Question about HP LaserJet 1100 Printer
NOT PRINTING CORRECTLY
WHEN I PRINT ANYTHING, I HAVE TOW WHITE STRIPES DOWN THE COPY WHERE IT FAILS TO PRINT. DOES THIS MEAN I NEED INK OR WHAT?
Try shaking your cartridge to distribute the toner in the drum. That should help.
Posted on Jan 22, 2007
How to solve streaks in printout
If you have tried running the "eliminate light stripes" process in the troubleshoot print quality without success, you may want to look at the print quality sheet and do "jet substitution" on the ink nozzle numbers that aren't printing out. That will slightly slow down the printing, but will eliminate white streaks down your prints.
May 04, 2014 | Xerox Office Equipment & Supplies
Brown background instead of white
You are probably out of ink in one or more cartridges. You need to do a diagnostic print and take the print to the ink supply vendor to get the correct replacements.
Oct 03, 2012 | Kodak Office Hero 6.1 All-in-One WiFi...
Just printed a photo using the ip4700 & it has come out red/orange/white. Does this mean I need new ink cartridges already as I've printed about 50 photos to date since I purchased the printer new....
you may try to replace your ink cartridge for a quick solution, if it still fails to print correctly, your print head nozzles may have dried up and clogged.
Feb 09, 2011 | Canon iP4700 InkJet Photo Printer
Roland SP 540v with Eco Sol Max ink. ... When printing large solid colors, especially blues and light blues, there seems to be an ink supply weakness that shows up in soft-edged stripes in the direction of...
Inhae had similar issues, I corrected it by slowing down the print rate to 250mm per sec and also doing a calibration to the messy used if all else failed calibration wise I used textile heat transfer profile for printing on both banner and vinyl hope this helps
Sep 21, 2010 | Office Equipment & Supplies
White line
White lines are generally caused by clogged print nozzles. I assume that you have a printer with the print heads built into the cartridge. Are you using high quality cartridges or cheap refills? If cheap refills, try a better/different brand of cartridges and see if that helps. I would also check the printer manufacturers website and try their recommended printer nozzle cleaning procedure.
Jun 03, 2009 | HP LaserJet 3055 All-In-One Printer
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Apr 28, 2009 | Office Equipment & Supplies
Printing when ink is low
The machine requires all color in order to print anything, even just black and white copies. You need to install a new cyan ink before it will print.
Feb 10, 2009 | Brother MultiFunction Center MFC-440CN...
Why does minolta copier print white stripes?
TRY TO CLEAN AND CHECK MAIN CHARGER AND TRANSFER CORONA FOR VOLTAGE LEAKAGE,AND CHECK DEVELOPER GEAR AND DEVELOPER DRIVE GEAR
Dec 03, 2008 | Minolta EP1030/1030F CS/PRO Copier
Printing problem
The black cartridge printhead needs to be cleaned or replaced. Follow your printer manual instructions.
Mar 18, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP LaserJet 1100 Printer Logo
73 people viewed this question
Clive
Clive
