Question about Toshiba 57H81 57" Rear Projection Television
Wavy, jumpy picture, ghosts, occasional color loss/change---you name it!
We have a toshiba 57" rear-projection unit. last fall, it began to start up with the picture being wavy and kind of jumpy, would clear up after about 10 min. now, it's never clear, all written words/numbers are unreadable, images seem to double-up in a jumpy way (like ghosts, but farther apart), sometimes the color isn't correct momentarily, and vertical lines appear. have tried turning it off for a while---no help. have tried the "touch focus" button on front of tv---when procedure is finished, a message reads, "touch focus error". have tried adjusting everything else i can think of/find on menu choices and in manual, but nothing helps. can power surges mess things up like this? is it worth repairing? and what kinds of repairs are we looking at and at what cost?
  • 5 more comments
  • Anonymous Oct 27, 2008
    tv piture is wavey and jumps but can kinda see the picture
  • Jasonyvonne Nov 28, 2008
    Ours is wavy more at the top than the bottom - hard to watch a game with scores at the top - its a good 10-15 min warm-up.
  • OLDGOAT77 Nov 28, 2008
    I have wavy lines at sides of picture after an hour or so, and a rainbow type image at top of screen.
  • Anonymous Nov 29, 2008
    Our picture works perfect for HD channels and transmissions. But if we use regular input like a DVD player or Wii the picture is all wavy. It was better before and would clear up after 10 minutes or so but now it never clears up.
  • jpmurr Jan 30, 2009
    IM wouddering how to fix my hyperboard
  • kac7 Feb 05, 2009
    I have the same issue. Would only work on HD channels. Had the cable company come out because I thought it was the cable box, the box was not the issue. Now since the cable tech. messed around with it I am not even getting the HD channels.
  • dzomtec Mar 04, 2009
    loss of colour in tvs
  • 3 Answers
It's the hyper mod board. I've replaced many of these.
Posted on Oct 09, 2008
This is crap
Posted on Feb 13, 2008
    President:
  • 3,130 Answers
It could all be one problem A simple capacitor in the power supply circuit,or in the sweep power supply. But it could also be a combination of problems like regulator, convergence,or tuner problems. My bet would be in the regulator circuit of the power supply with bad capacitors. Your looking at around $250.00 to $400.00 for a repair price. Good Luck
Posted on Jul 24, 2006
  • 1,476 Answers
Your description of the problem seems quite clear. It is a classic convergence failure. I do not know your capabilities so here is the procedure. If you aren't capable of TV repair get a reputable repair shop to do it for you. Cost shouldn't exceed $250 US depending on your location. Can power surges cause this? Power surges cause lots of problems but usually in the power supply. You can avoid that issue by getting a good Uninterruptable Power Supply like you would use on a Computer and plug the TV into it. They are not that expensive anymore and will pay for themselves the first power surge or electrical storm. Is it worth repairing, certainly. Here's the convergence IC procedure if you have the skills - If the convergence adjustment is not moving the beam chances are the convergence IC(s) are defective. If you know how to solder and understand TV safety you may be able to fix it. With power disconnected remove the back. You should see two large heat sinks with large ICs (3 by 6 inches) with about 30 leads going through the circuit board. Numbers on the ICs should usually be something like STK###-### or some variation with # being a number. These ICs control the position of the red and blue beams. If they go bad you can't adjust one or more beams. Replace them both as you don't want to get in there again in 3 months. Cost is not that much. http://www.tritronicsinc.com or http://www.partstore.com should have them at a reasonable price. Check the associated components in the circuit for problems, resistors etc, and replace any which do not check in specification. Before replaceing the ICs look at the circuit board closly for cracked solder joints. Resoldering any bad joints might just solve your problems and avoid replacing the ICs. Good luck and remember safety.
Red is ghosting to the right. i replaced the convergence tubes about 6 months ago. went with the expensive ones "not the cheapy's" used heat sync putty stuff and everything. the problem is...
Yes,the tv problems it is the same,it is the tv convergence problems again,now it just color it is shaded in shadows pictures,instead of wavies mis colors R,G,B mis alignments.Yes.The tv convergence board it is the problems,must be repair again.
Apr 27, 2011 | Sony KP-57WS500 57" Rear Projection...
My 57" Toshiba projection TV recently started having picture problems. The picture is distorted and wavy. The picture on the PIP screen is fine. is this a common problem and is it fixable?
First bypass the cable box and hook the tv directly to the cable to see if the problem goes away. if the problem persists you possibly have a bad input board.
Mar 13, 2010 | Toshiba 57HDX82 57" Rear Projection HDTV
I have a 57 in toshiba rear projection, picture just started jumping and went out, if you put it on another imput for gaming the picture is there but is rounded and is jumpy could you tell me what is wrong...
Possibly not repairable, because many problems are related to a board called the "hyper" board, which is mostly no longer available.-- Most picture problems other than convergence or a bad tube, which doesn't sound like yours.
Mar 08, 2010 | Toshiba 65H82 65" Rear Projection...
The picture has ghost images, not lining up
This sounds like a convergence problem. Use the menu functions to reset your set's convergence. If this is not enough, you may need to replace the convergence board.
Feb 17, 2010 | Toshiba 57H82 57" Rear Projection...
Loss of red color and dual images
Ur convergence is dead,U know how to solders?Buy a convergence kit,use what in that kit.ur tv should be back to normal.This website have the convergence kit
Tv repair World.com.
Oct 21, 2009 | Hitachi 57F500 57" Rear Projection...
We have a Toshiba HDTV model number 57H82. It is
Sounds like a bad tuner/decoder on the Qam analog side of things. You can bypass this with a Clear qam converter box or a analog to digital tuner box or simply having this repaired upwards of $200 bucks.
Thanks for using Fixya.com
You're Toshiba Tv Expert.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | Toshiba 57H82 57" Rear Projection...
RE: TOSHIBA 57 IN
This is a Hyper PCB problem. Ready the following for information: http://www.hdtvoice.com/voice/showthread.php?t=10984
Mar 27, 2008 | Toshiba 57H81 57" Rear Projection...
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 12, 2007 | Toshiba 50H81 50" Rear Projection...
Toshiba 57H81 57in. Rear Projection Please help us get started
this set has a scan converter board that causes this prob. it can be replaced or rebuilt. rebuilt is the best option. by tv tech..john
Sep 12, 2007 | Toshiba 57H81 57" Rear Projection...
57"H82 Toshiba-- wavy picture
you got somes capacitor bothering you, and nop, there are nothing you can do, but call a tech, the problem could be in the video card or in the power supply but is a tech job....good luck
Aug 08, 2006 | Toshiba 65H82 65" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
756 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
