Question about Nokia E71 Smartphone
Nokia pc suite
I'm working with BT and from some reason the nokia pc suite is seeing the device but saying that is not authorize.
How can i authorize the device?
  • Yoav Shilon
    Yoav Shilon Nov 11, 2008
    I'm running winXP and I'm the admin
  • Yoav Shilon
    The phone is paired with the laptop (including approved pass key)
  • 94 Answers
Uninstall every BT software you have and any Nokia PC Suite software you have. Plug in your BT phone dongle and let windows auto recognize the device. after it is done installing, then put in the Nokia cd. Do it in this order.
Posted on Nov 11, 2008
    President:
  • 2,712 Answers
On your E71, go to Setting Screen > Paired Devices screen > highlight the Computer you just paired with > press Options > select Set as Authorized and Yes. You will then see a padlock icon beside the paired device - this device will no longer require manual authorization for connections to the E71.
    Sergeant:
    Novelist:
  • 196 Answers
• If you use the passcode generated by Get Connected, enter the passcode on the phone when requested. Alternatively, you can create your own passcode (1-16 characters, numeric) and enter the same passcode first on the PC and then on the phone when requested. This passcode is used only once and you do not need to memorize it. • You need to authorize the connection between your Nokia phone and your PC. Select Yes when you see a connection request on the phone’s display. • You can set your PC as authorized, which means that individual connections between your phone and your PC do not need a separate authorization. On your phone, find the Paired devices view, select your PC, and edit the PC to be authorized or trusted, depending on the term used in your phone.
You can see the connection status between your phone and the PC at the bottom of the Nokia PC Suite main window: Connected Disconnected Connected but the phone is in an incorrect USB mode for Nokia PC Suite.
  • 1,879 Answers
Unpair the phone from the computer then use Nokia PC Suite - Manage Phone Connection
    Genius:
  • 1,011 Answers
Dear Sir/Madam, Pairing devices for Bluetooth connection To use Bluetooth as the connection type, you need to pair your phone and the PC. Pairing means that you code two Bluetooth devices to communicate so they can exchange data. You only need to pair the devices once, before you use the connection for the first time. Follow the pairing instructions in Get Connected and note: ? If you use the passcode generated by Get Connected, enter the passcode on the phone when requested. Alternatively, you can create your own passcode (1-16 characters, numeric) and enter the same passcode first on the PC and then on the phone when requested. This passcode is used only once and you do not need to memorize it. ? You need to authorize the connection between your Nokia phone and your PC. Select Yes when you see a connection request on the phone?s display. ? You can set your PC as authorized, which means that individual connections between your phone and your PC do not need a separate authorization. On your phone, find the Paired devices view, select your PC, and edit the PC to be authorized or trusted, depending on the term used in your phone. Thanks Good Luck
    Genius:
  • 3,422 Answers
HI,
  • Nokia Master
  • 13,433 Answers
Have you paired the phone with your computer? passkey enabled and set correctly?
  • Nokia Master
  • 19,396 Answers
If you are using Vista, ensure that the account you are using has administrator privileges.
Try also reinstalling PC suite.
How can i connect my bluetooth to my pc?
on pc side
1. give your host bt name
2. find bt COM port
My Computer->My Bluetooth Places->right click my device->Local Services->Bluetooth Serial Port
on phone side
1. give your phone bt name
then install pc suite and modem tool (if necessary)
restart computer
pairing
1. add device
host: go to My Bluetooth Places->Add new connection
phone: go to bluetooth, choose Paired Devices->add
2. provide passkey (4-digit, 0-9 only) on both
Check mRouter
check bt COM port that you found
Start bt serial
if you see mRouter turns green and blue, you got it
start pc suite
Oct 19, 2009 | Nokia 5000 Cellular Phone
My laptop does not recognize my n97 when connected via usb
Have had many similar issue with Nokia phones & PC Suite connections - works fine then stops - in add remove programs there is an entry called PC Connectivty Solution - it does not say Nokia unless you go change then it says Nokia - remove this, the Nokia suite & Nokia Connectivity Cable Driver - restart PC, switch off phone, remove battery, switch on, reinstall and it should work.
Good luck.
Oct 14, 2009 | Nokia N97 Cell Phone
How to connect cell phone with pc by bluetooth driver& where to download bluetooth driver for vista
friend, you dont need to download the driver from anywhere. tha CD that came with the phone contains Nokia PCSuite, which has all the drivers. If you dont have the CD then go to Nokia site of your country and download the PCSuite for your phone, ie, N72. Install the Suite. and start it. activate the BT on your phone. and search for all BT devices to get your PC as well. Pair with the PC. Both will ask for code. Give the same code at both the places. And you are thru.
Sep 07, 2009 | Nokia N72 Cellular Phone
Didnt connect bluetooth headset to N73
Sometimes what happens is that we keep looking for BT devices without making them visible. Is it so in your case too? Go to settings of the headset and make it visible and your mobile visible to the headset. then you must pair them and also authorize them to connect without pass code etc. Then they will work.
Aug 02, 2009 | Nokia N73 Cellular Phone
Nokia 6233 GPRS connctivity through USB blue tooth dongle and Nokia PC suite
There is some problem in your Bluetooth device driver. Try to uninstall it and restart your Pc then reinstall it.
Oct 05, 2008 | Nokia 6233 Cellular Phone
Compaq nX 7400 Bluetooth device not detected by the system and modem drivers not detected
you gotta love vista..did you check nokia's site for the vista 64 bit driver? If you find it post it here, and we'll let the world know about it
Mar 21, 2008 | Computers & Internet
Bluetooth on but not identified - dell latitude d630
First of all search device from your nokia phone near to your lap-top. If its found your lap, then you have to checkout your lap BT settings.
Other wise go to Device Manager and Uninstall your BT brivers.
After that make reboot then install driver for your lap BT.
You can download the driver for your lap BT from the following link or any where else.:
http://www.wireless-driver.com/download/bluetooth/dell/Dell-Wireless-360-Module-with-Bluetooth-20-EDR-Driver-Download.htm
Thanks.
iqbal_delphidev@yahoo.com
Mar 05, 2008 | Dell Latitude D600 Notebook
Nokia 3230 USB bot working
try to download nokia 3230 pc suite again, but first delete the one that you have on your computer completely before installing the new one
Aug 14, 2007 | Nokia 3230 Cellular Phone
Nokia E71 Smartphone Logo
559 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
