Question about Maytag Performa PAV2200
Water leaking from back
I have a Maytag modelA612. When standing in front of it water leaks from the left rear, near where the hose fit onto the machine. I have checked the hose connections and they are dry. any suggestions?
  • 62 Answers
There might be a small hole in the inside part of hose, or ck fill valves
Posted on Oct 22, 2008
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
Hi there my hotpoint 640 is leaking it was leaking first at front but now the cold water connection at the back is leaking too.any ideas thanks
Fit a new hose or a new washer onto the old hose ...assuming that is the source of the leak that should cure......Good luck.....
Dec 10, 2010 | Washing Machines
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
Water leaking onto the floor
hat leak may not be in the machine. It may be one of the hoses going into it. Look to find out where the water is actually coming from. If it is a hose from the faucet behind the machine, the hose can easily be replaced at a low cost. If it is only leaking with hot water, check the water inlet valve at the rear of machine where the hoses connect, top left rear facing it. If it is leaking and running down the left side, it is the wrong side for the pump unless it running across the floor and out the left side. If it were the hose, it would leak all the time. It sounds like the hot side has gone bad on the inlet valve. You can save several dollars by fixing this yourself.
Tilt it back and look for two screws, near each corner on the bottom front. Remove these screws and pull the bottom toward you. It should lift off the clips on top. Run the machine carefully, moving parts and see if the leak is actually coming from the left rear and from somewhere up high. First try cold water, then hot. If it leaks on one and not the other, then it is the valve. Be sure to unplug the machine if you decide to change this part. Also you might want to mark where the wires go back to be sure you do not reverse the hot and cold water, as well as fittings and connections. The water leakage evidence should be visible. If not, wash a load and watch for where water leakage occurs. Just look. Do not touch since there will be electrical current supplied.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Water left pooled inside maytag neptune front loading washer
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The valve is either electric solenoid or plastic/rubber clapper in a cylinder. Your call whether to fix or not depending on ease and cost. Probably a $20.00 part.
Cheers!
Jan 27, 2009 | Neptune MLE2000A Front Load Stacked Washer...
In the spin cycle water leaks onto the floor,
If the hoses at the back are not leaking, you need to check the drain hose lines, aksi check that the machine is not dripping from the inlet valve hose, or because of a leak from the door gasket.
Dec 09, 2008 | Maytag PAV3240A Top Load Washer
Maytag A212 clothes washer, leaking on fill up.
Possibly Injector / Vacuum break unit has gone bad (mine started spilling water lately, 20 years old). Get a 216201 to replace in your vacuum break, or better (if the machine is older) replace everything from the water valve with a kit: SUB 206680 (INJECTOR HOSE KIT).
Quite easy to get to. Just open front panel (remove two screws at bottom, lift bottom of panel away from machine and swing out. Spring clips at top should release easily. Then remove two bolts that hold top cover down and lift top. Water injector/vacuum break will be at the rear left of the machine. Costs about $40 for the kit. Or $5 for the small rubber part (but I am replacing everything that is pressurized on my machine since it is 20yrs old). -- Kevin
Jul 19, 2008 | Maytag Washing Machines
Maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Feb 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
59 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
