Question about Canon PIXMA MP830 All-In-One InkJet Printer
I receives error message A600 on my printer
I have a problem with printing due to error message A600.
    Sergeant:
  • 154 Answers
6A00 fix
There is a sponge to the right of the ink cart that gets pushed up to prime each ink cart. The sponge then drops back down when finished. The problem is that the sponge gets stuck up. Just give it a tap and it will fall down, turn off then on and all fixed
Posted on Oct 21, 2008
My printer is giving me this error message "Batch
That's a batch error, more than likely due to a communication issue between the pc and the printer. If you reboot the printer, THEN reboot the pc you should clear that error.
This error sometimes occurs when the printer has been shut down whil logged into your software, which disables communications between pc and printer. The error indicates that the printer didn't receive enough data to properly print the batch of labels/tags.
Sep 14, 2011 | Paxar Monarch 9825 Thermal Label Printer
Getting error code on printer screen A600 why does
Mine kept doing that. My dad found website where lots of people had turned it upside down, shook it and then was fixed, so we tried it and it actually worked!! Now is printing again and no error codes!! Worth a try!!
Feb 09, 2011 | Canon PIXMA MP600R All-In-One InkJet...
Receiving error message 5200...but i have lost my original manual thanks
According to the error code, http://pixma.ulmb.com/?p=226, the error #5200 means "Print head temperature rise error".
Some of the nozzles of your printer are clogged. The print head will overheat because it does not have ink going through the nozzles to cool it. But you continued to print repeatedly, the print head may have been destroyed due to overheating.
Sep 10, 2010 | Canon PIXMA MP240 All-In-One InkJet...
The cartridge holder won't slide along - just says error message A600. Had just replaced a cartridge, and it did work at first, but not 5 mins later
Hi there
Error A600
Your A600 is a paper path error, usually related to the purge unit. Try checking the purge unit for paper stuck in it.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Almost 90% of the time is related to the purge unit being jammed with something and not being able to move.
Look for paper, paper clips, push pins, screws flower bud pods or the like.
The offending item needs to be removed or the purge unit needs replacement.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow.
The purge unit is a white plastic assembly (on the right side of the printer where the print head homes) that is spring loaded on rides on a rail.
You can try moving it back and forth about 5 times or so and clean the rail with a cleanex and putting a little bit of some light oil on it and then close everything up and try it.
I will keep on helping.
All The Best: Pineworks
Mar 22, 2010 | Canon MP610 Photo All-In-One Printer
The printer screen shows "Error A600" and the printer will not work - what can I do?
Hi there
Can only try.
Error A600
If you found this useful all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Feb 11, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My ip4300 printer shows - Service Error A600-
goes through this link and try.........
http://tricks-collections.com/solution-canon-pixma-ip4300-error-6a00/
Oct 07, 2009 | Canon Office Equipment & Supplies
Received the following message when I tried printing - "System Error. The printer failed to print due to a system error. Try printing again. If unsuccessful turn Windows off and reprint." Can you sugg
Turn it off and unplug it for about 30 seconds. Plug it back in, turn it on and try printing a Self-Test (Setup, 2, 5). If this works, try printing your document again.
Apr 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Cannon MP810 when turn on display error A600. There is also no light displaying on the printing cartridge.
A600 or 6A00. If 6A00 then the fault code is for the AP motor position error. Error lies with the sheet feed unit, Purge unit or Logic board.
http://www.tradebit.com/filedetail.php/4588588-canon-pixma-mp810-printer-service-manual
This is a complete service manual
Sep 14, 2008 | Canon PIXMA MP960 All-In-One InkJet...
Brother mfc 420 cn
if you have an error 41 the machine wont print any more due to a short circuit in the print head.
plz check error message.
anyway, if you have received error 41 you need a new printhead or better (because its cheaper) a new mfc.
sorry!
Feb 13, 2008 | Brother MFC 420CN All-In-One InkJet...
Printing Error
try changing the ink cartridges.
This may have happened due to low ink levels. Also try reinstalling the printer driver.
If the print cartridges are damaged this problem will pop up. Even static electricity in human hand could damage the print cartridges.
Oct 07, 2007 | HP PSC 2355 All-In-One InkJet Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
112 people viewed this question
old marine
old marine
