Question about Porter Cable Saws
Older Porter cable circular saw blade removal
Unable to remove blade for replacement
  • 1 more comment
  • Anonymous Mar 16, 2014
    how do you remove blade from circular saw
  • Anonymous Mar 25, 2014
    circular saw manual
    blade goes off to the right as i cut on a line.
    Problem Solver:
  • 16 Answers
Clamp a pair of vise-grips onto the blade to act as a blade-lock to stop rotation of the blade.
Posted on Oct 27, 2008
  • Kirk Sims
    Kirk Sims Apr 21, 2014
    i have same problem but the motor spins with the nut even with blade locked.
How to install blade in my PCL186CS
I wish I know the whole process in installing the blade. Call a dewalt technical rep.
Jun 01, 2013 | Porter Cable Portercable Pc186cs 18v...
How do u put on a saw blade for a cordless circular saw.???
First remove the battery, next make sure of the blade rotation and remove the hex bolt and OUTER flange lift the guard and put the blade on the spindle. Reinstall the outer flange and tighten the hex bolt, generally newer saws have a spindle lock to hold spindle to tighten the blade. If this is a Porter Cable like in the header you can go to dewaltservicenet.com and with your model and type number find an operators manual. Let me know if you need more assistance.
Mar 11, 2012 | Porter Cable Saws
Can a 7 1/4" circular saw blade be used to replace
Some furniture shops used 7 1/4 circular saw blade for other brands of circular saw. Based on my experienced it's applicable as long their is clearance for the blade not touch the adjustable safety cover of the unit. Thanks for asking FixYa.
Jun 14, 2011 | Porter Cable Plywood Circular Saw Blade
I have a Porter Circular Saw, 18v, Cordless, 6 and a half inch blade. I'm a novice, so I unhooked the wire latchet that held the lower guard on. I figured out how to put the saw blade on, yet I have the...
Remove the battery, take the blade back off and you will see the holes for the torsion spring. what you will have to do is start putting lower guard on but pretenstion the spring so it will fit back into the proper holes, it might be a benefit to remove the small bumper so that you can move the guard more. when installing the blade you don't remove the lower guard just retract it and slide the blade in place. Usually there is a retaining ring to hold the guard in place but I looked at a breakdown and didn't see one. Let me know if you need more assistance before voting please. Thank you
Feb 02, 2011 | Porter Cable Portercable Pc186cs 18v...
Change the blade on my porter cable 347
Here is the owners manual for your saw. It details the procedure for removing and installing a blade.
Please rate this positive if it helps!
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/En900003.pdf
Jul 03, 2009 | Porter Cable Cable 7 1/4" Quik - Change...
The saw blade on my Porter cable 423mag saw is jammed tight.
Unless you can get a wrench on it I can't see anything else on the breakdown. You are aware that the knob is Left Hand thread I hope.
Mar 22, 2009 | Porter Cable Saws
Saws Logo
1,097 people viewed this question
Top Porter Cable Saws Experts
Frank Mangiapane
Level 1 Expert
Jim Thurston
Are you a Porter Cable Saw Expert? Answer questions, earn points and help others
