Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Clearing codes on liftmaster garage door opener with yellow learn button
Have a liftmaster garage door opener with a yellow learn button. tried to add a wireless keypad, but was sold the wrong one. since then, the garage goes up or or down with what appears to be other peoples garage door openers. I need to clear the codes and reprogram, but I have tried holding the learn button down for 6 seconds, 30 seconds, etc, but the led does not flash to indicate the codes are cleared, and the unit continues to open when other controllers are pushed. Don't know if there are different instructions for the yellow learn button controller, or if you have to jumper something. Help much appreciated.
  • 2 more comments
  • Anonymous Nov 15, 2008
    I'm having exactly the same issue. If I find out how to clear out the codes, I'll let you know.
  • Anonymous Mar 01, 2009
    I am having the same issue with mine, have you been able to reslove the problem?
  • ic4paws Apr 19, 2009
    I have the same problem. Thought I was going nuts! :o)
  • ruffnerpkl
    ruffnerpkl Feb 06, 2012
    Has anyone resolved this issue I am having the same problem
    Champion:
  • 244 Answers
You seem to be doing right thing, hold learn button for 10 seconds, this should clear out all coded items; keypads, remotes.
Posted on Jan 15, 2009
  • abelardo_us Dec 30, 2010
    I have the same problem. This recommendation haven't fixed the problem
2 Suggested Answers
  • 3197 Answers
SOURCE: Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: I cannot reprogram the keypad outside the garage....
Make sure the battery is good and then locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this button and then walk over to the keypad and key in a 4 digit code and press enter.
Posted on May 05, 2010
Liftmaster Garage Door Opener won't clear codes
This was a first generation learn button model. Antiquated by current technology standards. It was a two channel system. One channel for a dip switch remote, the second for a 66LM key pad. No way to erase the programming, however, by programming in a dip switch remote (61LM with the dip switches set to new positions, and a 66lm set to a new entry code) will purge the two channels of their previous memory, now set to the the new settings.
Jun 06, 2012 | Home Security
I can't get either one of my remotes to learn to open the garage. I have followed the instructions and still neither one works. I even clear the codes after each unsuccessful time. Please help.
Hi, the Liftmaster 371 remote control operates on the 315MHz frequency, ensure your receiver works on this frequency, some Liftmaster remotes and receivers operate on 390MHz.371 remote is compatible with models manufactured from 2005, and all Chamberlain Liftmaster and Sears garage door openers with a purple learn button and purple antenna.
You can find further details here chamberlain-liftmaster-garage-opener-parts
Aug 25, 2011 | liftmaster 371 Remote Transmitter
Trying to chg code on garage door opener have cleared by following instructions. I am trying to reprogram remotes and is not working
Hold the button down on the remote while you press and immediately release the smart/learn button. Do this for each remote you have.
Dec 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to reset older 1/3 HP Opener with a yellow learning button
To clear all codes.
Hold down the yellow button for 30 seconds.
Now you can program remotes and keypad.
Remotes - press and release yellow button. press button on remote and hold for 5 seconds. The next time you press the remote the door should move.
Keypad - press and release yellow button. within 20 seconds put in desired code press and hold enter button for 5-10 seconds. again the door should move the next time you put in the code.
Hope this helps
Nov 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
New code entry does NOT override old code on Craftsman 315 keypad
yes. Press the learn button for 8 seconds to clear the remote memory. Reprogram all remotes and keypad
Feb 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Change keyless entry passcode for chamberlain model 4100 door opener
You have to press a Yellow/Purple button on the back of the garage door opener unit.
It is the LEARN button. Then enter a new four digit code into the keypad and press the enter button.
The unit should click and the lights should flash. This acknowledges it has learned the new code.
Aug 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
3,157 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
