Question about Brother MFC 8500 All-In-One Laser Printer
Brother mfc 8500 clicking noises
Our fax machine which is a brother mfc-8500. makes clicking noises when it receives a sheet of paper. Whether it is a fax or a print. They all still come thru, and we don't seem to miss anything, it just clicks really loadly. I assume it is a roller problem but can't seem to find anything that looks like it is sticking out or not in the right place. Anyone know how to fix this?
  • 3 more comments
  • Anonymous Nov 05, 2007
    I have had the same problem with my 4-5 year old MFC 9660, i.e. clicking noise but printing OK until now. After a week holiday break the clicking noise is there but the paper feed no longer works and changing the drum unit has not made any difference. Hope someone has a solution.
  • rbush May 09, 2008
    I have the same problem ... printer now jams the paper on every attempt to print or receive a fax. Seems like it might be a roller problem. Replacing drum doesn't help.
  • Anonymous Jul 13, 2008
    Brother mfc 8500 clicking noises problem
  • mjadams7 Jan 06, 2009
    I have had the same peoblem for a long time. Now a different problem has occured while trying to print. It makes a clicking sound similar to baseball card on a bicycle spoke and gets jammed. Solution might be a new machine?
  • mjadams7 May 11, 2010
    understand exactly , but the problem persists if i close the cover without inserting the toner cartridge back in. it sounds like it is coming from just in back of where the toner would go
If you open the cover and remove the toner/drum unit, you will see (on the left side as you remove) a small hole with two triangle teeth.
on either side of this hole are two small phillips head screws. this is the problem we had with our clicking noise. As the machine tries to turn the toner/drum, the innards of the toner are becoming harder to turn. So the part of the fax machine that fits in the hole end up stripping the teeth in that hole. If you have an old toner cartridge, you can remove the gearing from it (where the small phillips head screws are) and use it to replace the gearing on the newer cartridge. Or go buy a new toner cartridge.
Posted on May 09, 2008
We have a Brother MFC -8500 fax machine. Every day
The Drum unit is a consumable.
Buy a new Drum from Staples , Office Max etc and replace it soon.
It will stop and refuse to print when a certain page count is reached.
Jan 07, 2011 | Brother IntelliFAX 2800 Laser Fax
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
My fax machine keeps saying there is a paper jam.
look on the bottom of your drum unit. there is a sensor opening that might have a tiny piece of paper in it, not allowing the sensor flag to reset. if thats not it, closely inspect behind rear door.
hth,
razors
Apr 05, 2009 | Brother MFC 8500 All-In-One Laser Printer
When fax, the paper cannot be loaded.
The machine clicks when you plug in the power is the gear porblem, most likely the gear is broken.
the one that does not pickup paper is the roller.
you can change the roller form the licker to this one.
hope that helps.
Dec 01, 2008 | Brother MFC 8500 All-In-One Laser Printer
Help
rest teh machine by shut off the machine and pull out the pluug. wait 2 minutes and plug in the power and turn on the machine.
May 29, 2008 | Brother MFC 8500 All-In-One Laser Printer
Brother MFC 8500 receives faxes and does nothing else
Check to make sure that the PC Fax Function is turned off. I noticed after I connected the 8500 to my PC and installed the software, I too could no longer receive faxes and it was corrected after I turned this PC Fax function off.
The function is located by:
  1. Press the MENU button.
  2. Select Option 2.
  3. Select Option 1.
  4. Select Option 8 (PC Fax) and turn that function OFF.
Hope this helps!
Apr 28, 2008 | Brother MFC 8500 All-In-One Laser Printer
Fax receiving problems
Check whether there is any paper stuck inside.
Mar 24, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
MFC-8500 fax operation
If there is noise on phone line machine reduces speed to enable fax to be sent. Have line check or try machine on different phone line to ensure it is a phone line problem.
Dec 03, 2007 | Brother MFC-8500 All-In-One Laser Printer
Brother MFC 8500 All-In-One Laser Printer Logo
497 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
