Question about HP Color LaserJet 2600n Printer
Hp 2600n laserjet will not print
Was n line with pride2000 ad
  • Puneet Jain
    Puneet Jain May 11, 2010
    Please clarify the question and write in detail, so we can further investigate here.
    Guru:
  • 558 Answers
Check the printer if no light coming during power on. If it is coming, and no sound for rolling printer after giving any command.. or blinking light when print command is send, then check the top cover for any paper jam and firmly closed.
Clean the toner/cartridge and also internal part of printer with a blower/Vaccum cleaner.. then with a cotton or cloth.
Let me know the status after this, so I can help you out.
Posted on Oct 22, 2008
Need to change font size larger when printing
Change the font on your document before printing
Jan 12, 2015 | Office Equipment & Supplies
How can i calibrate print head of pagewriter trim 1
It would help if you stated the manif. example. Phillips, HP, hewlett Packard. ect.
You should be able to find service information on the bottom of unit.
May 08, 2014 | Office Equipment & Supplies
Why is print quality poor after inserting new ink. Copies are faint and have lines
the cartridge is clogged with ink that has dried and reduced the slit. you need to replace the cartridge with a new one. it happens usually if you recharge the cartridge 3 or 4 times with compatible ink.
May 07, 2014 | Office Equipment & Supplies
Hp laserjet m1522f error 5 turn off and on
Hi, Error 5 is a Scanner error. When turning the printer on, have the lid up so you can watch the scanner movement. Does it move smoothly? It should go through a warm up and you should be able to watch the scanner movement. If there is a problem with the scanner, there isn't a lot you could do except. The service manual says the scanner assembly should be replaced. If it was my printer, I would try to take a closer look at the scanner assembly and check to see if the scanner unit is bound up somewhere, or maybe a drop of 3 in 1 oil on the scanner rails. Let us know what happens.
thanks
Oct 02, 2013 | Office Equipment & Supplies
Prinnter not printing but showing 'put custom in manual tray'
There is still a print job in the queue. Place a sheet so it prints or kill the job.
Open Printers and Faxes. Open printer. Highlight jobs and Right click > Cancel, or Documents > Cancel.
For those stubborn jobs, Right click My Computer > Manage. Choose Services and Applications > Services > Print Spooler. Right click and stop. Then start. This may have to be done from the Print Server if it's network printer. Contact IT to kill.
Nov 09, 2012 | Office Equipment & Supplies
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
My fax wont work in my ricoh aficio 1515 mf??
Using the 1515 as a fax machine is a pretty simple procedure if everything works right. All you have to do is hook a working phone line up to the phone jack on the back of the copier (the one labeled LINE, not TEL).
Why won't the fax work? If it is giving you an error message, what is the message?
If you are not getting a dial tone when faxing, unplug the fax from the phone line and plug a working phone in, and see if the phone gets a dial tone. If it doesn't, there is a problem with your phone line.
You can also try plugging the fax machine into another phone line. If the fax works on that line, then there may be a problem with the first line.
Are you having problems sending faxes or receiving them, or both?
Jan 05, 2010 | Office Equipment & Supplies
Problem installing drivers for HP 4355 printer in vista 32bit OS
Vista OEM Cd usually doesnt come with drivers.
Printer should have come with its own cd which contains both the software & drivers.
If it didn't come with any
You can try using windows update
or
downloading drivers from hp site
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=1138373&lang=en
Feb 24, 2008 | Office Equipment & Supplies
HP Color LaserJet 2600n Printer Logo
47 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
