Question about Whirlpool AWM6120 Front Load Washer
My washing machine wont drain or spin and is making a funny noise and smells of stagnent water. could this be the filter? how often are you supposed to clean the filter? (it hasnt been cleaned since i got it 8 years ago!!!)
  • Anonymous Mar 15, 2014
    filter at front has been cleaned
    President:
  • 1,294 Answers
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Posted on May 21, 2007
Stagnent water smell while filling
I found that running about a quart of white vinegar through a cycle with hot water and no clothes or detergent takes care of the musty smell. Vinegar removes detergent build-up.
Nov 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer was filled with water but wont spin.. makes little noise but no spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 18, 2011 | Maytag PAV5157A Top Load Washer
It will spin but the water does not come out, then it makes a funny sound-like a high rattle noise. We have never had any problems - we checked the hoses, they are clear. I has worked like a tip for years,...
heatman101
Aug 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Hi. i have had funny noises during last couple of washes. now washer wont drain programs are responding fine but washer keeps filling up and not draining.water backed up and came out of the drawer hotpoint...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 18, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Wont spin the water out
check for the DRAIN MOTOR PUMP , located where the DRAIN HOSE is attached to ,it could be clogged,
hpe it helps , AJ
Dec 21, 2009 | Frigidaire GLTR1670A Front Load Washer
Whirlpool Ultimate Care II - making funny noise
this is probably a bad motor coupling, you have to take the cabinet off, then the drain pump, then the motor, the coupling is located between the motor and the trans
Aug 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool AWM1200 washing machine wont advance at certain stages
there is a little motor in the selector switch that moves the dial around.  This little motor is defective and needs replacement.  Sometimes it's sold separately and sometimes you need the whole timer.
Apr 01, 2009 | Whirlpool AWM6120 Front Load Washer
AWM8121 Drain/Spin cycle stops
it seems to point to blockage in drainage pipe from drum likely to be a lost sock remove pipe and check
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
Whirlpool noise
Ok can you take the front panel of the washer off easily?
If you can look for the motor pump assembly. Start the washer with no load, turn the water level down to the small and fill with water when it goes into agitation does it make the noise? if not turn timer to spin and see if motor makes the noise.
One other thought, maybe the smell is coming from the dryer?
Let me know. I wont be on line again until Friday Sorry
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
Not rinsing
check and see if its pumping out water, if not it may be the pump.Close Ire.byeps,something caught in it
Dec 27, 2006 | Whirlpool AWM6120 Front Load Washer
Whirlpool AWM6120 Front Load Washer Logo
238 people viewed this question
Sal De
Marvin
Marvin
jimorris77
