Question about Toshiba 42H81 42" Rear Projection Television
No picture or sound on my toshiba tv
I have a toshiba tw40f80 all i have is a blinking power light found a bad fuse tn the f860 spot i replaced it but still nothing
  • 1 more comment
  • tpluttig Nov 29, 2008
    I replaced convergence IC's but now all I get is a blinking power button.
    My questions at this point are, 1) Where exactly are the fuses located. I don't see anything labeled F850, etc.? 2) When I check the resistor at R7726, I get 2 ohm's, not 2.2 as appears to be the spec. I get this reading on the others as well. Do these need to be replaced too?
  • moe524 Dec 01, 2008
    I have a toshiba projection tv model number 43A61 no picture no sound fuses are ok but the horizontal out put transistor blow out so i replaced but still no picture no sound there are 2 resitors next to the fly back transformer burning evry time i turn the tv on and i don't know the values of this resistor they look i like may be they are the same value please help me
  • Anonymous Feb 13, 2009
    but the dvd is ok
  • 934 Answers
In this unit it's likely the convergence amps are the cause. Those and possibly the 2.2ohm resistors (especially R7726) in the yoke return path - that's why you found the open fuse.
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
Posted on Oct 28, 2008
My toshiba TP50H15 color tv comes on then off and the light blink
The flashing power light on those Toshibas is usually caused by capacitors on the power board having failed solder connections. I have fixed them before by removing the power board and resoldering the capacitors. If you have experience with soldering and electronics it is an easy repair. Most shops will recommend replacing the entire board since their labor to repair it would probably cost more. Toshiba put out a service bulletin on this issue which a good technician should be aware of. (If memory serves the capacitors are C109 and C110.  Since your TV still turns on you probably haven't blown fuse F860 which often blows when these capacitors act up.)
If you would like further help with this please post a comment back here.
Dec 05, 2009 | Toshiba TP50H50 50" Rear Projection...
Toshiba tw40f80, replaced both convergence ic's, power light still blinks
Solder yoke plug and vertical IC connections.....try again.
Let me know.....T.
BTW....Tosh recommends STK-392-110's replace with -110T's
Toshiba OEM.....then there is no question about resistor value
Aug 03, 2008 | Toshiba TW40F80 40" Rear Projection...
Tv not powering up
Check micro fuses in power supply,Ex. F851,F852,etc.
Common cause is convergence IC's are bad,located on large heat sinks.let me know....T.
Oct 23, 2007 | Toshiba TW40F80 40" Rear Projection...
No pictures and no sound on Toshiba TW40F80 television
Check soldered-in micro fuses in power supply. Ex.--F851,F852.
If there is a blown fuse, identify which B+ circuit it protects.
Most common - convergence IC's bad===replace.
Need more help? Let me know.....T.
May 21, 2007 | Toshiba TW40F80 40" Rear Projection...
Toshiba 50H50: No picture or sound, red light blinks
On alot of these Toshiba TV sets, there is a fuse called F860 that will blow and the light will flash because of bad solder connections on C 810, and C 809, on the negitave terminal. I have seen many of these boards condemed by non-authorized Toshiba repair shops. Good Luck
Jun 04, 2007 | Toshiba TP50H50 50" Rear Projection...
Toshiba 42H81 Blinking on and off light
Very common problems with this TV set. Toshiba even has a technical bulliten on this and several other models of tV set. The negitve terminal of C809 and C810 need to be soldered, as there are no eyeletes in the printed circuit board. This problem could also take out the fuse, F860. Replace if necassary. Good Luck
Mar 31, 2007 | Toshiba 42H81 42" Rear Projection...
Power light blinks
I would start with C869 a 2.2 Uf at 200 Vdc in the power supply. I have replaced a fair share of those in these sets. Of course the first thing to check would be the pico fuse in the power supply regulation circuits F860 a 4 Amp Pico Fuse and if it is blown, you will have to replace Q801 the Regulator IC Str-Z4214 Part # 23906369. If you're not that good at soldering and measuring capacitance and resistance, this would be a job for a more experienced tech.
Jan 24, 2007 | Toshiba CZ36V51 36" TV
Flashing red light
You might want to check the first Item talks about power LED lights Power supply does not start
Sep 27, 2006 | Toshiba 57H81 57" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
147 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
