Question about Epson Stylus CX3200 All-In-One InkJet Printer
My scanner hi i have a epson stylus cx3200 and the red light is on saying the scanner error is on how do i fix it
  • tinamarshall Dec 04, 2008
    red light on saying error c booket but i cant find it
Had/have the same printer and the same problem. I am running Windows XP.
Go to the "Control Panel.
Select "Scanner and Cameras"
You should see your device listed here. If not then add it.
Select your device and you will see "Welcome to the Scanner and Camera Wizard".
Select "next" the following three times.
It will then scan the desktop.
Select "Next" and then finish.
The red error light should be gone.
I suggest ignoring the red light unless it just drives you nuts. You may have to run this everytime you turn your computer and printer on. Some reason the scanner is not linking with windows and you have to introduce them everytime.
Keep the printer.
Posted on Dec 06, 2008
  • 154 Answers
Have you looked to see if there is a 'scanner head lock' if there is, make sure that it's unlocked
Scanner error see ur documentation and callservice if necessery
Posted on Oct 22, 2008
2 Suggested Answers
  • 94 Answers
SOURCE: my scanner
Open the scanner lid and slide the transportation lock back to the hw_translock_1.gif unlock position.
I will appreciate a Fixya rating if I were able to resolve your concern.
Error light on and saying scanner error
Hi!
Open the Lid for scanner, check for a switch on the side for Scanner Lock. Try to switch it to unlock position and retry booting up Printer. That should take care of scanner error message.
Hope this helps. Cheers!
Mar 04, 2011 | Epson Stylus CX3200 All-In-One InkJet...
Error Message - Scanner
Go to manufacturer's website, and download the latest device drivers for your model printer, and any other software updates they provide.
Sep 01, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX3200 Error
Possible scanner failure.
Turn off your printer. Disconnect it from your computer. Toggle the transportation lock on the scanner unit if there is any. It has to be in the unlock position. Turn the printer back on.
If your unit is not yet a year old, please contact epson for your warranty options.
To help you find an epson certified servicer near to your area, please log on to epson.com.
Apr 28, 2009 | Epson Stylus CX3200 All-In-One InkJet...
My scanner
Oct 22, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Scanner error see your docmentation and call service if necessary
Please follow the steps below to resolve your issue.
1) Turn off the printer.
2) Lift the scanner cover.
3) Toggle the transportation lock five times, ensuring that it is in the unlocked position, towards the back of the scanner.
4) Turn on the printer, and the error should be cleared.
Jul 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printer problem
Make sure the head lock is not on (if fitted). Look to see if the scanner array illuminates and moves when the machine powers up. If the array does not illuminate then the chances are it will be too expensive to fix.
If the scanner tries to move but can't, you probably fix it by removing the scanner and seeing if something is blocking it's movement. It could be the motor has died so again too dear to fix.
Feb 16, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Nazir
There is an error with the scanner section.
Feb 08, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printer fails
Need more info. than this. What exactly is the issue - is the printer feeding paper? Is the ink not printing etc.
Aug 26, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
182 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
