Question about Hitachi 53UWX10B 53" Rear Projection Television
Mitsubishi VS-5003R TV is on but won't connect to cable.
When the power goes off, the cable box disconnects from the TV. The TV power is on but defaults to a black screen with green letters at the top - "TV___:___ and EXT-1". It also says A003 or B003 when I switch antennas. Any idea how to get the TV to hook back up to our cable? Thanks!
  • 905 Answers
This is the service menu , try to exit out of it , if you can't turn off power on both cable box and tv then unplug both of them and disconnect the cable from the tv , leave it unplugged for at least 10 min , then try it again , if it still does it then the crystal that is connected to the IR sensor and EEPROM IC needs to be replaced as the IR sensor should be also replaced
hope it comes out of that!, if not we can try to set the menu settings for it being like a clock and #1 on the remote to exit the menu
let me know what happens , thanks,
Posted on Oct 21, 2008
  • jason Oct 21, 2008
    a = antenna1 input
    b = antenna2 input
    analog and digital
Remove screen on Mitsubishi VS-5003R to clean the inside
screen unit is removed from front--remove speaker grill and some screws at bottom of screen and it lifts up and off.
Jun 05, 2012 | Televison & Video
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Slight ghosting and color alignment problems
comvergencia that reviews the misaligned with the remote control and traps
Jan 05, 2010 | Televison & Video
Tv does not come on you can here it sizzle when you push the power button but no sound are picture its a mitsubishi vs-5003r prohection tv
a "sizzle" sound is not ggod especially if you can "Smell" it, I say call a service tech to give an estimate, if you are not electically inclined
Apr 20, 2009 | Televison & Video
Mitsubishi VS-5003R close caption
That is so old I can't find specs on it.If you have a cable box, Directv or Dish Network you can turn on cc from the Receiver box or even an antenna converter box
Mar 29, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi VS-5003R Tuner Out
the tuner is where the cable hooks up on the back of the tv.its out and needs replaced.thats what the message means
Jan 24, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Mitsubishi VS-5051
It is called Text in your Close Caption. Turn off
Nov 12, 2007 | Mitsubishi VS-50605 50" Rear Projection...
PVAT!!Look for bad connects--start w/easy first. Power supply,then vertical IC pins,then regulators.Take your time,be thorough.
Oct 01, 2007 | Mitsubishi VS-4543 45" TV
Mitsubishi vs-45609
You should have two antenna inputs A & B. Most commonly the RF or TV output on the back of the cable box is connected to antenna A and the TV has to be set for channel 3 or 4 depending on which station is not available in your area. If you don't get a picture on 3 or 4 then switch the cable box to antenna B or find the switch on the remote that allows you to remotly switch antenna inputs. If your TV has a connection that says "cable out" don't use that one as that is for a more complex setup. I hope this helps you.
May 02, 2007 | Mitsubishi VS-45609 TV
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
41 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
