Related Tags:
This problem should be removed because:
Problem with RIM BlackBerry Curve 8520 Smartphone
blackberry curve wont switch on
my battery power went last night and phone switched its self off and now i have been charging it for about 2 hours and still wont swich on> not even sure its charging.
Suggested Solution (2)
Hi, application errors are usually Virus infected error, You can try and use this reset steps, but it does not work on all black berries.
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Feel free to pass on your comment..
Thanks for using fixya...
Source: my blackberry 8520 curve gives
Is your phone on a contract? If it is call the service provider and ask them to block your sim card.
Source: my blackberry curve model 8520
my google g1 randomly shut off
my google g1 randomly shut off in the middle of the night last night. I think the battery died, however it was fully charged right before i...
iphone not starting
I was downloading face book software through i tunes but suddenly my phone went blank and then it started showing a person standing with his...
Tuesday I dropped my Motorola Rival in to a thing
Tuesday I dropped my Motorola Rival in to a thing of water on my phone, it was in it's case. I took the back off and the battery out and...
HI...Last night I forgot to
HI...Last night I forgot to charge my Alias 2, so it has been on the charger for about an hour now, and I went to turn it on, but it wont...
uncaught exception 11>=11 bb
uncaught exception 11>=11 bb storm
Tips for Helping sarah turner With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
keyboard works but screen is black on blackberry
well i turn my phone on and they key board lights upbut the bar to show how long left its got to turn on doesnt show its...
my bb curve 8520turn white screen
my blackberry curve 8520 turn at white screen help plz
bonjour mes amis ofait j'ai un probleme avec...
bonjour mes amis ofait j'ai un probleme avec mon blackberry 8520. ;j'ai besoin de connaitre mon MEP et...
I have forgotten the password for my blackberry...
I have tried it 5 times and don't want to try anymore, would be great if someone could help me!
Fix-O-Meter
18
18 people viewed this problem
- 0 people are following this problem. Be the first!
Top RIM Cellular Phone Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
