Question about Polaroid FLM-3232 Television
Polaroid LCD TV FLM-3232 turns on, then turns off
My Polaroid LCD TV FLM-3232 completely stopped working without any warning. When you plug it in, the LED is red. When you push the power button, the LED turns blue for a few seconds, then turns back to red.
I saw the capacitor post by Stev0 but after inspecting all three caps (and physically tested) the capacitors are all fine. I actually have all new caps installed and it still does the same thing.
I have read countless horror stories of other consumers and Polaroid LCD TVs and now I feel their frustrations! I have had the TV for about 16 months.
  • 4 more comments
  • D C Oct 21, 2008
    The factory warranty was only for 12 months. I have had the TV roughly 16 months now. I did not purchase any extended warranties.
  • D C Oct 22, 2008
    I have not checked for a blown fuse as I could not locate one. Connection from the power supply to the main circuit-board is snug.
  • D C Oct 22, 2008
    Reposting my problem.
  • D C Oct 22, 2008
    In reply to:
    Most likely your TV needs Back Light Inverter board to work again. Its available at Shop Jimmy.
    You can get Poaroid LCD TV parts on very low prices there.
    Good Luck.
    Thanks for your reply. I have replaced several Back Light Inverter boards. This does not seem to be the case. Usually, when the TV boots up, it takes a few seconds, then the TV Brand Logo shows up for second, then my image comes up. Right now, it does not stay on long enough to display that start-up logo. It turns off within 2 seconds.
  • D C Oct 22, 2008
    Thanks for your solution cbinny1. However, I believe I voided the warranty (well, if I had one) when I replaced the 3 capacitors I mentioned. When I get home tonight, I'm going to look more closely at the other boards and connections. I did find info on someone on Craigslist/Jacksonville FL, that actually knows what the problem is and will do the repair for $100.00. Problem is, I don't live in Jacksonville. I e-mailed them and asked what they'd charge for providing me the solution but haven't heard back from them.
  • D C Mar 30, 2009
    Thanks for all the suggestions. I got rid of the TV so no need to answer the problem any longer. Thanks again!!
    Genius:
  • 1,550 Answers
Did you check the fuse ?
There is chance for loose connection .
Did you check the connection from power supply to circuit board ?
Posted on Oct 21, 2008
  • SAM ANDERSON Oct 22, 2008
    I think you might have damaged the ICs when replacing the capacitors because when an IC takes a direct "hit" from a static discharge, the dielectric
    will get burn holes completely through the layers and that will render
    the IC useless. It's easy to look at the capacitors and see that
    they're bad, but it is difficult to see damage to IC
  • Polaroid Master
  • 19,396 Answers
When you have no raster, led is red, and the led turns from red to blue on Polaroid LCDs, that means that there can be a faulty inverter, or a faulty or misplaced connector to LCD, or a bad LCD display, or a bad ccomponent in control box.
Unless you have a strong experience in servicing electronics, I suggest purchasing an extended guaranty and having it fixed by a technician. In that case you
If you know how to repair electronics I can guide you, that will require testing components and probably replacing them, using the solder on your TV main PCB.
Easy things that you can check are :
  • LCD connector (LVDS cable), try unplugging an plugging it back.
  • Test the inverter board, see if you get 24V power out to LCD panel. If faulty replace it.
  • If you do not find any other problem, then test the control box
Less easy to test :
D-sub 37pin board, this is the board that manage I/O connections it connects to the inverter, to speakers and to the control box.
Here is the troubleshooting diagram for your situation:
Antd this is the LVDS cable connectorPolaroid LCD TV FLM-3232 turns on, then turns off - 018d301.jpgalso need to check:
HePolaroid LCD TV FLM-3232 turns on, then turns off - 2178ca2.jpgD-sub 37 pin diagram:
Here is also the service manual.
Where you find disassemblege procedure, and more detailed schematics and diagrams.
Let me know if you require further help.
If you are satisfied, do not forget to accept the solution.
Many thanks.
