Question about Olympus FE-230 Digital Camera
A couple issues
Hello. When I turn on my camera, there is a blinking green dot in the upper left-hand corner and I am not able to zoom at all. If I take a picture then it locks up and I have to actually turn the camera off, take out the battery, put it back in and turn the camera back on before I can take another picture. Also, when I got into the "Play" mode, I am not able to play any videos. And, it will only let me delete one picture at a time. Then I have to take the battery out again. Is there some kind of setting I have turned on that I am not aware of or is there a way to fix this?
Thank you!!
~April
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Check the battery door or the battery compartment.. the battery may not be in all the way
or else repair at olympusamerica.com/repair
Posted on Oct 22, 2008
Orange light flashes on when turn on Olympus c-50 zoom camera and orange and green lights in upper left corner blink when try to take pictures. Won't take any pictures
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
Mar 05, 2011 | Olympus Camedia C-50 Zoom Digital Camera
Nikon Coolpix p80 blacked out, rounded corners
Have you attached some sort of lens shade to the front of the lens? The vibration might have something to do with the shake reduction system but I can't be sure. It certainly shouldn't vibrate heavily. You might get a better answer if you e-mail the tech guys at the support section of the Nikon website.
Feb 19, 2010 | Nikon COOLPIX P80 Digital Camera
TI 84 plus calculator, flashing dot in upper left hand corner
When you turn the calculator on, its screen is cleared, save for a small square on the top left corner. This is the cursor and it is blinking: The calculator is waiting for you to order it to perform some calculation.
Try this simple operation
[1] [+] [1] [ENTER]. The calculator will display the result one line down justified to the right.
Hope it helps.
Aug 26, 2009 | Texas Instruments TI-84 Plus Calculator
Blurred Images with Olympus E520
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Mar 23, 2009 | Olympus Zuiko 70-300mm f/4-5.6 Digital ED...
Hightlight message on Nikon D80
Highlight is just the info mode, there are several info modes including Basic file info, Shooting Info and RGB histogram, just press the round controller in the up or down direction to change between them in playback mode. Highlight will flash black anywhere there is pure white in an image.
Try resetting the camera by pressing the 2 buttons with green dots (on top of the camera near the shutter release) holding them for a few seconds.
Mar 08, 2009 | Cameras
For Nikon AF 24-50mm f/3.3-4.5D Zoom-Nikkor Lens I need instruction book. Specifically, there are dots side by side marking the apeture selected, left one yellow, right one green, what one is correct and...
The green mark is the index for the aperture setting at 24mm, the yellow mark is the index at 50mm. These really only matter if you are setting the exposure manually and using an external meter. The green mark is the primary mark -- as you turn the ring you will notice that it lines up with a number at every clickstop, while the yellow one is a bit off.
The pull down lever you ask about is the aperture lock. Autofocus film cameras and all digital cameras expect the lens to be set at smallest aperture (highest number). They will give an FEE error if it is not set correctly. When you turn the aperture ring to smallest aperture you will be able to slide the white dot into position next to the orange mark, and that will lock the aperture ring so that it is not accidentally tgurned while using or changing the lens.
Feb 22, 2009 | Nikon AF 24-50mm f/3.3-4.5D Zoom-Nikkor...
Green dot in upper left-hand corner of screen.
you can try demagnetising your tv screen
Jan 13, 2008 | Emerson EWF2004 20" TV
Camera shakes when turned on and when taking a picture there is a black area in upper left corner
This soundfs like a Zoom lens element problem May be expensive to get fixed Check out customer support
Jul 31, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Olympus FE-230 Digital Camera Logo
59 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
