Question about Epson TM-U220 Matrix Printer
Epson TM-U220D Receipt Printing Problem
We have installed Quickbooks 2007 and connected our Epson TM-U220D printer to the computer in order to print customer receipts. We can get the printer to print the test receipts but with one driver it prints just a skinny column of text (about 1/3 to 1/2 of the width of the receipt tape) and with the other generic driver that we have installed it prints the full width but is positioning/wrapping the text in a weird way. Has anyone successfully figured out how to format their receipts from QB to print to the Epson printer? We'd like to also know how to set what we specifically see on the receipts. Thank you.
  • Anonymous Nov 25, 2008
    same problem with windows xp
Mau download driver epson tm-u220d ga ada...
klo mau cari dimana yah
Posted on May 11, 2009
Will not print longer receipts. How do I fix this problem
PDF]TM-T70II Brochure - Epson
www.epson.com/alf_upload/pos/pdfs/.../brochure_tm-t70ii.pdf
EpsonThe TM-T70II prints receipts and graphics at the same fast ... Print technology, the TM-T70II can print ... It also offers Serial, Ethernet and USB options ... long-lasting autocutter and all-front access. ... are easy to use and do not affect print ... Space-Saving Thermal Printer with Easy All-Front Access ... Epson Dark Gray (EDG).
Epson C31CD38A9971 TM-T70II Front-Access Thermal ...
www.newegg.com > ... > Receipt Printer > Epson America
Newegg(Do not use your browser's "Refresh" button). ...... Streamline your POS system withEpson's space-saving TM-T70II printer. ... Ethernet and USB options, enabling flexible mobile and web-based receipt printing. ... including drop-in paper loading, long-lasting autocutter and all-front access. ... Color, Epson Dark Gray (EDG).
Epson TM-T70II Series - Epson
www.epson.co.uk > Home > Retail
EpsonEpson TM-T70II thermal receipt printer for barcode, ticket printing is for ... The latest innovation in Epson's long line of receipt printers are its series of smart ... same
Jan 27, 2016 | Epson T70II - SPACE-SAVING - PUSB & USB -...
Cannot print from command prompt - Epson U220D Windows 7 32-bit New parallel port with driver New centronix to parallel cable Epson driver APD_455dE (I was using Windows 7 64 bit with a...
The Epson works fairly well with XP. It is to be connected to
a parallel port, usually LPT1
using an IEEE certified parallel printer cable. The computer BIOS
setting is best set for standard parallel port, SPP, bi-directional port
or similar. If possible, do not set it to ECP or EPP or ECP & EPP.
The only native driver for the printer is on the Windows CP CD. Install
using the Add Printer wizard.
The Epson LQ-860 drivers, and a few others, can be used. Using these
drivers, you will discover that the printer actually has some resident
fonts (in printer ROM) that are not accessible from the Stylus
driver. However, with this driver, graphics printing quality is
compromised.
Windows 9x drivers _cannot be used_.
Let us know.
Tom
MSMVP
Windows Shell/User
"the_best_of_fools" <thebestoffools@discussions.microsoft.com> wrote in
message news:E7A27E3E-81E7-46CC-B38E-C63AA474A239@microsoft.com...
:I have an Epson stylus color 600 I can't get to work with Windows XP.
This
: printer worked fine with my old Mac.
: I've tried everything I could and nothing is working. The printer is
: connected to
: the computer via parallel LPT1 port. I've installed the WindowsXP
resident
: drivers
: for this printer model (the Epson drivers are too old and not
verified). The
: computer doesn't detect the new hardware with Plug and Play when
turned ON
: (don't know why) so I had to manually Add Hardware (Printer Port) with
the
: Hardware Wizard. I'm not sure how to recognize if the LPT1 port is
active or
: not and set up properly in the BIOS? I read something about having to
set the
: parallel port to ESP or ECP depending on the printer's requirement
(which I
: don't know) in the BIOS?
: Everytime I send a test page or print from a command prompt or WordPad
: nothing happens for 1-2 minutes and then I get a "Printer Out of
Paper"
: message in the pop-up. Of course, the printer has enough paper (and I
can
: print a sefl-test page from the printer). I also tried with another
parallel
: cable and it still doesn't work. I've tried uninstalling/reinstalling
the
: printer's driver many time and it's still not printing.
May 13, 2014 | Epson TM-U220D Matrix Printer
Epson TM-U220D. Parallel to USB connection. Which drivers should I install?
Hi Ali
The problem by doing this is that not all Parallel to USB cables work right out of the box with your equipment.
What you need to do first is make sure that your computer sees the device through the cable. Then when it prompts you for the drivers for the printer install the driver set (parallel) the connection should not matter at this point. However the step of the computer detecting the device first is very important.
I hope this helped.
Philipp
Apr 16, 2014 | Epson TM-U220 Matrix Printer
Printing arabic characters font
What is the question? Shouldn't you load use.package_name as is done in Java?
Nov 14, 2013 | Epson TM-U220 TM-U220A, TM-U220B, TM-U220D...
To install Epson printer TM-U220PD Model M188D
What is the baud rate of the EPSON TM-U220D MODEL M188D?
Feb 14, 2010 | Epson TM U220D Printer
How can I connect an Epson TM U220D Printer to a PC?
You can connect it using a SERIAL NULL MODEM cable, You can download the driver from epsonexpert.com after you register they will send you username and password to login, go to technical resources and select printer model and download the APD304E driver
May 02, 2008 | Epson TM U220D Printer
Epson tm u220
What type of interface card are you using to connect printer to your computer?
Mar 14, 2008 | Epson TM-U220 Matrix Printer
Cant print even test page
hit "start" and go to Printers and Faxes. In the side bar, choose add a printer, follow the instructions in the wizard to automatically, install and use the printer. Also check and make sure that you have any software that comes with the printer, as some of them need it in order to run. If all else fails, uninstall the printer by selecting it in the Printer and Faxes, right clicking and select DELETE. Then follow the above steps to reinstall it.
Jan 18, 2008 | Epson TM-U220D Matrix Printer
Having problem installing tm-u220d printer on parralel/serial connection
Hello Sanjaypk,
Printer problems can be a real headache.
This definitely sounds like a driver issue because you are able to print a test page so that tells us the computer is successfully communicating with the printer port. What is happening here is the Computer is communicating with the printer through the Operating System (Windows or Apple etc) but the driver IN the software for the POS is not. You didn't mention the computer Operating System you are using or the POS software but the dates of each are ctitical.
The tm-u220d is a high speed printer so make sure you set your LPT1 settings for High Speed Bi Directional printing. (You do this in the Printers Configuration area.)
As far as a driver, check the dates of the driver and look for updates. If you like what I've told you so far then let me know and I'll be glad to assist you further.
Best Regards and Best Luck!
Charlie
Dec 01, 2007 | Epson TM-U220D Matrix Printer
Epson TM-U220 Matrix Printer Logo
1,399 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
