Whirlpool duet ghw9300 fabric softener dispenser not emptying
At the end of the wash cycle the fabric softener dispenser is not totally emptied and it is still full of water. This has been going on for several washings. I have removed the dispenser drawer several times and flushed all openings with hot water to be sure nothing clogged. What next?
  • 3 more comments
  • Anonymous Jan 01, 2009
    Same problem
  • tjohnson85 Jan 31, 2009
    I have had the same problem for some time, and now the detergent is not getting washed out either.
  • meznok Feb 21, 2009
    i have same problem. not even sure how it is supposed to work. may go to sears service and ask them about it.
  • kasedelia Mar 08, 2009
    Same - fabric softener compartment is full of water at the end of the wash cycle. If I soak up the water with a washcloth some of the water drains into the washer.
  • bearcasa Mar 19, 2009
    Same thing here- I wondered if it only happened on certain cycles- but it seems to happen every time. Glad to hear I'm not the only one-- but would love to hear a solution!
SOURCE: Fabric softener compartment problem.
Squeee, It's been more than a year since you posted this so I guess you must know the answer. It sounds like a Visit from an engineer(?) I've got exactly the same problem with a Servis Easilogic 1500 and would appreciate knowing what you had to do to resolve the issue.
Posted on Jul 05, 2007
SOURCE: Water in detergent dispenser
Remove dispencer again, remove conditioner syphon assembly and clean up the little tube. Should then go okay
Posted on Jul 11, 2007
Buffalo12980
  • 625 Answers
SOURCE: Fabric Softner won't dispense
fabric softener goes into the dispenser. it may be a full blown solenoid valve -or- a flapper type of solenoid valve. operation of the solenoid operates a flapper to let the softener out. go to an appliance repair site to find the solenoid - appliance parts dot com or repair clinic dot com.
Posted on Sep 05, 2007
  • 213 Answers
SOURCE: Problems with fabric softener
you either have low cold water pressure being caused by the screens on both ends of the cold waterline being clogged by sediment or one of the solinoids for the water inlet is bad. try removing cold water hose and cleaning both screens if that doesnt help youll need a solinoid
Posted on Nov 20, 2007
  • 4 Answers
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Posted on Dec 12, 2007
The fabric softener drawer does not empty after a washing cycle so how do I solve this
It is normal for some water to remain in the fabric softener dispenser after the wash cycle is complete
Jan 10, 2013 | Washing Machines
Whirlpool duet washer fabric softener dispenser does not empty
Hi there
I wonder why, mine does though I never use a fabric softener, the water just runs through. It must be clogged somewhere, the only solution I have is the old one. The needle and the thread,try puting a needle through then pull the thread back and forth.
I hope it works
kolbrun
Mar 24, 2012 | Whirlpool GHW9150 Duet Washer
Whirlpool Duet Washing Machine
its normal for this to occour, atvery least nothing to worry about, the unit "floods" the compartment to release the fabric softener, and uses a syphoning action to empty chamber, regardles sof usingor not waterenters the chamber, and depending on level determines if it empties or not
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fabric Softener dispenser
thats quite normal, espessially if you do not use the fabric softener, the compartment empties through an overflow siphon action, so if there eis nothing in the compartment the area is flooded but cannot cause siphon action, not an issue at all
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet empties soap, bleach and fabbice softener as soon
soaps goes right in normal, bleach and fabric softer you can't go past max line line it will dispense."less soap plz"
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Rinse cycle
di you try to remove the drawer completely and check for a blockage under he dispenser itself.(sometimes te fabric softener can get kinda gunky.. if you extend the dispenser you see a little black tab in top left corner, push it down and dispenser will release, just in case you didnt know that
Mar 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Feb 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
844 people viewed this question
Top Washing Machines Experts
