Question about Bosch Nexxt WTMC 3300 Electric Dryer
NEED NEW CIRCUIT BOARD FOR BOSCH NEXXT WTMC3300US
MY BOSCH NEXXT DRYER CIRCUIT BOARD IS OBVIOUSLY FRIED. I CAN'T FIND A REPLACEMENT PART. DO YOU KNOW WHERE I CAN FIND THIS BOARD. ALSO IN RESEARCHING THE PROBLEM I HAVE FOUND SEVERAL PEOPLE WITH THIS PROBLEM; SOME HAVE IT REPEATEDLY. A RECOMMENDATION FOR A HOUSEHOLD IN LINE CONDITIONER WAS MADE. IS THIS NECESSARY WITH THESE NEW CIRCUIT BOARD RUN DRYER UNITS? WHAT IS CAUSING THIS TO FRY?
CIRCUT BOARD STICKER SAYS AKO 546 822-01 UL E136856 BSH 5070 00397
SOURCE: Bosch Nexxt Electric dryer tumbling but not
Unplug the dryer first. Then remove the back cover on the dryer. You will find the red reset button underneath the dryer drum. If the button has been tripped, you will feel and hear it click when you press it in. I would suggest that you vacuum out any dust or lint that has collected inside the unit before replacing the cover.
Posted on Apr 26, 2009
SOURCE: Bosch nexxt 500 series dryer
I just had the same problem, motor runs but no heat. I had a fun time figuring out how take the front panel off, hint the rubber seal comes off easily. It looks like mine tripped the resettable over heat sensor. So far so good.
Posted on Oct 10, 2007
  • 213 Answers
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Posted on Nov 20, 2007
hunter19_46m
  • 7482 Answers
SOURCE: The dryer (Bosch Nexxt 500) makes a loud grinding
The noise could be your drum rollers need lubricant or replacement.
When the drum rollers get flat spots on them they will make a bumping/thumping type of noise.
The grinding noise sounds to me like the drum rollers are in need of lubrication.
Posted on Sep 26, 2009
Ranglo
  • 1194 Answers
SOURCE: Bosch Nexxt 500 series dryer, E:01 and lint light
This indicates the sensor near the lint filter gets too hot. This is usually caused by bad air flow.
Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting.
You may need to have it cleaned out. May be lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, there may be heat escaping somewhere within the dryer. This is only resolved by technician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Posted on Jun 27, 2010
No heat from wtmc3300us Bosch dryer. Pushed reset and the heater started working. Next load and no heat. If it tripped the overload again, what now?
Looks like you may have an over heat problem. Look for a problem with your vent system and pipes. If its partially blocked you will trip the heater over temp thermostat.
Apr 07, 2015 | Bosch Nexxt WTMC 3300 Electric Dryer
I have power to the display but dryer will not go on
More than likely you fried the belt or the motor.
Nov 06, 2014 | Bosch Nexxt 800 Dryer
WTMC3300US/01 need to locate the heater element
http://www.ebay.com/itm/Bosch-Nexxt-Dryer-Model-WTMC3300US-01-Fan-Blower-Housing-5070000460-/160948680806?pt=LH_DefaultDomain_0&hash=item257949f866
Jan 17, 2013 | Dryers
Need a new control board for Bosch Nexxt 3300 dryer... any clues where I can get a refurbed one?
Here is a link to the new board.Here is a link to a working used board.
I would personally go with a new board. You don't have any idea as to how long a used board will last. I do a lot of appliance repairs and have seen people try to save money (as I would) but there are certain things that should be bought new so you get a warranty with it. But that's just my opinion. Keep me posted.
Oct 22, 2012 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch nexxt 500 plus dryer no power
could be a fuse on the main board. open the dryer and look for one either in line to the main boasts our on the main board itself
Feb 01, 2012 | Bosch Nexxt 500 Plus Dryer
Dryer runs for approx 30 min. then turns off and lint light flashespush to restart it comes on for 1 second then turns off let it set for 30 min then turns back on Bosch model# wtmc3300us/01 vent was...
our dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 30, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
Need user guide for Bosch Dryer Model WTMC3300US/01
try this link to the .pdf file for your unit..
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0807475.pdf
best of luck,
ttfn
Oct 25, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
The dryer (Bosch Nexxt 500) makes a loud grinding noise when rotating. Any idea what this may be?
Sep 26, 2009 | Bosch Nexxt 500 Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
345 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
