Question about Hoover U5507900 Elite Rewind Bagless Upright Vacuum
Burned smell hi, I have used my hoover 4 times and is starting to smell as something burned, I checked the troobleshouting part of the owner manual and it says that check the belt, I already did that and everything is ok I used the hoover again and still smelling bad and start to work very slow I better shut off it.. what could I do??
  • Anonymous Dec 19, 2008
    I have the same problem and the rotating brush on the front of the vacuum has stopped working. I suspect that something got wrapped around the brush during vacuuming and prevented it from spinning and this either burnt out the motor driving the brush or the wires which power the motor The smell has gone away now, but the brush doesn't turn. Unfortunately with this model there's no way to turn the brush off while the vacuum is running and it looks like no auto cut-out when it gets jammed. So either I take it back, repair it myself (if I can) or bin it and go and get a Dyson
  • 294 Answers
If the motor slowed down this would indicate a bad motor. not cost effective on this model to replace unless under warranty. it is not uncommon these days to see a motor go bad every now and then.
What are the first 4 digits of your serial number? this would be the month and year of mfr. even without a receipt, a warranty service shop should be able to assist you.
Posted on Jan 19, 2009
Why does my vax power 2 cylinder hoover make a noise and smell of burning rubber when I turn it on we have cleaned inside and out and all filters
That is the smell of perhaps burning insulation when there is excessive current going into motor. If something in unit is binding the motor will not spin fast enough, generate less back emf, use more current, overheat and burn out!!!!!!!!!!!
If it has a drive belt and that is rubbing up against something and not turning properly that will also cause the smell.
Do not use unit in this condition -you risk permanent damage.
Aug 31, 2015 | Hoover Vacuums
Hi, how do I check my hoover floormate deluxe spinscrub's filter and motor?
Hi Mike! To check the filter on the Floormate deluxe, remove the dirty water tank and pull up on tank lid to separate from the base. Check foam filter for debris, if filter has debris, rinse it with water. To prevent internal damage make sure you are using only the Hoover Floormate detergent. If the machine is still noisy and smells bad we recommend taking it in to a Hoover authorized service center. Follow the link to find the nearest service center to you. Hope this helps! Service Center Locator
Oct 20, 2014 | Hoover Vacuums
Hoover Dimension has no suction and it smells of something burning
pets in house? check all hose passages for "hairball" clog...and check the drivebelt that spins the brush...(some have an electric motor to spin the brush, thus no belt)
Nov 02, 2012 | Hoover Bag Paper Microfilter Dimension...
Smoke coming out!
This sounds electrical. If you have had this one year or less then it should be under warranty. find your local Hoover warranty dealer at the Hoover website hoover.com
Apr 20, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
My Hoover bagless vacuum starts to smell like something's burning
What does it smell like? If it smells like burnt anything-it could be that the fan is broken and lodged in the motor. You can see if the fan is good just by looking into it.
Mar 13, 2009 | Hoover U5753-900 WindTunnel Bagless...
Vacuum shuts off and has a burnt smell
Try removing the drivebelt, and try running it to test like this. The brush bar will not turn, but it should function normally without smell at this point. If it doesn't, you may need a new motor as I think the brushes may have worn down - producing an electrical type burning smell.
If it runs fine without the belt attatched, then there is probably a build-up of hair or threads at each end of the roller stopping it turning freely. With the hoover off, check it turns freely and easily. A small metal nail file or similar is usually a good tool to clear it.
If the roller is stiff, the belt will not turn easily, and overheat on the motor spindle - causing the burning smell.
Jan 08, 2009 | Hoover Vacuums
Hoover mach 4 burning smell
There are two reason you could be smelling a burning smell-
1. The belt is too stretched out and needs to be replaced. This causes it to slip when the vacuum is on and will create that type smell. You can avoid stretching and having to replace the belt to often by releasing the belt after each vacuum.
2. There may be hair or other debris stuck around the rod that the belt is attached to. Can be avoided by checking after vacuuming.
Hope this helps
Nov 12, 2008 | Hoover Vacuums
Rubber smell, Hoover
Well it sound like you do need a new belt because of how the smell is you might want to stop using it because the smell comes from the burning and over heated belt my solution would be to get a new belt and that should fix it if you need anything else you know whre to find me.
Jun 30, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuum cleaner smell
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40540&thid=528723
Posted by lcw1 on Apr 20, 2008
Our Hoover Windtunnel has recently started emitting a bad odor when we use it. We recently bought a new house, and the previous owners had dogs, but the carpet was professionally cleaned before we moved in. I have replaced all of the filters and belts to no avail. At this point, I have to remove and rinse off all of the filters after every time I use the vacuum to prevent stinking up the entire house. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U6616-900 Windtunnel Bagless Upright
I think you are right, if it is not the switch then it would be the motor. Does it smell bad like a burning smell? If so it is definitely the motor and then @ that point you may want to get an estimate for motor replacement, and keep in mind of what you spent on the vacuum versus what the cost of repair might be. My own rule of thumb is if it cost more than ½ of the price I paid for it then you have to decide – do I want to pay the repaired cost for the vacuum or do I want to purchase a new one. Just a suggestion... You may want to check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Apr 20, 2008 | Hoover U6616-900 WindTunnel Bagless...
Hoover empower
Don't ignore your instincts. If you think it smells like a scorching belt, you're probably right. Check that the pulley the belt is meant to spin is free to turn. If it isn't, find out why and then sort that out. A.
Feb 24, 2007 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Hoover U5507900 Elite  Rewind  Bagless Upright Vacuum Logo
320 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
