Question about Carrier Heating & Cooling
Need wiring diagrams for carrier roof-top furnace/air conditioner unit. Model 48LJE012510.
  • 1,420 Answers
It is 45 pages long so email me at the_rinnai-guy@hotmail.com and I will forward it to you.
Posted on Oct 21, 2008
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
I have a new Salem travel trailer with Dometic products. Everything appears to work fine, but when I run my furnace and it turns on, my fan blows from my AC unit. I have owned 2 other RV's but...
Yes it sure does sound like something may be wired wrong, Could you please reply with model number of your AC unit as well as thermostat model? To find your AC unit model number if you don't already have it, remove your ceiling air filter assembly, and it should be on the base of the roof unit, facing you.
The base of the roof (upper) unit will have a model and serial number, and if you see a control box where all the wiring attaches as well, get model number from that too if you will. Those numbers should make it easier to determine exactly where the problem is. Thanks.
May 28, 2011 | Dometic Rooftop RV Air Conditioner
I have a carrier visionaire model LCA061P and i am in need of the fan assembly or part # for it it. any help would be appricated
Something fell from the roof and broke the top (outside) of my
visionair a/c unit. Can I replace the part? It's near the circle on
top and finally part broke away and can't be found
Smurfsters@aol.com
Aug 13, 2010 | Carrier LCA061P Air Conditioner
Wiring diagram needed for carrier air con unit
Here ya go:
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/38ckc-c2w.pdf
May 27, 2010 | Carrier 38CKC036 Air Conditioner
Furnace overload limit switch
Here is the service manual with wiring diagram.
Dec 19, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Need wire diagram for 3207-121189
http://www.corp.carrier.com/www/v/index.jsp?vgnextoid=9d087afdef677010VgnVCM100000cb890b80RCRD
Search this web site. It has lots of manuals. It is Carrier site.
Hope this helps. Wiring diagrams are hard to find but I know they are there if you input enough of the right info.
Hope this helps and be patient while you search.
Nov 20, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a DuoTherm BriskAIr 13.5K BTU. The Dometic thermostat also controls my HydroFlame 8531-IV furnace. This morning, the furnace would not come on. I checked the wiring and there is no voltage at the...
If you look at control box at roof unit, they usually use a separate set of wires for furnace. See what colors they are attached to at harness to thermostat. Some just follow other harness, and come out at thermostat. (bypass control box) Once you've determined which 2 they are, join them together & see if furnace starts, as it should. If it does, thermostat is faulty. If not, pull outside cover off & check voltages at furnace. I'm guessing by furnace model that your unit is approx 30 ft , but if it's a park model, you may have 24 volt system on furnace or 12 volt. Another way of confirming is to go to back of furnace where air intake grille is inside your unit, and locate 2 blue wires going to furnace & remove whatever wires are attached to them & connect them together. Furnace should start up.
Jul 08, 2009 | Dometic Rooftop RV Air Conditioner
Diagram for 10kw heat pack for carrier furnace
I hope this helps
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/wd-fa4c-01.pdf
Jan 23, 2009 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
183 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
