Question about Whirlpool AWM6120 Front Load Washer
Hoover washing machine
What is the water bottle on the back of the drum used for?
    Champion:
  • 249 Answers
In case your thirsty!no I'am jokeing of course it works the water level switch if it blocks the machine would overfill,top of the morning to you Eire
Posted on Dec 15, 2007
Hoover optima 614 drum wont spin
Either a broken drive belt or a failed transmission.
Jan 12, 2015 | Hoover Washing Machines
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
Error number 2 appears on Hoover AAA whisper 1400 washing machine - any help? When it appears which is becoming more regular that it use to be I usually end up putting the washing through a quick spin,...
I downloaded the manual from Hoover website. Error number 2 relates to the washing machine not filling up with enough water. Check the water supply and correct angle of the pipe.
Sep 15, 2009 | Washing Machines
My hoover washing machine wont spin. I have tested the motor and this is fine. What else could it be?
If you have checked condition of carbon brushes in motor and they are ok.Check the valve at the back of drum(turn of and disconnect power supply) this valve is situ at the bottom of rear of drum. it may look like a small plastic bottle with a rubber pipe that goes up to the top of machine. undo clip and pull it out carefully, use a pipe cleaner to clean out inside of drum and wash and rinse out valve. Replace in order of dismantling. only a small job. One tip if you can is to tip machine backwards draining out any water and gunge from back of drum after cleaning out. Good luck, and let me know how you get on.
Sep 03, 2009 | Hoover AAA160 Front Load Washer
How to clean the inside of the machine
Go to the store and buy a bottle of CLR. Run a few cycles of it (without the clothes in there, of course!). Make sure you run a few cycles of just straight water before you attempt to wash clothes. That should do it. I've also heard of people using powdered lemonade to clean the inside of dishwashers, too. Maybe try the powdered lemonade first if you're squeamish about damaging something.
May 21, 2009 | Hoover HTC243 Top Load Washer
Water leak at rear of drum on Hoover Nextra HNF 3157 washing machine
The outer plastic casing around the drum was cracked by change left in a pocket. I fixed it with a secondhand casing
Jul 26, 2008 | Hoover Washing Machines
Water Accumulating in Washing Machine Drum
Could be draining from your sink outlet. Ensure the outlet pipe is routed higher than the sink trap. Normally attached underside of the work surface.
Mar 04, 2018 | Hoover Washing Machines
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Hoover ab130 water won't empty from drum
unselect the option button "crease guard or easy iron" it will will spin normally! (ex hoover engineer)
Jan 08, 2008 | Hoover UltraCare HC6 130M Front Load...
Whirlpool AWM6120 Front Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
