Question about Apex Digital AT2014DV 20 in. TV/DVD Combo
Remote won't work
I was using my remote controller in the morning and it worked fine then, but then in the afternoon it just stopped working, the batteries are ok, I even put in new ones just to be sure. The transmit light on the remote turns red whenever I push a button, and the lens on the tv is clean too. There was never any problem with changing channels to show possible dying batteries, when I tried to use it in the afternoon it just wouldn't work. I used both of the blue button settings (TV and DVD) when I was trying to change channels. Unplugging and replugging the TV didn't work. AndI can't flip through chapters while I'm watching DVD's either. Thanks for at least taking the time to read this, and thanks more if you helped.
  • 14 more comments
  • obadiah Nov 23, 2007
    Tv response to remote control just quit. I have inserted new batteries. I even tried a universal remote control. No response.
    I cleaned the lens on the front of the tv. Still no response.
    Help
    Thanks
    Lee
  • lost in Ohio Dec 10, 2007
    Earlier this year my remote stopped working for no reason. Did the usual - checked batteries and uplugged it for a few minutes. No difference. Took it to an authorized repair palce and they soldered the infrared connection. Worked fine until today, Dec. 7. Same deal. Tv hasn't been moved at all during this time. It cost $100 to have the soldering done the first time. Any suggestions? Will call the repair place to see if they guarantee their work, but that means getting a van and lugging the tv about 40 miles each way. HELP!
    vickimsu@hotmail.com
  • LTtjn Dec 13, 2007
    only some of remotes functions work, I tried programing a universal and got the volume and the tv to shut of but no channel changing
  • kaukerman Dec 21, 2007
    I have the same issue, tried turning everything on and off, the set works fine manually just not with remote. Bought a new factory direct remote of the same kind for this model, worked for 1/2 day then stopped working leading me to believe must be in the sensor, but can you even get replacement sensors for these? MW20FM1/MW24FM1
  • 0308 Dec 30, 2007
    TV works fine. Remote won't work. Changed batteries and unplugged TV. Infrared light out on TV. How do you repair or replace infrared light?
  • avidskiier Jan 03, 2008
    Same problem. My remote was working one moment and then wasn't working the next. My digital camera shows that the remote is sending out a signal. I tried a universal remote with no success. Changed batteries, unplugged TV, cleaned lenses.
  • JGuid Feb 19, 2008
    What is the code to put in a universal remote for the symphonic SC13D?
  • shellyapt103 Mar 08, 2008
    remote wont work for some reason. tv works great manually
  • Anonymous Mar 22, 2008
    After 5 years, the remote stopped working.
    I replaced batteries, it still didn't work - at all.
    The TV that always worked great now makes me work.
  • Anonymous Mar 23, 2008
    Tried the following, it's the TV:
    Tried fresh batteries in the remote.
    Opened the remote to check for cracks and bad solder joints, none found.
    Tried remote on another Toshiba TV, worked there.
    Tried remote from another Toshiba TV that my remote operated, MVI3M3 still doesn't respond.
    Tried universal remote on my MVI3M3 using the code search function.
  • Anonymous Apr 02, 2008
    The remote for the projector has power, but I am unable to use the remote to change the slide for a PowerPoint presentation. I had to use the mouse to change from slide to slide.
  • angeljo Jun 02, 2008
    same problem with the remote. tried all the possibilities to solve the problem. got any advise other than to buy a new tv?
    thanks
    Jo
  • kklott Jun 12, 2008
    I am having the same problem, replaced batteries, bought new factory remote. If I need to replace the remote sensor in the TV, does anyone have the Toshiba part number for the replacement?
    Thanks,
    KLott
  • Anonymous Aug 18, 2008
    Same problem, it used to work off and on , but now not at all, I know the remote works, but the tv will not respond to it. TV is a Symphonic 13in.
  • Anonymous Nov 29, 2008
    I dropped my remote and I think it's broken. It worked before I dropped it. Can i buy a new one, and where? What code do I use for a Universal remote?
  • samcassie14 Apr 05, 2009
    iam home alone and my dad will be so mad but i didnt do any thing my remote is brooke it was being fine tyhen i tried to change the channel and well it didnt work please help me!
I would try 'waking up' the remote-Take the batteries out,press each button once then put the batteries back in.See if that works.
Posted on Dec 31, 2006
I HAVE THE SAME PROBLEM MY SYLVANNIA TV/VCR REMOTE STOPPED WORKING AND NO UNIVERSAL REMOTE WILL WORK ON IT ?????
