Question about Maytag Neptune MAH5500B Front Load Washer
Will not spin
Unit washes normal, gets down to 8 minutes on timer, unit keeps draining and then turning 1 or twice before repeating draining never goes into spin, timer keeps going back and forth between 8 and 7 minutes. thanks
vickijodon@comcast.net
  • northneil Oct 24, 2008
    I have this problem as well
Yes i have had the same problem, many times, my son forgets to check his pockets and coins get caught in the pump... after the third time i had a service tech out to my house i asked him to show me how to fix it and he did... you have to take the pump off and look for anything stuck inside the pump, i just had to do this again yesterday... the tech told me he has 12 calls a day for this exact thing.. kinda of a bad design..... ya think.
Posted on Oct 28, 2008
We have had the same problem and the dealer has come out twice to reprogram the computer. I have not been there, but evidently they can do this with the buttons on the front. They seem to clear the codes like a PCM on a car. The first time it worked for another week and did the same thing. Perhaps they do not know about these causes of the problems or it is another flaw in the design of this over priced piece of ****. If I had the codes I could clear it myself and finish washig the clothes. This usually happens on a weekend when we have time to do the wash.
Posted on Oct 27, 2008
How do you check all of these
Posted on Oct 26, 2008
  • 725 Answers
First I would check the hose screens are clean .and check that you have enough water going the machine it will time out ant the forced rinse and not spin... next check if the drain pump is removing all the water.. if not check it , make sure it is clear . next check that the door lock light is on... if not you have a door lock problem... if all are OK then we can check the control and motor control.
  • Franklin Ouchida
    Franklin Ouchida Oct 27, 2008
    1} unscrew the hoses check the screen inside the water valve.
    2} open the soap dispencer and watch how much water flows if it take 6 min or more for the water to stop then it take too long to fill..
    3) if the washer still has water in it after the door unlock... you have a drain problem...
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
Hello, My Kenmore, Model 110 92582110, stock#25821 will wash but it does not spin or drain. However, If I turn the timer and keep putting in spin mode, eventually it will spin and drain out the water....
By advancing the timer wheel to spin, you are able to get the machine to do what you require, however, the timer itself may need replacement if it does not proceed thru the cycles by itself..It sounds like your timer is 86.
Jan 18, 2015 | Washing Machines
Washer stops during normal wash cycle for a minute or more, and then continues. Would replacing the timer fix it?
If it actually goes on and finishes the cycle and that really bothers you replace it. If not leave it alone and allow a little more time to complete its cycle. The lid switch only keeps the spin cycle from going with the top open.
May 23, 2014 | Whirlpool Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Gets stuck on timer and wont count down
We had a similar situation with our LG washer. It was not a timer problem.
The machine was not entering the spin cycle and was just stuck in limbo. A sensor or something was not being satisfied and allowing the progression to the next cycle. Our problem had to do with the drain line; it seemed as if it was air locked?? After lowering the drain line height (to reduce the head pressure), and manually draining some water out of the drainage cap (where the strainer is located) onto the floor, the sensor became satisfied and the machine completed its cycles properly.
What told me that it was not a timer issue was the fact that on different wash settings (normal, heavy, quick cycle), the machine timer would get stuck at different countdown points (22mins, 12mins, etc.).
Jan 17, 2009 | Washing Machines
Plastic in drum
REMEMBER IN 4- 6 -8 MINUTES IS YOUR DRAIN AND SPIN CYCLE, PLZ INSPECT PUMP,,, AND SUMP THAT WILL RESOLVE YOUR PROBLEM
Nov 25, 2008 | Kenmore Elite 45986 Front Load Washer
Please help
it is the timer or, it may be a short of some kind
Apr 19, 2008 | GE WDSR2080D Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
