Question about Toshiba 1370 Black and White Copier
Flashes paperjame sign but there is no paper jame!
The red paperjame LED is flashing. But there is no paperjam at all. What is the problem here?
  • 1 more comment
  • Anonymous May 02, 2008
    Flashes red paper jam sign but there is no paper jam. Even after opening the machine up and making sure there definitely is no paper jammed anywhere. (The used toner cartridge was pretty full - should that make a difference?)
  • Anonymous Aug 01, 2008
    Have taken all steps described in the operator's manual.
  • mike5650 Dec 01, 2008
    Same problem of paper jam sign flashing, but no paper jam.
    There appears to be a small piece of plastic missing from the end of the paper tray. Single paper copying from the rear of machine is OK.
    I have another 1370 copier that works fine.
The problem is same sensor no work in the good way or ther is problem in the fusing unit or ther is problem in the feed unit
Posted on Jul 25, 2006
Paperjam error stays on display
open door & close it after replace any jamed paper inside machine
Feb 11, 2014 | Xerox WorkCentre 6015Ni Printer
310, 311 318 paperjam can not find it
is the paper in the fuser, try turning the fuser, sometime there are some small pieces of paper stuck in between the fuser and pressure roller
Feb 18, 2010 | OKI C3200n Led Printer
Says paper jam but NO paper is in the machine
One problem i found with those printers is that over time the casting around the paper tray is wearing off and printers starts to show paperjams when there is no paperjam.
One way to fix is try and positions the paper tray better or perhaps raising it a bit with piece of wood or paper.
Cast unfortenately is too expensive to replace so if this doesnt work and you are sure there is no paperjam and nothing obstructing the sensor then replace the printer.
Nov 02, 2009 | HP LaserJet 2200D Printer
Oki B4250 PaperJam
clean and wash paper transfer roller or feed roller guide it fail timing
Sep 10, 2009 | OKI B4250 Led Printer
PAPER JAME CODE 13
Try looking for the jam from the rear of the printer. Also, using one of those compressed air cans, blow all the paper dust our of your printer, because the sensors usually are photo-electronic sensors, and paper dust wil register a paper jam, even when no paper is in the printer.
Jun 19, 2009 | HP LaserJet III Printer
My printer says there is a paperjam but I don't see a paperjam.
its a mechanical problem ...
check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
May 24, 2009 | HP DeskJet 3653 InkJet Printer
Kyocera paperjam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Office Equipment & Supplies
I have a cano MP210 and it is flashing E3 and the alarm light is on. I have tried many things and it still won't work.
Error code E3 stands for paperjam
Take a look so you dond have a paper jamed, not even a litlle pice of paper, clean the wheels where the paper passes
Good luck to you
Dec 17, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
PaperJam
I found that the little plastic hinge guide that supports/aligns the scanning area with the printer (stage 4 on the internal paper jam problem) was misaligned. I just removed it and the printer now works OK
Aug 28, 2008 | Samsung CLX-2160N All-In-One Printer
Printer
Sometimes just a teensy bit of paper stuck inside will make it say paperjam. I would check very well.
Dec 11, 2006 | Canon I900D InkJet Photo Printer
Toshiba 1370 Black and White Copier Logo
257 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Computer Links
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