Posted on Mar 14, 2008
    New Friend:
  • 163 Answers
Could be anything but give you a tip any way.. I use my celular camera to see if the remote bean is lighting and blinking (thast the white one in the front) if not the remote control is the problem. open the unit and observe for broquen parts or broken solders.....good luck...
Posted on Jul 24, 2006
Open up the remote carefully. Look for any dark areas of the circuit board where burning may have occurred. Get a stick of gum and using the foil, cover the circuit board, this should temporarily fix the remote but I'd suggest contacting your tv's company for a replacement.
Posted on Jan 08, 2008
I gave the same television/DVD combo to my mom for Christmas and she had the same problem. She found that the remote was EXTREMELY light sensitive. She lowered the wattage of her light bulbs to 25 over the kitchen table and kept the remote in the cabinet when not in use. This may sound ridiculous but it actually worked for her. I came on this site looking for a better answer to her problem and saw yours. Maybe it will help.
Posted on Mar 08, 2007
I have depressed a wrong key or something as I was getting everything. I can only get local stations, lost my cable. What should I do
Ruth
Posted on Jul 25, 2008
Ruth
I bought a new remote from Toshiba. Checked it with my digital camera it was working fine. I ordered a receiver from Toshiba, soldered it onto the main board and it works like a new one. The receiver would only change state if I unplugged it for a while.
A new sensor is the answer.
Lee
I finally ordered a new remote sensor. I removed the old sensor and soldered in the new one. It works just fine now.
Posted on Dec 19, 2007
I have the same problem, and I did order a new remote and from toshiba and had the same problem. It must be the sensor in the tv.
Just unplug the tv for a minute, this will reset everything...
Posted on Sep 30, 2007
Provide universal remote codes
Posted on May 12, 2007
Take the batteries out and leave for 5 mins then retry. signalsuk.com
At most Canadian Best Western hotels they have room set Tv remotes and they are such pieces of ****, they just barely work the maintenance guy says they are the biggest hassles the hotels have because no matter how much the company lodgeview says that there working they won't work for anyone who works there does anyone out there know what might be happening new batteries in stalled units cleaned inside no solder joints seem or appear to be cracked
Posted on Apr 20, 2008
    President:
  • 3,130 Answers
They sell replacement remotes at 1-800-remotes or at http://www.remotes.com
4 Suggested Answers
SOURCE: unlock apex tv model # AT2702
i need to unlock my tv
Posted on Dec 05, 2008
SOURCE: locked tv
all you have todo is hit the function key and the mute key at the same time, on your remote, and the picture will return.
Posted on Dec 18, 2008
SOURCE: unlock tv
i have a shinon tv and it is locked what do i have to do please
Posted on Sep 16, 2009
All 5 ceiling fan remote sensors not working
Check that the remote is working. Do this by using a digital camera and point the sender at the lens . If it is working you will see a blue/red dot on the viewer screen. It will move when you move the remote. You cannot see the beam but the digital camera can and shows it up on the view finder.
Mar 24, 2013 | Hunter Ceiling Fan Light Remote Control
Logik remote control won't work
It sound that your remote control need serivce. In most cases, claning it will rectfy the problem. You can get more details about how to reapair,test or clean the remote control by entering this site "Electro-help". Search for it in Google.
May 02, 2012 | Televison & Video
Wii remote not working?
You got to sync the remote with your console to activate the remote
Aug 09, 2017 | Nintendo Wii Console
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 22, 2011 | LG Televison & Video
I have 2 fans 1 stopped working 1 remote
Look at the remote code on the remote which is broken, then copy the code on the fixed remote, then you can control anoher fan.
Jul 12, 2009 | Universal Remote Control Hampton Bay...
2 different openers stopped working by remote at the same time
Both the older genie and a newer chamberlain (3-4 yrs old) both run on 390Mhz frequency. sounds like you will have to change your receivers on both operators (365LM 315Mhz) then get 3 button remote so you can program both doors on one remote.
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote only closes the garage door, will not open it
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
In your case the expansion of the wall in the afternoon may be enough to cause pressure on the wire to increase the problem – works in the morning but not the afternoon.
Also after you change the batteries you need to reprogram the remotes.
HOPE THIS HELPS
Aug 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Remote won't work
reset the default setting go to menu button and manualy do this.....
Jun 19, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Remote won't work
hi, see if the right funtion is selected, tv, vcr, dvd.then if that does not help, get a universal remote. they don't cost alot or some don't good luck. hope this helps.
Apr 15, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Apex Digital AT2014DV 20 in. TV/DVD Combo Logo
21,694 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
