Question about Indesit 24 in. D63 Free-standing Dishwasher
Dishwasher doesn't seem to pump water through
When i switch on my dishwasher it starts up fine and goes throught the process of draining the sump first. however after this, when the water is meant to be pumped into the dishwasher only a small trickle comes out of the outlets. also the dishwsher makes a funny churning sound suggesting its sounding like there could be a blockage in the pump. the timer isnt faulty ( i think ) as its still engaging its normal cycle. i'd appreciate any feedback, thanks.
  • Murfsmoke Feb 29, 2008
    hot point sometimes water comes in to wash sometimes dont. seems like if you play with swith/timer it randomly workds. hotpoint diswasher
  • mauve May 19, 2008
    I HAVE CHECKED ALL PIPES AND TUBES, ALL CLEAR, THE MACHINE STILL GOES THROUGH CYCLE BUT NO WATER, CAN YOU HELP.
    Sergeant:
  • 236 Answers
Add more water to see if it is not filling enough. if it is there may be a problem with the wash pump either a blockage or it seizing.
Posted on Jun 01, 2007
Dishwasher starts program, then few mins in pause/start button flashes "insufficient water supply". Checked all hoses and all clear. Anyone? Thank you. Glen
As soon as the waser begins the wash cycle pause, open door record water level in sump.
Close door and continue cycle until machine faults and stops.
Open door, record water level in sump.
Compare before and after. If level is low that the flapper valve that allows the water to drain is stuck open and the water is draining into the sink as the unit is washing.
To confirm, if the washer drain hose is connect to the neck of the disposal or sink drain, observe the drain after restarting the wash cycle from the beginning. If water is trickling out from the dishwasher while it is washing then it is confirmed the drain door is not closed if equipped with that configuration.
All washers have a process and hardware to drain. Some have a sepperate drain pump
Hope thisd helpd?
Jun 29, 2017 | Dishwashers
I have a Baumatic BDI631 integrated dishwasher which has started making a strange noise when the water is coming out. It is washing fine but makes a buzzing noise when discharging the water which soun
It sounds like something's trapped in the pump touching the impeller. Drain the machine, isolate the electrics and see if you can access the pump, you may find a piece of debris or small article in the pipework.
Jan 05, 2015 | Baumatic Dishwashers
Aeg slimline dishwasher 64800. AL5 alarm, but fills up
This control procedure is in operation only during the cold wash and heating phases.
  • Once the pressure switch has closed in the "full" position, it must remain "full" until the subsequent drain phase; if the pressure switch signals "empty", the fill solenoid is activated for a period equivalent to the period of aperture of the pressure switch.
  • The maximum aperture time for the pressure switch (T) during the entire phase is 60 seconds; if this period is exceeded, an alarm condition is generated.
Alarm: AL5
Possible causes:
  1. Dishes upside down
  2. Central filter clogged
  3. Siphon effect created in drain hose
  4. Leakage in sump - pressure switch tube.
Dado
Mar 02, 2014 | AEG 18 in. Favorit 64800 Free-standing...
Water does not drain,how do I access the pump
Hi jolanda03,
Remove the Top Panel, fastened by 2 screws at the back, Then remove the right Side Panel, you should see the Drain Pump attached to the sump. To test it, you could attach direct power to the two pins on it (Alternating current, so position of connectors unimportant). If it works, it could be either that it is not receiving power from the PC Board, or the sump is clogged inside (Filter).
Hope this helps, if it did please rate with 4 thumbs up. A testimonial would be nice too. :-)
Apr 21, 2011 | Dishwashers
Dishwasher pump keeps running
This is caused by a water leak into the base pan,it will trigger the anti flood and the machine will continously drain out even with the door open,you need to establish what is leaking,if you leave the appliance standing for a few days it will start again as the water will evaporate however if the fault returns you will definetly have aleak on the appliance which will require further investigation.
Jul 29, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
I have a Beko DE 2541f slimline dishwasher and it seems to have got stuck draining - have switched it off and removed power completely but it just starts draining as soon as it's switched on again. Any...
hi there.......your problem can occur when the sump of your apliance becomes flodded....this activates the anti flood switch which causes the drain pump to run....soloution is to dry out the sump or remove machine from its location...tilt it back letting excess water flow from the sump..check that all fixing screws in cabinet are secure including the air vent (mid way u the left/rt hand side of inner cabinet...
test appliance again if problem persists you will need to change the water flow meter
regards Sir Galahad
Jun 29, 2009 | Beko 24 in. D3731F Free-standing...
GE Dishwasher model PDW8200J03BB stopped draining. Removed the drain pump, checked with Voltmeter and there is resistance on ohms X10 of about 3. The flap is in place so water isn't shooting back into the...
clear the line from the air gap to the drain,, if the rest is clear the only thing it can be is the propellers on the pump, i which case you will need to change the pump
Jun 06, 2009 | GE 25 in. Profile PDW8200J Built-in...
Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Mar 12, 2009 | Asko D3152XLSS Stainless Steel Built-in...
Pump continues to run
make sure you dont have water sitting under dishwasher in tray. it can cause pump only to run. If there is water in bottom, look under water valve, there is a float-is it surrounded with water?
Jan 01, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Beko Freestanding Dishwasher
Hi there ....this condition is ususally caused by a water leak into the sump of the dishwasher which activates a safety switch to run the drain pump..preventing the appliance from being used....Remedy...tip the dishwasher back in the head allowing excess water to exit from the sump...then with the door open check that the air vent lock ring is secure, thet the salt unit retaining ring is secure..and finally that the filter unit to base screws are secure...this done re-start and you should b fine
Jun 28, 2006 | Beko 24 in. D3731F Free-standing...
Indesit 24 in. D63 Free-standing Dishwasher Logo
273 people viewed this question
Top Indesit Dishwashers Experts
Eric Taylor
Marvin
Marvin
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
