Question about Asrock 775Dual-880 Pro Motherboard
How can i run 1 or 2 DDR2pc8500 1066Mhz on a asrock 775dual 880pro< it booted,went to bios to down the speed to 667, but when windows(XP) tried to boot it went to a blue screen saying things about memory error or hardware error. Do you know how i could make it work?
  • math_saint Oct 21, 2008
    oh yea i already updated the bios, and once i was able to boot to windows,with 1 RAM installed, but then tried installing the second one and it didnt work,and since then i cant even make 1 work.
    well first off,i bought em for my computer,which runs on a maximus formula,but,that motherboard has problems running 4 ram sticks. so i wanted to sell them to my girlfriend, but unfortunatly she her MB supports only 667 DDR2. i'll try booting with no memory. and here's what it says oon the sticker:
    2-1GB 240-pin unbuff DIMM 128MX64DDR2 PC2-8500 CL5 EPP
  • 13,433 Answers
Your motherboard supports DDRII 667/533/400 and DDR400
1066 is not supported, I have never tried to use a unsupported memory speed on a motherboard so I don't know, I know you lowered it to 667 but still the ddr2 which you have bought is not supported by default.
why buy too fast memory?
Posted on Oct 21, 2008
  • 3 more comments
  • Ekse Oct 21, 2008
    try removeing both of the memorys then boot up without any ram, it will beep, then insert the other one, try if it starts up.
  • Ekse Oct 21, 2008
    and ofcourse turn the power off in the middle of these changes.
  • Ekse Oct 21, 2008
    can you post the details of your memory? I think im onto something..
  • Ekse Oct 21, 2008
    everything it says on the stickers of the ram
  • Ekse Oct 23, 2008
    so hows it going I see I got a Thanks for trying rating?
    The thing is you have a memory that best works at 1066 and you are trying to run it on 667 you can't blame me for this hardware issue.. can you change the rating? you have to get memory that runs on 667 and it will work properly.
Can my hdd samsung 1tb model hd103SI work with 775dual-880Pro motherboard? I conect but Its not deteted!
That is an Asrock board and Yes, any standard hard drive will work with it. The reasons for your problem in descending liklihood:
>Your connection is incorrect or a bad cable.
>If you have an operating system, there is a corruption/problem with it.
>The hard drive has failed
>Drive is not activated; enter Disk Manager and activate it.
May 18, 2014 | Asrock Computers & Internet
Audio driver
This motherboard drivers supports Win XP
if you looking drivers for XP, GOODLUCK
http://www.asrock.com/MB/download.asp?Model=775Dual-880Pro
Jan 05, 2014 | Asrock 775Dual-880 Pro Motherboard
Can my WD 5002AALX SATA3 work with 775dual-880Pro motherboard?
Hi, yes you can but you have to format the drive before you can use it.
You can download a manual from here:
http://www.asrock.com/mb/manual.asp?Model=775Dual-880Pro
You can format the drive in the disceditor.
Aug 30, 2011 | Asrock 775Dual-880 Pro Motherboard
I installed the new BIOS so I could Install my new CPU, Intel E5400 2.7 Ghz but when I boot it up. I have a black screen, everything seems to be running fine, there is no beeping noises. I have a...
Sounds like a video driver issue. Try this: Reboot the system and press the f8 key before it loads windows and select vga mode. Once you do this try reinstalling your driver for your vga adapter. Good luck and let me know how it went.
Dec 28, 2010 | Asrock 775Dual-880 Pro Motherboard
Cabel connect problem on the bord power sw reset sw hdd led connecting pins ???? i don't have a plan of the bord
Please refer to the Product user manual. You can download it from the following link: -
http://europe.asrock.com/manual/775Dual-880Pro.pdf
Hope this helps!!
CreativeTECH
Nov 14, 2010 | Asrock 775Dual-880 Pro Motherboard
775Dual-880 Pro cannot boot sata
Have you tested the same with IDE ODD ? Check SATA drive is detected in BIOS. If yes enable IDE simulation in BIOS
Oct 02, 2010 | Asrock 775Dual-880 Pro Motherboard
Hello can i connect 2 fans to the motherboard? 1 is at the rear,,can the other 1 go anywhere else with 3 pin connectivity??
Hi, this link will show you the manual to your Motherboard, Page 12 section 1.4 Motherboard Layout. this page will show the layout and you may need to zoom in to see it clearer, there is No.5 CPU Fan Connector (CPU_FAN1) next to the CPU slot and there only seems to be 1 more Fan connection No.15 Chassis Fan Connector (CHA_FAN1), this seems to be the only additional fan connection, normally you would connect a side door/panel fan, the rear fan connections direct to the PSU.
http://download.asrock.com/manual/775Dual-880Pro.pdf
Sep 17, 2010 | Asrock 775Dual-880 Pro Motherboard
775Dual-880 Pro cannot detect SATA HDD 320gb
if you bought this board brand new, take it back and tell them the sata controllers in the bois are not sufficent and get one that is. If you got it second hand then you will need to update or flash the bios to the latest version. see if that works and the drive is recognised. if it is recognised via flash/update you may still run into problems if you try to install XP
good luck and regards
Nov 22, 2008 | Asrock 775Dual-880 Pro Motherboard
Adding memory and bios upgrading
hey man, I checked the asrock website
Support DDR-II 667/533/400,
If your going to keep the 533mhz memory in your pc, then I recommend you get another 533mhz, becouse if you get a 667mhz the 667 will run as 533mhz becouse the 533mhz memory is slowing it down.
If you need more assistance let me know, I'm here to help
Apr 03, 2008 | Asrock 775Dual-880 Pro Motherboard
Asrock 775Dual-880 Pro Motherboard Logo
104 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
