Question about Dryers
Disassembling a kenmore dryer
Can someone tell me the correct way to disassemble a kenmore dryer to get the drum out. We have a lint problem because the drum is off balance. I have cleaned all the lint out of everywhere else. I discovered this problem because the dryer was overheating and the automatic thermstat shut it off. Thanks
  • 2 more comments
  • MsFixIt69 Oct 21, 2008
    The lint trap is on the bottom in the front.
    oops, it is a frigidaire dryer.
  • tictic24 Oct 22, 2008
    I want to inspect the inside because i think i might have a lint problem, the dryer shuts down way too often with the lint button lit. Can the bottom pannel be removed in any way?
  • tictic24 May 11, 2010
    I lost confidence in this site because of micbeth1981's useless responses here. Everyone has a opinion.
    Genius:
  • 1,122 Answers
Does it have a top lint filter or a inside the front lint filter-?-mike
Posted on Oct 21, 2008
  • 1 more comment
  • MIKE major Oct 22, 2008
    why did you leasve me a thanks for trying when you gave me all the wrong information?you screwed up by expert rating!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • MIKE major Oct 24, 2008
    your a ****, you give wrong info and want the right answer!!!!!!!!!
  • MIKE major Dec 08, 2008
    your an ******* for that rating
Kenmore 80 series dryer is making a loud screaching grinding noise what could be the problem
Kenmore (Sears) dryers are usually manufactured by Whirlpool. The rear of the drum rides on 2 lower rubber rollers that go bad with age. Those rollers may need replaced. There is also a felt seal strip attached to the rear of the drum that rides the back wall of the dryer that may need replaced. Can only tell for sure by disassembling the dryer and checking.
Jun 02, 2015 | Kenmore Dryers
Kenmore Elite Oasis 6806 Electric dryer with burning smell
you must disassemble the unit and clean the lint out of the heating unit area, it is lint catching fire and could be dangerous to continue using your unit in this condition. a vacuum cleaner should do well to clean the lint and the drum must be removed to do a proper cleaning
Apr 15, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
My dryer runs and heats but seems like no air is being blown. It should have some sort of a blower correct? Taking 2 cycles to get dry and vent is not clogged, but not sure about lint trap slot.
First, of course, make sure ALL the airways are clear, including the area around the lint filter, and the outside vent - lint likes to stick to the outside vent flap, so make sure you clean that off too, and that it opens and closes freely.
Here's how to get the dryer apart
http://fixitnow.com/wp/2004/03/22/appliance-tip-of-the-day-encore-dryer-disassembly/
There is a blower wheel, but it's powered by the same motor and belt which turns the drum. So if your drum is turning, the blower wheel should be turning, too. If not, you may have to replace the blower wheel. Here a link showing how to do so:
http://fixitnow.com/wp/2010/06/30/replacing-the-blower-wheel-in-a-whirlpool-built-dryer-with-the-lint-filter-in-the-door/
Mar 26, 2011 | Kenmore Dryers
No heat
WITH THE POWER OFF check:
Thermal fuse (should read zero ohms on an ohmmeter).
Thermostat (yours has a combination type, both terminals opposite of each other should read zero ohms.
Heating element. You will probably see broken coils if this is bad.
This is not difficult to repair, but requires disassembling of dryer front, removal of drum and belt, an ohmmeter and screwdrivers, and small socket wrench set.
See this:
http://www.applianceaid.com/wpdryer_how-to.html
and prices:
http://www.repairclinic.com/Kenmore-Dryer-Parts?s=b6a8c244
Apr 29, 2010 | Kenmore 63942 Dryer
Belt replacment
Here is a diagram from kenmore corp. that should help you out
Maytag Dryer Belt Routing
This is the most common belt routing found on most Maytag brands clothes dryers.
Since you will have everything disassembled to change the belt, this is an excellent opportunity to vacuum out the cabinet to remove dust and lint and perform preventative maintenance on your dryer. When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Dec 04, 2009 | Kenmore 66862 Dryer
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
Drying not drying, clothes moist after hours
This is likely the result of an air flow problem if you are sure the heater is working. Ensure you are not running the dryer in a closed room which would starve the dryer of air dramatically reducing the air over the clothes even if the full length of your vent is brand new. Next, remove the vent hose from the rear of the dryer and check for strong air flow at the outlet. If it seems strong enough then run a vent through a window or out into another room and do one load in this fashion. If this resolves your problem the blockage exists in the vent line outside your dryer and disassembling dryer becomes unnecessary.
If not, ensure you have seen and touched every inch of interior dryer piping and hold the lint filter up to the light to be sure you can see through it. Disassemble and clean ANY section of piping you can't get your hand into. The area below the lint filter tends to catch a lot of lint and can only be accessed by removing the housing at the rear on the left side as you face the rear. Ensure the blower wheel turns when the motor turns. (Newer models may have the filter housing at the front)
Having performed all these actions will likely resolve the problem.
Sep 19, 2009 | Kenmore Dryers
I have Whirlpool Duet Dryer that has a noise.
It is common for small items (such as coins) to get stuck inside the dryer drum baffles. You can easily remove them without disassembling the entire dryer. The screws that hold them in place are located on the outside of the dryer drum. In order to access, follow these steps:
1. Unplug the dryer.
2. Remove the top panel of the dryer by removing the three screws located in the back of the dryer holding the panel in place. Once the screws are removed, the top panel slides back, then lifts off.
Each drum baffle has two screws holding it in place. Remove the screws and the baffle will drop into the drum allowing you to easily check inside each one.
Another source of dryer noise is something caught in the blower fan housing. You will need to remove the lower toe panel directly below the dryer door to access. Follow these steps:
1. Open the dryer door and remove the lint screen (the blower fan cover will not come off with the lint screen in place).
2. Locate the screws that hold the toe panel in place along the bottom front edge of the panel. HINT: Propping the front feet of the dryer up can give you better access to reach the screws (a 2x4 works well for this). With the screws removed the toe panel will drop down, then come off.
3. Remove the screws that hold the blower fan cover in place.
Inspect the blower fan housing for any objects that may be vibrating against the fan blades.
If you still need further assistance, please let me know. I hope you find this helpful.
Sep 01, 2009 | Dryers
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Kenmore he3 electric dryer has F1 error code while drying clothes. dryer will run for a few minutes and automatically shut off. purchased a new thermostat but can not find where the thermostat is located...
How to disassemble a kenmore dryer to get the drum out. Can someone tell me please. I want to know what I need to take off first so I don't mess anything up.
Jul 10, 2008 | Dryers
Dryers Logo
184 people viewed this question
Top Dryers Experts
