Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA TV MODEL D52W25
IT IS NOT TURNING ON AT ALL. WHAT SHOULD I DO?
Take the back off the TV look where the wire from the power plug enters the TV. There is a small fuse on the board where the wire plugs into. If that fuse is blown, you have a power supply problem.
Posted on Oct 29, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA D52W25
Thats possibly the flyback causing that. If you need more help with the problem or how to change the flyback, let me know
Posted on May 12, 2008
kevin000
  • 1847 Answers
SOURCE: i hav a RCA model
go through this link it will help you with your issue..
http://www.ehow.com/how_2034880_perform-convergence--tv.html
Posted on Oct 08, 2008
  • 1779 Answers
SOURCE: High Squealing Sound
There is a stand up coil about 1" tall and the dia of a nickel close to the HV transformer, the iron core glue comes loose over usage. This can be cured by replacing it or using a sealer/caulk and re-seal the coil. Hope this helps, it is not an expensive job for service.
Posted on Feb 13, 2009
Slinteriors
  • 8617 Answers
SOURCE: RCA D52W25 power issues.
Install the repair kit called the CP150, CP120 and CP114 repair kit available from www.tvrepairworld.com the kit contains instructions on CD also.
Posted on May 25, 2010
Slinteriors
  • 8617 Answers
SOURCE: rca hd d52w25 tv was
The most common cause of that symptom in that model are the CP150, CP120 and CP114 capacitors. You can get the RCA repair kit by that same name from www.tvrepairworld.com the kit contains the capacitors and the CD with repair instructions.
Posted on Nov 05, 2010
D52W25 RCA Problems
What is the problem you faces with this TV? Provide more details please. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2300 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 15, 2013 | RCA 264102 Refurbished Power Board Circuit...
Rca hd d52w25 tv was working fine turned it off when turned on now no picture or sound and power button flashes green
Nov 05, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
May 24, 2010 | Televison & Video
RCA model# D52W25 won't turn on How do I test parts
you have to leave that to a professional tech it is very dangerous to probe into a tv if you dont possess the experience there are very high voltage stored inside your tv.good luck.
Feb 21, 2010 | Televison & Video
The power button light blinks a few times but no power afterwards. RCA D52W25 is dead. I lightly shook the TV last night and it worked until this morning.
These units are famous for loose solder connections at the high voltage transformer and for bad capacitors in the power supply. Have a repair shop check it out for you. You have to remove the Deflection PCB to do these repairs. Thanks
Oct 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA d52w25 52 inch blinks 3 times off...turns on...off
Most likely Capacitors cp150, CP120 and CP114 need replacement. You can get the repair kit at www.tvrepairworld.com under the RCA reapair kits catagory bottom of the page. The kit contains the capacitors and detailed instructions
Sep 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sound won't work on RCA D52W25 TV
first things to check in settings check to see if the settings to make sure the set is set to internal amplifer. not external. there two other things this can be the speakers if blown or the audio amp is blown if the amp is blown the the main board will need replaced. Tech have special equipment needed to replace this and at my shop it would run about 250
Apr 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Feb 13, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W25
May 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Rear projection Tv D52W25
the would be you high voltage flyback do not run the set while this is happening as it could do more damage.
you should replace that part.
Jan 09, 2008 | RCA P52926 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
438 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