Posted on Oct 22, 2008
    Guru:
  • 859 Answers
BeSafe, If you can hold on a bit longer. Some our other board geniuses will be online later. They are in other English speaking countries and some are very very good at knowing just which IC chip and supporting parts on the boards.
No need to rate this reply its not a contribution to solving your problem. I'd just encourage you to keep your premium question open until 7am GMT tomorrow. There's one tech in Australia I'm thinking of in particular and unfortunately another in Trinidad but he's tied up by activity in his business right now for a few more days. We all are in fact as this is a busy time of the year.
Worldvet
    Genius:
  • 1,011 Answers
This model TV is known for having issues with failed power supplies. The only way to know for sure which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. If you feel capable of repairing the TV yourself, you may want to try and replace and capacitor in the TV that is bulging or leaking. Click here for some information that will aid in the capacitor replacement. This will likely correct the problem but the only way to know for sure which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment
thanks
good luck
    Scholar:
  • 64 Answers
It sounds like you have tried everything I have been able to find on the web......Have you Registered your TV with Polaroid yet? Because if you haven?t you can make up the few months your past on the warrantee.....I would go and Register and then call on the warrantee.....it?s a bit fishy but it works...In my opinion they should just warrantee it for you. (being so close to the end an all) ....I have had great success when I have call the manufactory directly to see what they can do for me......don?t talk to just any one ask for the manager of customer service or the manager in the warrantee department...in the very begging of your call.... here is there information if you didn?t have it already Regional Headquarters: Polaroid Corporation Corporate Headquarters 300 Baker Avenue Concord, MA 01742-2131 Phone: +1 781-386-2000 Good Luck and be assertive but not an *** on the phone.......I find that when I?m just strait up honest with them it all works out....If it doesn?t try the Registration thing?Let me know if this helped cbinny1
  • 10,594 Answers
Good Luck.
  • Shahid Electronics
    Shahid Electronics Oct 22, 2008
    That's why back light inverter is suspected because it doesn't work and system control shuts down TV in 2 seconds.
    Have you tested back light or you get any flash on screen?
    Master:
  • 538 Answers
Well..yes..that is true...any chance it under warranty?
FLM-3232 Screen Shattered
ky9c1le,
I have a flm3232 with a dead supply (I think). Maybe we could strike up a deal. Contact me at rking43040@gmail.com.
Jul 28, 2009 | Polaroid FLM-3232 Television
Tip
Polaroid FLM-3232 Service Manual Download
Download Polaroid FLM-3232 LCD HDTV Service Manual
Models: FLM-2632 / FLM-2632M / FLM-2634B / FLM-3232 / FLM-3232M
Models: FLM-323B / FLM-3234B / FLM-3732 / FLM-3732M / FLM-373B
Models: FLM-3734B / FLX-374
Have you misplaced your Polaroid FLM-3232 LCD HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3232 LCD HDTV Service Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Polaroid FLM-3232 Manual Download
on May 01, 2010 | Televison & Video
Tip
Download Polaroid FLM-3232 LCD HDTV Manual
Have you misplaced your Polaroid FLM-3232 LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3232 LCD HDTV Users Guide?
Follow this link
I hope that helps.
_____________________________________________
Tip
I hope that helps.
on May 01, 2010 | Polaroid FLM-3232 Television
Tip
Follow this link
I hope that helps.
Universal remote code for a Polaroid LCD TV
I may be able to help with your Universal remote and your Polaroid LCD HDTV.
You can find some Polaroid HDTV Remote Codes here.
I hope that helps.
Feb 26, 2009 | Polaroid FLM-3232 Television
I need a universal remote code for a Polaroid LCD TV FLA-3232B
I may be able to help with your Tevion Universal remote and your Polaroid LCD HDTV.
I hope that helps.
Feb 26, 2009 | Philips 32PFL7332D 32 in. LCD HDTV
HD cable question
i have the same LCD and my problem was the same as you, you need a powerful antena like a out dor antena or indor antena whit buster
Dec 03, 2007 | Polaroid FLM-3232 Television
Polaroid FLM-3232 Television Logo
920 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
