Question about Samsung CLP 300 Laser Printer
Samsung clp-300 printing
Want to print on a thick 120gram colour page.paper jams all the time but the settings is placed on thick page but still no luck
  • 74 Answers
Per the user manual you should try using manual feed, loading one piece of paper at a time into the try and then following the on screen directions(whould be press the stop button once after paper loaded), find attached a image showing how to set up the manual feed
Posted on Oct 22, 2008
I have a Samsung CLP-310 and I've mislaid the units manual. On the top of the unit down on the bottom right hand corner there are four (4) colour icons a yellow, red, blue and a grey, all which light up...
Here is the link to the manual, it says that the flashing light is PROBABLY caused by lack of toner and the first step is to replace/replenish the corresponding flashing light to the toner. It explains that when the light turns stys on all the time the toner will be empty.
With regards to the paper jamming, there is 3 pages on things to do or try.
I hope this gives you a few ideas
http://www.samsung.com/uk/function/search/espsearchResult.do?keywords=Samsung+CLP-310&input_keyword=Samsung+CLP-310
Nov 30, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP300 jams when normally printing, but will print test
If you are using a 6cm paper to print that is smaller than a A4 size paper.
do a check when you print did you select the correct paper size. as wrong paper size is print will course paper jam too.
Apr 08, 2010 | Samsung CLP 300 Laser Printer
Samsung clp 300 paper jams after feeding about 5cm. Tried more paper, less paper, printing black only, printing colour, no change. Help
Clean up the Pick Up Rubber.
When you are able to get the Pick Up Rubber out of the maschine rotate it 180 degrees an reinstall it. then the problem would be fixed.
Oct 14, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP-300 will not print any type of white paper.
I think there may be problem with toner or black developer. Kindly get it verified. You may check by taking out imaging unit. For more details use the user manual.
Jul 23, 2009 | Samsung CLP 300 Laser Printer
Won't print
download smartpanel for this model from samsung web,install on pc,will tell you what the problem is.
May 31, 2009 | Samsung CLP 300 Laser Printer
SAMSUNG CLP-300 SERIES PRINTS OFF WEB PAGES BUT NOT OFF WORD
ok..then open up word..and check the print settings on a doc..might be that the margins are not set well..reset them for default..see how that goes..
Nov 21, 2008 | Samsung CLP 300 Laser Printer
Thick paper wont print
Per the user manual you should try using manual feed, loading one piece of paper at a time into the try and then following the on screen directions(whould be press the stop button once after paper loaded), find attached a image showing how to set up the manual feed0c16087.jpg
Oct 21, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP-300 dark prints and smears
For starters remember this is not meant to be a PHOTO Printer, I am guessing the Spearing is because Glossy paper does not hold the toner like Regular paper or at least until it is fused. I am a technitiian and i also own this printer.
Jul 14, 2008 | Samsung CLP 300 Laser Printer
Printing jammed on thicker paper
See the manual. It looks as if 120g/m2 is the heaviest paper it can use:
"Set Type to correspond to the paper loaded in the tray from
which you want to print. This will let you get the best quality
printout. If not, print quality may not be acheived as you want.
Thin: Less than 19 lb (70 g/m2) thin paper.
Thick: 24 lb to 32 lb (90~120 g/m2) thick paper.
Cotton: 20 lb to 24 lb (75~90 g/m2) cotton paper such as Gilbert
25 % and Gilbert 100 %.
Plain Paper: Normal plain paper. Select this type if your printer is
monochrome and printing on the 16 lb (60 g/m2) cotton paper.
Recycled: 20 lb to 24 lb (75~90 g/m2) recycled paper.
Color Paper: 20 lb to 24 lb (75~90 g/m2) color-backgrounded
paper."
Nov 22, 2007 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
388 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
