Question about Acer TravelMate 4150LCi Notebook
Hello i have a charging problem in my Acer TravelMate 4150 model,its 3 yrs old. Its not being charged at all,i mean its battery is nt gaining charge. suppose the charge level is 60%,so inspite of plugging in the AC adapter the battery is nt charging. Though when i connect it the Charging icon is showing in the all related windows/places. But the thing is that the battery is doing '1 way business'. The Laptop is doing fine with battery charge,but the charge its loosing not regaining again. when there was nt this problem the battery was giving 2hrs backup!!! So i doubt its not a battery drain-out problem. Hope you can suggest me a solution.Thank you -shubhayu Datta datta.shubhayu@yahoo.in
    Problem Solver:
  • 9 Answers
Well, this is happening to another laptop i know. if you remove the battery and order a new one and replace it it should work. Its probably just a dodgy battery. While you have the battery out, you will need to use the power cable all the time. This just happens to some batteries. Thats just my advice anyway.
PS: I am only 99.9% sure this is the right thing to do. I would check at a computer repair place too or battery world.
Posted on Dec 22, 2008
Why will my battery not charge?
I will assume you are finding the procedure to remove battery for the ACER travelmate C300 tablet PC. Best way would be to go to page 50 in the service manual available at this site.
http://tim.id.au/laptops/acer/travelmate%20c300.pdf
The battery not charging could simply be the battery is old and dead or the charging circuit is faulty. Start with the adapter in that case as it is cheapest to replace.
If you are removing parts to diagnose further then I would strongly suggest you video what you are doing in order to get back to where you started.
Sep 26, 2014 | Acer TravelMate C300 14.1 XGA LCD Display...
My acer travelmate 4230 is losing power very quickly when it is not plugged in...it seems like the battery is not holding a charge very well. is my battery just old? any suggestions?
If the battery is 2 or 3 years old or more chances are it needs to be replaced. When you charge it and it gives you less than 30 minutes it is time to replace it, ebay is a good place to start if you are considering getting a new one.
Dec 20, 2010 | Acer TravelMate 4230 Notebook
My Acer Laptop is about 3 yrs old and since the last month the battery has been running down within half an hour while in the past it used to last at least for three hours.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 25, 2010 | Acer Computers & Internet
Battery will not charge. Black box (on wire which connects to mains - sorry not good with techno!) light is on. Acer Travelmate 2480 laptop. Quite old I think, got it second hand. Does it just need a new...
May 04, 2010 | Acer TravelMate 2480 PC Notebook
I have a acer travelmate 2428anwxci. When I plug in
Thsi problem arise when you have a bad BIOS version. Normally, you should update the BIOS with the latest version. go to www.acersupport.com and download a latest BIOS together with the flash tool. you should be able to charge the battery normally.
Feb 25, 2010 | Acer Computers & Internet
Travelmate 4150 not able to find the battery
you can also use your laptop without the battery, just plug its power cord while using for the mean time, the battery may be has low charge to the point that it can't turn on your laptop, insert your battery then plugin your power cord to charge your battery
Oct 19, 2009 | Acer TravelMate 4150LCi Notebook
Battery works and then doesn't
first off all remove the batterey and just connect the laptop directly to the power adaptor and check out is it working properly with out battery as it should work without battery on power adaptoir.if it works that means the battery is faulty if it does not works that means the laptop main board is having loose connection problem get it repaired do not do it your self very risky.
Mar 02, 2009 | Acer TravelMate 2201LCi Notebook
New 6600 mAh battery won't charge
Is the AC adapter the original that came with the laptop or is it a replacement?
Check the label on the laptop (on the bottom of the laptop) for the voltage and current requirements.
Check voltage output of the adapter with a multimeter, this voltage should be slightly higher that the voltage than what is shown on the adapter's label because there is no load on the adapter.
It could be that the current (amps) that the adapter is delivering less power than the laptop's requirements, whilst it can power the laptop it may not be sufficient to charge the battery fully.
Try charging the battery overnight by shutting down the laptop but leaving it connected to the mains. Then boot up the laptop in the morning and check the battery's charge state. If the battery is at or near full capacity, then the problem is a (part) faulty adapter.
Jan 07, 2009 | Acer TravelMate 8200 Notebook
DRIVERS FOR TRAVELMATE 4150 nlcI
OK go to the ACER web download site and find ya exact model lappy and then Download the drivers for ya OS..
www.acer.com
OR simply type into Google search.......
Audio Driver ACER Travelmate 4150 xp download..
ethernet Driver ACER Travelmate 4150 xp download..
GL
Aug 06, 2008 | Acer TravelMate 2300 Notebook
Batter Not Charging
if your unit can charging battery from 0% to 28%, it's mean your battery is bad.
But if your unit can't charging battery at all, it's mean your motherboard is bad,
Jan 25, 2008 | Acer TravelMate 2300 Notebook
Acer TravelMate 4150LCi Notebook Logo
157 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
