that went in a small engine, a quality one. I placed it on the shaft, put the motor back together and put the dishwasher back together. It has run quiet and great for many weeks now. I expect the dishwasher may last many years now, because the bearing I took out was a cheap aftermarket one, and the new one is vastly superior in quality.
Good luck and fire away with any questions. I love this dishwasher and am glad I could fix it for 19$ and some of my time.
Oct 08, 2008 | Jenn-Air JDB6510 Built-in Dishwasher
Dishwasher will not drain
We took it all the way apart and cleaned it really well in the bottom of the dishwasher. Then we put it back together. Then we removed the hose from the disposal and suctioned it with the wet/dry vac to remove any clogs, then put that back together.
Ran dishwasher with Tang in both powder cups to clean it, and it's running fine now.
Apr 20, 2008 | Dishwashers
Dishwasher pump not working
Jan 30, 2008 | Dishwashers
Kenmore 41729042990 Front loading washing machine
you can take the pump apart by removing the 3 screws that hold it together. take it apart to make sure there nothing in it that could be blocking the impellar. if theres nothing in there, replace the pump
Nov 26, 2007 | Kenmore 44042 Front Load Washer
Dishwashers Logo
98 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
