Question about Akai PT46DL10 46" HDTV-Ready Television
AKAI PT46DL10 Bulb replacement
I think I need to replace the bulb in my AKAI PT46DL10 TV. Heard a pop and the picture disappeared. Label on back of TV says this must be done by a service engineer. Manual says to call 1-800-726-4405 for AKAI customer service but this line is not monitored and a message says to call 323-281-0782 which is out of service.
I therefore have several questions.
1) Is there a phone number for AKAI customer support that actually works
2) Is there a someone in the Vancouver BC area (Canada) that might be able to repair the TV.
2) Is it possible to replace the bulb myself
3) If so, where can I get a suitable bulb. The serial # of the TV is 1007373PT46DL10J0.
Thanks in advance for any assistance
  • 4 more comments
  • Anonymous Dec 14, 2008
    I have the same exact situation with my 46' DLP AKAI. I heard a pop and then the screen went blank. Everything else seems to work fine (sound, ect.). I also am wondering if my TV only requires a bulb replacement, and also, if this is easy enough for me to replace myself?
  • Anonymous Dec 26, 2008
    need repacement lamp for akai pt46dl10 s/n 10005699
  • Anonymous Feb 19, 2009
    you can replace the bulb but it can be expensive.The cheapest i found was 120 dollars as for if theres a number im not sure
  • baswick Mar 03, 2009
    I gave up trying to contact AKAI but was able to order a bulb assembly from for $120 US. There apparently are two different bulb types - J & S which correspond to the letter near the end of the serial number so make sure you order the right one. I did the installation myself and it was easy enough but you need a small Torx bit screwdriver to remove the panel to get to the lamp.
  • Anonymous Mar 29, 2009
    black screen blinking green light and sound
  • ricky_star19 Apr 27, 2009
    I need to get the lamp of AKAI PT46DL10 . I been calling all of the from number the shows at the bottom of the lamp but theirs wrong sevice. I need help for get the lamp
    Problem Solver:
  • 10 Answers
Order from i did and works good now mine was type j
Posted on Apr 29, 2009
Need to find a bulb and cage for Akai pt46dl10
If your serial# has J P/N DR150E23
If it has a Z in serial# P/N L920-0017/P306
Mats Electronics 1-800-628-1118
And Go to E-Bay look under Electronics/type in Lamp number.
Feb 18, 2010 | Akai PT46DL10 46" HDTV-Ready Television
I have an akai Pt46Dl10 the picture wont come on i have sound
if this happened after you replaced the bulb its because it is the wrong bulb. there are 2 bulbs for this tv; a J and a Z (have to look at your serial number on the back of the TV in the middle. if it ends in a Z you get the Z bulb, J get a J bulb) If you haven't replaced the bulb, that could be the problem. take off the panel on the back of the TV (opposite side of the PC input) there are 6 screws, I used needle nose plyers to get them out. then after you get the back cover to the lamp off there are 2 stainless steel screws that need to be taken off the housing. Pull the housing out and check the bulb. if it is black it is no good. Make sure you put the back panel on properly again (knob on the cover facing down towards PC input) and screw it back in, or which I think that is the problem! GET THE RIGHT BULB!
Jun 11, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Good sound no picture
I have the same TV. On the back of the TV there is a square panel. Unscrew the six screws (the panel is on the opposite side of the inputs, I used needle nose plyers) after you take the panel off (make sure the tv is unplugged) you will see a black "housing" with two stainless steel screws. Unsrew those two screws and pull out the housing. there will be 4 screws to take off (uses a special tool called a T-8 TROX screwdriver and replace bulb. BE CAREFUL for this TV there is 2 different bulbs. If your serial number ends in a J you need a different bulb then if it ends in a Z (serial number is on the back of the tv in the middle) I recommend shopping as they clearly label there bulbs, plus they are cheap!
May 28, 2009 | Akai PT46DL10 46" HDTV-Ready Television
How to change out blub
panel on the back of tv, opposite side of inputs. 6 screws takes a special screwdriver. I used needle nose plyers. once in the back, unscrew 2 stainless steel screws to take out black housing. has your bulb. make sure you have the serial number off the back of your TV at the end of your serial number you will find either a Z or J. DONT GET THE WRONG BULB! taking the bulb out of the housing is different. you can either take a drill with a small bit to get the nuts out, or purchase the screwdriver called a T-8 TROX screwdriver.
Akai, PT46DL10 Has sound, no picture
make sure all componet cables are in the right color coded spots on the back or side of the tv and you are on the right componet if using a cable box make sure using componet / monster cables not all cable companies support hdmi if that is how you are trying to hook up make sure to check with them
May 14, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Tv won't turn on
I think this would be the lamp pull it out, if its bad you should be able too see the light burnt. you should be able to get to it from the front.
Jan 11, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Need to know how to change the lamp what is the procedure
theres a small square on back of tv you need a small torqz screwdriver to take off then bulb is inside theres a cage with bulb to reset lamp push menu on remote then enter 90918988
Oct 22, 2008 | Akai PT46DL10 46" HDTV-Ready Television
No picture Akai PTDLP46
It may be the ballast , I've the same problem in here in quebec, and i don't know where i can buy it. the part number is P306-0022. Normal Cost is $199.99
Apr 18, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Akai PT46DL10 46" HDTV-Ready Television Logo
1,284 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
