Question about Stoves Sterling 1100E Stainless Steel (Electric) Kitchen Range
My whirlpool cooktop front right radiant burner stoped working
How do i fix this problem and where do i get parts. thanks.
  • 417 Answers
Hi
You have to remove the old one first by disconnecting the wire teminals and the fixing screws. Remember to disconnect the power before starting work,
You can get the parts from www.pcappliancerepair.com/whirlpool-range-oven.php
Hope this gets you sorted.
Posted on Oct 21, 2008
Inner burner-- front right burner - does not heat up
you have either a bad switch or a bad element. If you plan on repairing this yourself, turn off the power to the unit BEFORE removing it from countertop. A continuity tester will be needed to properly test components. Nice Saturday morning homeowner project.
Mar 07, 2016 | GE Profile 30" Electric Self-Clean Drop-In...
The front right burner is not working
If the radiant burner is not working, but the other 3 are, then you will need to replace the burner with this part.
Feb 09, 2011 | Frigidaire 31 in. FEC30S7E Electric...
Kenmore electric cooktop not working on low eat
If it was the burner element it either would work or not (no in between)
It has to be the switch
Apr 13, 2010 | Kenmore Elite 44173 30 in. Electric...
My whirlpool gas cooktop on sparks on left front burner. Model scs3014gq1
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 01, 2010 | Whirlpool SCS3014 Gas Cooktop
Jenn Air Gas cooktop burner ignition
Hi JHMcdona
Most likely the electrode for the right burner is defective. As well as the switch may also be defective (is shorted because of pressing hard on it trying to make it work!!). Change the electrode and igniter switch of the right front burner.
Regards
Aug 26, 2009 | Miele 35 in. KM326G Gas Cooktop
Radiant cooktop stays on at low settings. fix?
it is the burner switch that needs to be replaced.the thermocouple function is built in the switch.
Aug 17, 2009 | Cooktops
One of my kitchenaid cooktop burners does not work
go to searsparts.com could be switch or burner or high temp fuse under glass
Jul 02, 2009 | KitchenAid Cooktops
Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
May 21, 2009 | GE Cooktops
Stoves Sterling 1100E Stainless Steel (Electric) Kitchen Range Logo
193 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
marley mcelhinney
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
