Infinity 7540A Car Audio Amplifier
Problem for Infinity 7540A Car Audio Amplifier
On and off
By nrh06002 on Oct 21, 2008
it was hitting a loud note and just cut out. i noticed that the power light blinked off and on and my speakers were moving in and out very slowly in opposite directions. i have a protect light and clip light and power light, and just the power comes on for a second, every five seconds and a bit of sound comes out. help please
Comments:
Oct 22, 2008
- no just the power light blinks on every five seconds and it sound come out
Solution #1
posted on Dec 03, 2008
Not Rated)
decidedly
Rank: Apprentice
Rating: 92%, 2 votes
Are the speakers that are moving oppositely in the same enclosure with no divider between them? If so (and assuming they were originally wired in phase properly), then one of them may be blown and causing the amp to short and go into thermal protect.
(In theory, with the power-on low-frequency "bump", the speakers should move in the same direction, so moving oppositely, if sharing the same airspace, could mean only one is working).
Unhook all speakers connected to the amp at the amp end, power up the system and see if the amp stays on with all power lights in their normal mode.
Was this helpful?
Yes
No
Solution #2
posted on Oct 23, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
You need to confirm that the voltage on the B+ and remote terminals of the amp are remaining at or above 11v. Place the black meter probe on the ground terminal of the amplifier when measuring the voltage. Let me know what you find.
Solution #3
posted on Oct 21, 2008
Not Rated)
pbabin
Rank: Guru
Rating: 89%, 362 votes
Are any lights on?
Was this helpful?
Yes
No
Popular Solutions for Infinity 7540A Car Audio
Questions and Unsolved Problems for Infinity 7540A Car Audio
Do you recommend Infinity 7540A Car Audio Amplifier?
Answer
Answer
im looking at a ssl fy1402 1400 watt amp 375rmsX2 at 2ohm and it is 2ohm stable. I'm getting a cvt12... (More)
Answer
hooked amp up it was working softly changed ring terminal on power cable to battery and it would not... (More)
Answer
Ford 5000 RDS head unit, the radio is drifting on AM and FM and making screeching noises as if... (More)
Answer
I need to know the wiring of the orion 2100 hcca amp?
Answer
Car audio amp Infinity 475A -do not work.I try to fix it but I have no circuit diagram . PWM on... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Infinity 7540A Car Audio...:
Top Car Amplifier Experts
Rank: Guru Guru
Solutions: 14935
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Car Amplifier Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
