Cannot get to windows
I have a IBM Thinkpad type 2652, When I turn it on a small key and a pad lock appear on the screen in the top left hand corner. How do I clear it.
Thank you.
Jim
w4jlt@bellsouth.net
  • massavic1 Mar 16, 2009
    i have a hp nc8000. a power on password is on it. how do i get it of
    Problem Solver:
  • 9 Answers
That is a BIOS power on password. If you have the password then start up the laptop and press f1 to get to the bios. It will prompt you for the password type it in then you will gain access to the bios. In the bios go into security then password then power on password. type in the old password then leave the next 2 spots blank and that will clear the password. If you do not have the password then I would suggest asking whomever you got the laptop from and ask them for it. if that is not a possibility then look for a copy of Hiram's boot disk and use that to hack it.
Posted on Oct 22, 2008
Can't get past lock code
Laptop computers have the advantage being portable and self-contained, but among their drawbacks is a keyboard without a separate number keypad. While for most applications number keypads are unnecessary, they can be useful for data entry. Laptops sometimes provide a number keypad by giving certain keys double duty, allowing them to enter numbers rather than letters when a "Number Lock" setting is turned on. Number Lock, however, can get turned on accidentally, or enabled by an operating system by default, which can really mess up your typing. If typing "M" ends up displaying a "0" on your screen, Number Lock is probably the problem.
Try to locate the function key. On a T-series ThinkPad, it's in the lower left hand corner. It should be labeled "Fn," and the lettering may be blue, green or red instead of white. If your laptop lacks a "Fn" key, use the "Shift" key for Step 3 below instead. Locate the key labeled with "NmLk". On a T-series ThinkPad it shares a key with "ScrLk" which sits on the very top row between the "PrtSc" and "Pause" keys. On other IBM laptops, the "NmLk" key might share a key with "Delete." While holding down the "Fn" key or the "Shift" key, depending on your model, press the "NmLk" key. This should turn off Number Lock and restore your keyboard to its usual state. Number Lock on an IBM laptop is a "toggle" setting. You can turn Number Lock on by following the same steps.
b>
Feb 05, 2013 | IBM ThinkPad Computers & Internet
Ibm thinkpad 2628 when you boot, a lock appears on the top left corner of the screen. Please help
For IBM/Lenovo Password
there is solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net/a2_series.htm u need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..u need to make com port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html
Thanks
Sep 11, 2010 | IBM ThinkPad A21m 2628 Notebook
My laptop IBM 2652 is locked .A padlock appears at top left of screen.I would appreciate help in unlocking and returning it to factory settings.My user guide is lost.
The Thinkpad is locked with a Power On Password and its purpose is to prevent unauthorized access to the laptop..
This password is set from the BIOS configuration.
Removing the BIOS battery to set the BIOS back to the factory default will not remove the password because it is stored on an EEPROM chip on the motherboard.
There is a way to remove this password, but it requires electronic knowledge and soldering skills. Please click on this link and follow my instructions.
http://www.fixya.com/support/r4335050-remove_bios_power_password_thinkpad
Jun 04, 2010 | IBM ThinkPad A31 Notebook
When i turn on my laptop it wants a password befor it will boot i didnt have one befor so i have a toshiba thinkpad t9545 and when i turn it on a small lock appears in top left hand corner it gives me...
the easest way to fix this is to pull the bios battery its a quarter sized flat battery on the mother board.
this will fix it for sure.
Good Luck.
Happy Computing
Jan 10, 2010 | IBM System Board 9545 (66G5036)...
IBM A31 2652 Video garbled video at boot
This is very possibly a hardware problem, namely a crack in the motherboard. Sorry, no easy or cheap fix for it if that's the case.
Feb 18, 2009 | IBM ThinkPad T42 Notebook
update monitor driver
your screen may be going
how old is the system
Jan 26, 2009 | IBM ThinkPad A31 Notebook
Ten key pad keys are turned on. How do i switch them off
Solution#1: Accidentally pressing Sft+Numlock key combination will activate & inactivates ten key pad. (You'll see light enabled in padlock symbol with a number in it [i.e.beside ALL CAPS symbol on your lap monitor]).
Use: "ShiftKey+NumLock" (NumbLock Key: 2nd panel from Top right on keyboard)
Jan 07, 2009 | IBM ThinkPad R51 Notebook
My thinkpad (X60s) will not start... when I try to start it, a lock icon shows up on the screen and no key seems to work...
This is a power on password set in bios. The keys appear not to work because it does not show anything you type. If it is a lock icon in the top right corner of the screen with a cursor next to it that is your problem. And we are not sure if there is a global passwork for the thinkpad, for this you would have to call IBM
Dec 22, 2008 | Computers & Internet
Ibm thinkpad A30 2652
Some of the older thinkpad had a program you from the OS or a boot floppy to had to run to get change the bios settings. But the BIOS key on most is F1. So if you press that key as soon as you turn the machine on and anything appears on the screen, and once you've provided the password you can then change the password to blank within the bios.
If you don't know the password at all, there may still be a way to reset it, but it may require a call to IBM/Lenov, or some other tedious process.
Feb 02, 2008 | IBM ThinkPad T40 2373 Notebook
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
