Question about Dell Dimension 4700C PC Desktop
Dell 4700c will not boot
I have a similar problem as others posting about 4700c - only mine will not boot - I hear 6 beeps as it is trying to boot, could this be the fan issue or something else. b
  • 3 more comments
  • brendab530 Oct 21, 2008
    No, can't get that far - seems to want to boot, but just a black screen - I did have it up and running earlier - as I was working on something else, the machine beeped and monitor is black. does this help?
    It's up and running now - changed the powercord - started right up - do you think that it is a sign that the powersupply is going and when it wouldn't boot up, it was very noisy - do you think cleaning the fan will help?
    yep , i have now
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    sure..sounds like you will need to boot from a recovery or installation cd, have either of those?
    maybe memory displacement..can you do a boot to F8?
    Master:
  • 538 Answers
Absolutely..when the power cord issue arises, then there is a problem with the input to the power supply..those are really cheap and easy to replace..
Posted on Oct 21, 2008
    A Womans Computer Man Oct 21, 2008
    good on you..now, please rate this as you believe it has helped you with fixya or helpful..
Memory upgrade on gx280 beeps on boot but doesn't start. memory beeps 1 234 5 6
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer. The other issue is if that model supports 4 gig memory.
Aug 30, 2012 | Dell Computers & Internet
G61-306NR power button doesn't work
Disk Drive works, Memory is good, so any Blinking Lights or Beeps when you hit the power button? Does anything ever post to the lcd screen when you press the power button?
It sounds like either you've got a memory issue or a video card issue. Just because the memory worked in your friend's computer does not mean it will work in yours. Your Slot where the memory goes might be bad.
When you plug in the power cord is there anylights whatsoever on the laptop, where the plug goes in or on the AC Adapter ofthe power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Apr 11, 2012 | HEWLETT-PACKARD G61-306NR Notebook
I have dell dimension 4700c I just get black screen all diagnostic light are green there are on beeps I have try F2,F8,F12,Windows turn it on take power cord out nothing is working pleas ehelp
You should try a different monitor if you can. I can't tell if you see the motherboard's BIOS, but if you don't, then I bet it's the monitor. If you can't find another monitor to plug it into, your TV might have the correct input. Hope this helps!
Apr 08, 2011 | Dell Dimension 4700C PC Desktop
Dell dimension 4700c pc clicks and beeps when trying to start up . does not start up.
  1. Generally this is a common problem of RAM.
  2. Check RAM, remove it, clean & install again. Restart your PC & check.
  3. Check the RAM with other PC for its healthyness.
  4. check all the connection of motherboard for tightness.
  5. Still not working then need to check the motherboard. it might be faulty
Aug 22, 2010 | Dell Dimension 4700C PC Desktop
I have dell optiplex gx 150 beeps 6 times and a and b led is amber and c and d led is green
the 6 beep codes will be in a specific timing i.e. two beeps, a space 2 more beeps, and another space and 2 more beeps.
Looks like it may be a memory problem according to the lights.
ad54556.gif Possible memory failure
Reseat all DIMMs and restart the system to retest.
Here is the link to the beep codes and diagnostic lights for your dell optiplex gx 150 HERE
The Beep codes are in Table 2 and the diagnostic lights are in Table 3.
Apr 14, 2010 | Dell Computers & Internet
Beeping sound from PC at turnon
If you do not get any display after turning on the system, first use the following steps:
Turn off the system and disconnect power cables
Press and hold the power button for 10-15 seconds.
Reconnect power cables and try to turn it on.
If it remains same, the next step will be to:
Open the case and re-seat memory modules
If you have more than one modules installed, try to test the system with a single module at a time.
Mar 12, 2010 | Dell Dimension 4700C PC Desktop
My Dell 4700c locks up for no reason at all, start-up issues
I have a feeling your hard drive is going bad if your hearing a clanking sound sometimes. Best way to know is to try to save your important stuff onto your external hard drive if you can and then format your C: drive using a windows 98 boot disk. If it can't go thru the format then you know for sure the drive is bad or if your hearing clanking sounds from the drive while your trying to do any of these steps then the drive is still bad.
Feb 07, 2009 | Dell Dimension 4700C PC Desktop
My Dell 4700C PC will not start
Sounds like a blown power supply. Easily fixed. Go the a local computer store and buy a 400+ watt power supply, open your case, remove the 4 screws in the back, all the power plugs and replace with the new one.
Jan 08, 2008 | Dell Dimension 4700C PC Desktop
Dell Dimension 4700C PC Desktop Logo
131 people viewed this question
Alun Cox
