Question about Honeywell Heating & Cooling
I want to try replacing the electrolytic capacitors Honeywell Part 136912 in my Honeywell F50A Electronic Air Cleaner with locally available parts. What are the capacitance and voltage ratings?
In my F50A1066 the capacitors are .022 uF (microfarad) with a 6000V rating. One is blown on my unit and I found a close replacement on Ebay (.02uF with a 16000V rating) for $5.00.
Posted on Dec 03, 2010
  • 1 more comment
  • laserwelder Dec 03, 2010
    The capacitors on my F50A1066 air cleaner are .022uF with a 6000V rating. I found a close match on Ebay (.02uF, 16000V rating for $5.00.
  • laserwelder Apr 10, 2014
    this is laserwelder again. I replaced those capacitors in my Honeywell air cleaner several years ago and it is still running great. So if you have one that does not work replacing the capacitors may fix it for you. You need to be able to solder and of course you need to turn it off before working on it - there are 1000's of volts inside when it is switched on.
    Add a Commen Probably even better to disconnect the unit before working on it rather than turning it off. Capacitors can also store a charge after it is switched off so short out the capacitors before you touch them. If you don't know what I mean don't try it yourself!
My Honeywell Type No. F50A Electronic Air Cleaner arced continuously even though I had cleaned it a few days prior. I shut the unit off and removed the air cleaner cells. Is it safe to run the furnace...
Yes you can run the furnace with out the electronic air cleaner for awhile.... It you are in a very dusty conditions than I would not run it very long a day or two....because you will not have any protection for dirty getting stuck on the evaporator coil or if you have a 90% gas furnace the secondary heat exchanger...and restricting air flow.... You can put in a 1" pleated air filter the same size as the total of the two cells in place of the cells till you can get the electronic working..... Sounds like either something big is caught across the cell plate or they are still wet and have not dryed out completely. Hope this helps.
Mar 02, 2011 | Honeywell (F50F1032) Air Purifier
The Honeywell electronic air cleaner constantly "snaps" even though it is clean. I have inspected the wires and fins, clean and spaced properly. Any suggestions?
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal .Remove both the cell and check clean the bottom portion by using a vacuum cleaner attachment. If the snapping continues with the cells remove contact your contractor.
Mar 05, 2010 | Honeywell (F50F1032) Air Purifier
I have an F50f electronic air cleaner. none of the
you need to change the power supply please contact your heating and cooling contractor for service on the unit.
Mar 03, 2010 | Honeywell (F50F1032) Air Purifier
Honeywell F50e electronic air cleaner indicator light stays on
Could be a faulty sail switch in the air cleaner that keeps the air cleaner on even without air flow.
Dec 20, 2009 | Heating & Cooling
Honeywell F50A does not clean well
sounds like it is working. You could replace the cells and prefilters with a disposable box filter that fits.
Sep 23, 2009 | Honeywell (F50F1073) Air Purifier
Electronic Air Cleaner problem
The presence of “white dust” is actually an indicator that your Electronic Air Cleaner is working properly. The Electronic Air Cleaner can only filter the particles that are passing through your system’s duct work. The staining particulate is generally lighter, and more able to be drawn through the return registers in your home, leaving the heavier, non-staining particulate behind. This heavier, non-staining particulate settles out of the air and is left behind on your furniture: because it is more visible, it may appear as though there is actually more dust in your home than there was prior to installing the air cleaner. To ensure that more particulate is able to reach the Electronic Air Cleaner to be filtered, you should make sure that the return registers are clean and not blocked by furniture.
Apr 29, 2009 | Honeywell (F50F1073) Air Purifier
I have a Honeywell Electronic AIR Cleaner model F50 F1099 and 2 of the nine wireson the right side of the cell broke while washing the unit. Can we obtain replacement wires?
yes, we have them in stock.  you can email, he's our parts manager, he can get you the cost and availabilty of them. Chris
Dec 02, 2008 | Honeywell Heating & Cooling
I have a Honeywell electronic air cleaner hooked up with my heat pump... I have not used it for a long time because when I turn it on all it does it pop and snap.. I also forgot if the mesh metal filter...
replacement parts (cells, prefilters & postfilters)
All replacement parts for an air cleaner are available through a licensed heating and cooling contractor.
May 28, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
107 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
