Question about Samsung WF337AA Front Load Washer
My samsung washer model no.p801,is showing error code e8?
My samsung frontwasher model no.p801,is showing error code e8.What's does mean?Thanks
SOURCE: Samsung P801.washer....Error Message " ED" WHY??
"ED" is a door open error. try Closing the door properly or else there might be jam at the door.
Posted on Dec 12, 2008
  • 4 Answers
SOURCE: When my Samsung Sensor Quick P801 800 washing
The machine can't balance the weight of the cloths.
Posted on Dec 18, 2009
  • 3 Answers
SOURCE: I have a samsung sensor
I had the same problem. I ended up paying $300 ($100 part $200 labour) for an authorized technician to replace the control board and that fixed the problem.
Posted on Sep 22, 2010
  • 330 Answers
SOURCE: I have a samsung p801 the washer will begin to
E1 error is motor fault you have to get the motor replaced
Posted on Jan 05, 2011
  • 1554 Answers
SOURCE: I have a e4 error
The error code E4 means no water entering the tub is detected because the pressure switch is not tripped. These could mean no water is running through the pipe line, the water inlet valves are not working, the pressure hose is pinched/detached, or the pressure switch itself is stuck in the empty position.
Verify first if there's any water that has entered the tub. If none, check the water pressure and if it's good replace the water valves. If there's water in the tub, remove the top panel by removing the attaching screws at the rear of the machine then slide the panel backwards and off. Look for the pressure switch with a small clear hose attached to it inside the cabinet. Make sure the hose is attached properly to the pressure switch and the bottom of tub. Check the hose for air leaks or holes by blowing air into the hose. Also blow air forcefully into the pressure switch to free any stuck or bonded contacts. Replace the hose if necessary or the pressure switch if no issue is found with the pressure hose.
Let us know if you need further advice. Please accept the solution should you find it helpful or informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Mar 06, 2011
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ... > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Why is my machine not spinning
Well, it would help to know the make and model... on a Samsung the E8 code means the water hoses are connected to the wrong taps (i.e. the hot hose is hooked to the cold tap and vice-versa).
If it's not a Samsung, please provide more info.
Mar 08, 2015 | Washing Machines
I have A samsung washer p801 and the washer wont close it keeps telling me Ed and i tried turning off the machine and closing the door and turning off the machine when i open it but the door just wont lock...
ED is a door not closed error code. The lock may be on and the machine will need to be reset. To do this either leave the machine unplugged for 24 hours or see if there is a reset option on the machine. If you need an owners manual, I can probably locate one for you .
Jun 05, 2012 | Samsung Washing Machines
Washer not spinning correctly
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 04, 2009 | Washing Machines
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Samsung WF337AA Front Load Washer Logo
67 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
